property widget for properties representing a checkable property. More...
#include <pqCheckableProperty.h>
Public Slots | |
| void | setEnableCheckbox (bool enableCheckbox) |
| pqCheckableProperty (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| ~pqCheckableProperty () override | |
| void | apply () override |
| void | reset () override |
| void | select () override |
| void | deselect () override |
| void | updateWidget (bool showing_advanced_properties) override |
| void | setPanelVisibility (const char *vis) override |
| void | setView (pqView *) override |
| bool | isSingleRowItem () const override |
| bool | enableCheckbox () const |
| pqView * | view () const |
| bool | showLabel () const |
Properties | |
| bool | enableCheckbox |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
pqCheckableProperty is designed for a specific use-case: a property that can be enabled or disabled by a checkbox. This is useful for optional properties since it restrains the user to use the property unless it is really needed.
Example proxy definition(s) that use this widget is as follows:
Definition at line 47 of file pqCheckableProperty.h.
| pqCheckableProperty::pqCheckableProperty | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smgroup, | ||
Reimplemented from pqPropertyWidget.
Only widgets that have interactive widgets need to override these methods to select/deselect the interactive widgets. selectPort(int) allows to specify an output port index and conditionnaly select the interactive widget if the XML hint WidgetVisibilityLink has been set. Default implementation does nothing.
This will fire the viewChanged() signal.
Originally intended for PropertyWidgets which are a group of other Propertywidgets, such as pqCheckableProperty. This mandates that when the widget is rendered, its label to be placed in the same row as the widget group.
| bool pqCheckableProperty::enableCheckbox | ( | ) | const |
slot |
readwrite |
Definition at line 71 of file pqCheckableProperty.h.
