pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (for the proxy's properties or display properties).
#include <pqPropertyWidget.h>
Definition at line 25 of file pqPropertyWidget.h.
◆ pqPropertyWidget()
| pqPropertyWidget::pqPropertyWidget |
vtkSMProxy * |
proxy, |
QWidget * |
parent = nullptr |
◆ ~pqPropertyWidget()
| pqPropertyWidget::~pqPropertyWidget |
◆ apply()
| virtual void pqPropertyWidget::apply |
◆ reset()
| virtual void pqPropertyWidget::reset |
◆ select()
| virtual void pqPropertyWidget::select |
inlinevirtual |
◆ selectPort()
| virtual void pqPropertyWidget::selectPort |
int |
portIndex | ) |
inlinevirtual |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive.
Only widgets that have interactive widgets need to override these methods to select/deselect the interactive widgets. selectPort(int) allows to specify an output port index and conditionnaly select the interactive widget if the XML hint WidgetVisibilityLink has been set. Default implementation does nothing.
Reimplemented in pqInteractivePropertyWidgetAbstract.
Definition at line 49 of file pqPropertyWidget.h.
◆ deselect()
| virtual void pqPropertyWidget::deselect |
inlinevirtual |
◆ isSelected()
| bool pqPropertyWidget::isSelected |
const |
Definition at line 51 of file pqPropertyWidget.h.
◆ updateWidget()
| virtual void pqPropertyWidget::updateWidget |
bool |
showing_advanced_properties | ) |
inlinevirtual |
◆ view()
| pqView* pqPropertyWidget::view |
const |
◆ proxy()
◆ property()
◆ panelVisibility()
| virtual char* pqPropertyWidget::panelVisibility |
const |
◆ setPanelVisibility()
| virtual void pqPropertyWidget::setPanelVisibility |
const char * |
vis | ) |
◆ isSingleRowItem()
| virtual bool pqPropertyWidget::isSingleRowItem |
const |
Determines if the PropertyWidget must be constructed using a single row.
Originally intended for PropertyWidgets which are a group of other Propertywidgets, such as pqCheckableProperty. This mandates that when the widget is rendered, its label to be placed in the same row as the widget group.
- See also
- pqProxyWidgetItem::newGroupItem
Reimplemented in pqCheckableProperty.
◆ showLabel()
| bool pqPropertyWidget::showLabel |
const |
◆ getXMLName()
template<class T >
| static QString pqPropertyWidget::getXMLName |
T * |
object | ) |
inlinestatic |
Description: This static utility method returns the XML name for an object as a QString.
This allows for code to get the XML name of an object without having to explicitly check for a possibly nullptr char* pointer.
This is templated so that it will work with a variety of objects such as vtkSMProperty's and vtkSMDomain's. It can be called with anything that has a "char* GetXMLName()" method.
For example, to get the XML name of a vtkSMIntRangeDomain: QString name = pqPropertyWidget::getXMLName(domain);
Definition at line 104 of file pqPropertyWidget.h.
◆ decorators()
◆ getTooltip()
| static QString pqPropertyWidget::getTooltip |
vtkSMProperty * |
property | ) |
Returns the tooltip to use for the property.
May return an empty string.
◆ hintsWidgetHeightNumberOfRows()
| static int pqPropertyWidget::hintsWidgetHeightNumberOfRows |
vtkPVXMLElement * |
hints, |
int |
defaultValue = 10 |
Helper method to return value from WidgetHeight XML hint, if any.
<WidgetHeight number_of_rows="val">,
◆ parseComponentLabels()
Parse a XML element as a list of label to use for this widget.
This is usually the XML node named ShowComponentLabels in the hints of a proxy. elemCount is a hint of the number of labels to use. Set to 0 to use the number of labels existing in the XML.
◆ viewChanged
| void pqPropertyWidget::viewChanged |
pqView * |
view | ) |
signal |
This signal is emitted when the current view changes.
◆ changeAvailable
| void pqPropertyWidget::changeAvailable |
signal |
This signal is fired as soon as the user starts editing in the widget.
The editing may not be complete.
◆ changeFinished
| void pqPropertyWidget::changeFinished |
signal |
◆ restartRequired
| void pqPropertyWidget::restartRequired |
signal |
Indicates that a restart of the program is required for the setting to take effect.
◆ setView
| virtual void pqPropertyWidget::setView |
pqView * |
virtualslot |
◆ addPropertyLink() [1/2]
| void pqPropertyWidget::addPropertyLink |
QObject * |
qobject, |
const char * |
qproperty, |
const char * |
qsignal, |
vtkSMProperty * |
smproperty, |
int |
smindex = -1 |
◆ addPropertyLink() [2/2]
◆ removePropertyLink() [1/2]
| void pqPropertyWidget::removePropertyLink |
QObject * |
qobject, |
const char * |
qproperty, |
const char * |
qsignal, |
vtkSMProperty * |
smproperty, |
int |
smindex = -1 |
◆ removePropertyLink() [2/2]
◆ setShowLabel()
| void pqPropertyWidget::setShowLabel |
bool |
show | ) |
◆ setChangeAvailableAsChangeFinished()
| void pqPropertyWidget::setChangeAvailableAsChangeFinished |
bool |
status | ) |
inlineprotected |
◆ addDecorator()
◆ removeDecorator()
◆ links()
◆ setProperty()
◆ pqCompositePropertyWidgetDecorator
◆ pqPropertyWidgetDecorator
◆ pqProxyWidget
