This is used by vtkPVXMLParser to represent an XML document starting at the root element. More...
#include <vtkPVXMLElement.h>
| const char * | GetAttribute (const char *name) |
| Get the attribute with the given name. More... | |
| const char * | GetAttributeOrEmpty (const char *name) |
| const char * | GetAttributeOrDefault (const char *name, const char *notFound) |
| const char * | GetCharacterData () |
| Get the character data for the element. More... | |
| vtkPVXMLElement * | GetParent () |
| Get the parent of this element. More... | |
| unsigned int | GetNumberOfNestedElements () |
| Get the number of elements nested in this one. More... | |
| vtkPVXMLElement * | GetNestedElement (unsigned int index) |
| Get the element nested in this one at the given index. More... | |
| vtkPVXMLElement * | FindNestedElement (const char *id) |
| Find a nested element with the given id. More... | |
| vtkPVXMLElement * | FindNestedElementByName (const char *name) |
| Locate a nested element with the given tag name. More... | |
| void | FindNestedElementByName (const char *name, vtkCollection *elements) |
| Locate a set of nested elements with the given tag name. More... | |
| void | RemoveAllNestedElements () |
| Removes all nested elements. More... | |
| void | RemoveNestedElement (vtkPVXMLElement *) |
| Remove a particular element. More... | |
| void | ReplaceNestedElement (vtkPVXMLElement *elementToReplace, vtkPVXMLElement *element) |
| Replace a particular element with another. More... | |
| vtkPVXMLElement * | LookupElement (const char *id) |
| Lookup the element with the given id, starting at this scope. More... | |
| void | RemoveAttribute (const char *attrName) |
| Remove the attribute from the current element. More... | |
| void | SetAttribute (const char *attrName, const char *attrValue) |
| Given it's name and value, set an attribute. More... | |
| void | Merge (vtkPVXMLElement *element, const char *attributeName) |
| Merges another element with this one, both having the same name. More... | |
| bool | Equals (vtkPVXMLElement *other) |
| Return true if the current object has the same content as the other. More... | |
| void | CopyTo (vtkPVXMLElement *other) |
| Copy the current XML element content into the provided one. More... | |
| void | CopyAttributesTo (vtkPVXMLElement *other) |
| Copy the attributes from current XML element content into the provided one. More... | |
| virtual void | SetName (const char *) |
| Set/Get the name of the element. More... | |
| virtual char * | GetName () |
| virtual char * | GetId () |
| Get the id of the element. More... | |
| int | GetScalarAttribute (const char *name, int *value) |
| Get the attribute with the given name converted to a scalar value. More... | |
| int | GetScalarAttribute (const char *name, float *value) |
| int | GetScalarAttribute (const char *name, double *value) |
| int | GetVectorAttribute (const char *name, int length, int *value) |
| int | GetVectorAttribute (const char *name, int length, float *value) |
| int | GetVectorAttribute (const char *name, int length, double *value) |
| int | GetCharacterDataAsVector (int length, int *value) |
| Get the character data converted to a scalar value. More... | |
| int | GetCharacterDataAsVector (int length, float *value) |
| int | GetCharacterDataAsVector (int length, double *value) |
| void | AddAttribute (const char *attrName, const char *attrValue) |
| Given it's name and value, add an attribute. More... | |
| void | AddAttribute (const char *attrName, unsigned int attrValue) |
| void | AddAttribute (const char *attrName, double attrValue) |
| void | AddAttribute (const char *attrName, double attrValue, int precision) |
| void | AddAttribute (const char *attrName, int attrValue) |
| void | AddNestedElement (vtkPVXMLElement *element, int setPrent) |
| Add a sub-element. More... | |
| void | AddNestedElement (vtkPVXMLElement *element) |
| void | PrintXML (ostream &os, vtkIndent indent) |
| Serialize (as XML) in the given stream. More... | |
| void | PrintXML () |
| void | GetElementsByName (const char *name, vtkCollection *elements) |
| Similar to DOM specific getElementsByTagName(). More... | |
| void | GetElementsByName (const char *name, vtkCollection *elements, bool recursively) |
| static vtkPVXMLElement * | SafeDownCast (vtkObject *o) |
| static vtkPVXMLElement * | New () |
| static std::string | Encode (const char *plaintext) |
| Encode a string. More... | |
Protected Attributes | |
| vtkPVXMLElementInternals * | Internal |
| char * | Name |
| char * | Id |
| vtkPVXMLElement * | Parent |
Friends | |
| class | vtkPVXMLParser |
Definition at line 23 of file vtkPVXMLElement.h.
| typedef vtkObject vtkPVXMLElement::Superclass |
Definition at line 26 of file vtkPVXMLElement.h.
