pqScalarsToColors is a represents a vtkScalarsToColors proxy. More...
#include <pqScalarsToColors.h>
| enum | Mode { MAGNITUDE = 0, COMPONENT = 1 } |
| enum | RangeScalingModes { GROW_ON_MODIFIED, GROW_ON_UPDATED } |
Public Types inherited from pqProxy | |
| enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
| The modification state of this proxy. More... | |
Public Slots | |
| void | hideUnusedScalarBars () |
| void | setScalarRangeLock (bool lock) |
| Set the scalar range lock. More... | |
| void | build () |
| Triggers a build on the lookup table. More... | |
Signals | |
| void | componentOrModeChanged () |
| signal fired when the "VectorMode" or "VectorComponent" properties are modified. More... | |
Signals inherited from pqProxy | |
| void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More... | |
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More... | |
| pqScalarsToColors (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) | |
| ~pqScalarsToColors () override | |
| pqScalarBarRepresentation * | getScalarBar (pqRenderViewBase *ren) const |
| Returns the first scalar bar visible in the given render module, if any. More... | |
| bool | getScalarRangeLock () const |
| Returns if the lookup table's scalar range is locked. More... | |
| void | setScalarRange (double min, double max) |
| Sets the scalar range. More... | |
| QPair< double, double > | getScalarRange () const |
| Returns the current scalar range. More... | |
| bool | getUseLogScale () const |
| Returns true if a log scale is being used. More... | |
| void | setVectorMode (Mode mode, int component) |
| Mode | getVectorMode () const |
| int | getVectorComponent () const |
| void | updateScalarBarTitles (const QString &component) |
| Convenience method to update the titles for all color legends showing this lookup table. More... | |
Public Member Functions inherited from pqProxy | |
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) | |
| ~pqProxy () override | |
| Get the server on which this proxy exists. More... | |
| This is a convenience method. More... | |
| Get the name with which this proxy is registered on the server manager. More... | |
| Get the vtkSMProxy this object stands for. More... | |
| Gets whether or not the source has been modified. More... | |
| Sets whether or not the source has been modified. More... | |
| Returns the hints for this proxy, if any. More... | |
| Returns a list of all helper proxies. More... | |
| Returns a list of all the helper proxies added with a given key. More... | |
| Returns the keys for helper proxies. More... | |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
| Return whether or not the user has modified the GUI name of the source. More... | |
Public Member Functions inherited from pqServerManagerModelItem | |
| pqServerManagerModelItem (QObject *parent=NULL) | |
| ~pqServerManagerModelItem () override | |
| static void | setColorRangeScalingMode (int) |
| This merely update the application settings with correct values for the temporal range scaling mode. More... | |
| static int | colorRangeScalingMode (int default_value=GROW_ON_MODIFIED) |
Static Public Member Functions inherited from pqProxy | |
| static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
| Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
| static std::string | rstToHtml (const char *rstStr) |
| convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
| static QString | rstToHtml (const QString &rstStr) |
Protected Slots | |
| void | checkRange () |
| Checks to make sure that the range is compatible with the log flag and adjusts it if necessary. More... | |
Protected Slots inherited from pqProxy | |
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
Protected Member Functions inherited from pqProxy | |
| Make this pqProxy take on a new identity. More... | |
| virtual void | initialize () |
Protected Member Functions inherited from pqServerManagerModelItem | |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
Definition at line 47 of file pqScalarsToColors.h.
| Enumerator | |
| MAGNITUDE | |
| COMPONENT | |
Definition at line 85 of file pqScalarsToColors.h.
| Enumerator | |
| GROW_ON_MODIFIED | |
| GROW_ON_UPDATED | |
Definition at line 107 of file pqScalarsToColors.h.
| pqScalarsToColors::pqScalarsToColors | ( | const QString & | group, |
| const QString & | name, | ||
| vtkSMProxy * | proxy, | ||
| pqServer * | server, | ||
| QObject * | parent = NULL |
| pqScalarBarRepresentation* pqScalarsToColors::getScalarBar | ( | pqRenderViewBase * | ren | ) | const |
| bool pqScalarsToColors::getScalarRangeLock | ( | ) | const |
Does not consider the ScalarRangeLock. Moves all control points uniformly to fit the new range.
If number of RGBPoints is 0, then the scalar range is not defined (in which case this method returns (0, 0).
| bool pqScalarsToColors::getUseLogScale | ( | ) | const |
| Mode pqScalarsToColors::getVectorMode | ( | ) | const |
| int pqScalarsToColors::getVectorComponent | ( | ) | const |
| void pqScalarsToColors::updateScalarBarTitles | ( | const QString & | component | ) |
This only updates the component part of the title.
Components that scale scalar range should look at this setting to determine how the scaling should be done. This provides access to the application settings that controls when color table ranges are updated by the application. Components that scale scalar range should look at this setting to determine how the scaling should be done.
signal |
slot |
slot |
slot |
protectedslot |