This is its XML tag. (<Name/>).
This is assigned by the XML parser and can be used as an identifier to an element.
If it doesn't exist, returns nullptr.
Definition at line 51 of file vtkPVXMLElement.h.
If it doesn't exist, returns "".
Definition at line 57 of file vtkPVXMLElement.h.
If it doesn't exist, returns the provided notFound value.
| const char* vtkPVXMLElement::GetCharacterData | ( | ) |
Returns 1 if a value was extracted.
Returns length of vector read.
| vtkPVXMLElement* vtkPVXMLElement::GetParent | ( | ) |
| unsigned int vtkPVXMLElement::GetNumberOfNestedElements | ( | ) |
| vtkPVXMLElement* vtkPVXMLElement::GetNestedElement | ( | unsigned int | index | ) |
| vtkPVXMLElement* vtkPVXMLElement::FindNestedElement | ( | const char * | id | ) |
Not that this searches only the immediate children of this vtkPVXMLElement.
| vtkPVXMLElement* vtkPVXMLElement::FindNestedElementByName | ( | const char * | name | ) |
| void vtkPVXMLElement::FindNestedElementByName | ( | const char * | name, |
| vtkCollection * | elements | ||
| void vtkPVXMLElement::RemoveAllNestedElements | ( | ) |
| void vtkPVXMLElement::RemoveNestedElement | ( | vtkPVXMLElement * | ) |
| void vtkPVXMLElement::ReplaceNestedElement | ( | vtkPVXMLElement * | elementToReplace, |
| vtkPVXMLElement * | element | ||
| vtkPVXMLElement* vtkPVXMLElement::LookupElement | ( | const char * | id | ) |
| void vtkPVXMLElement::RemoveAttribute | ( | const char * | attrName | ) |
If an attribute with the given name already exists, it replaces the old attribute. chars that need to be XML escaped will be done so internally for example " will be converted to "
| void vtkPVXMLElement::AddNestedElement | ( | vtkPVXMLElement * | element, |
| int | setPrent | ||
Add a sub-element.
The parent element keeps a reference to sub-element. If setParent is true, the nested element's parent is set as this.
| void vtkPVXMLElement::AddNestedElement | ( | vtkPVXMLElement * | element | ) |
Add a sub-element.
| void vtkPVXMLElement::PrintXML | ( | ostream & | os, |
| vtkIndent | indent | ||
| void vtkPVXMLElement::PrintXML | ( | ) |
| void vtkPVXMLElement::Merge | ( | vtkPVXMLElement * | element, |
| const char * | attributeName | ||
If any attribute, character data or nested element exists in both, the passed in one will override this one's. If they don't exist, they'll be added. If nested elements have the same names, the optional attributeName maybe passed in as another criteria to determine what to merge in case of same names.
| void vtkPVXMLElement::GetElementsByName | ( | const char * | name, |
Returns a list of vtkPVXMLElements with the given name in the order in which they will be encountered in a preorder traversal of the sub-tree under this node. The elements are populated in the vtkCollection passed as an argument.
| vtkCollection * | elements, | ||
| bool | recursively | ||
Encode a string.
| bool vtkPVXMLElement::Equals | ( | vtkPVXMLElement * | other | ) |
The comparison implementation is pretty weak in the mean that we compare resulting XML string.
| void vtkPVXMLElement::CopyTo | ( | vtkPVXMLElement * | other | ) |
| void vtkPVXMLElement::CopyAttributesTo | ( | vtkPVXMLElement * | other | ) |
protectedvirtual |
friend |
Definition at line 276 of file vtkPVXMLElement.h.
Definition at line 258 of file vtkPVXMLElement.h.
Definition at line 260 of file vtkPVXMLElement.h.
Definition at line 261 of file vtkPVXMLElement.h.
Definition at line 264 of file vtkPVXMLElement.h.
