#include <vtkSMPropertyGroup.h>
| bool | IsEmpty () const |
| Returns true if the property group contains zero properties. More... | |
| void | AddProperty (const char *function, vtkSMProperty *property, const char *name=nullptr) |
Adds property to the group. More... | |
| const char * | GetPropertyName (unsigned int index) const |
| Returns the name for a property at the given index. More... | |
| vtkSMProperty * | GetProperty (unsigned int index) const |
Returns the property at index. More... | |
| vtkSMProperty * | GetProperty (const char *function) const |
| Returns the property associated with a given function, if any. More... | |
| const char * | GetFunction (vtkSMProperty *property) const |
| Given property in the group, returns its function. More... | |
| unsigned int | GetNumberOfProperties () const |
| Returns the number of properties in the group. More... | |
| virtual void | SetName (const char *) |
Get/Sets the name of the property group to name. More... | |
| virtual char * | GetName () |
Gets/Sets the name of the property group to name. More... | |
| virtual void | SetPanelWidget (const char *) |
| Get/Sets the name of the panel widget to use for the property group. More... | |
| virtual char * | GetPanelWidget () |
| virtual void | SetPanelVisibility (const char *) |
| Get/Sets the panel visibility for the property group. More... | |
| virtual char * | GetPanelVisibility () |
The server manager configuration XML may define <Hints /> element for a property-group. More... | |
| static vtkSMPropertyGroup * | New () |
| static vtkSMPropertyGroup * | SafeDownCast (vtkObject *o) |
| vtkSMPropertyGroup () | |
| ~vtkSMPropertyGroup () override | |
| virtual int | ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) |
| vtkSMObject () | |
Protected Attributes | |
| vtkPVXMLElement * | Hints |
| vtkSMDocumentation * | Documentation |
Friends | |
| class | vtkSMProxy |
Definition at line 16 of file vtkSMPropertyGroup.h.
Definition at line 20 of file vtkSMPropertyGroup.h.
| bool vtkSMPropertyGroup::IsEmpty | ( | ) | const |
| void vtkSMPropertyGroup::AddProperty | ( | const char * | function, |
| vtkSMProperty * | property, | ||
| const char * | name = nullptr |
name is the name of the property. If nullptr, then the property's XML name is used. function is the role assigned to this property. If nullptr, the name (either specified as argument, or the XML name for the property) will be used.
| vtkSMProperty* vtkSMPropertyGroup::GetProperty | ( | unsigned int | index | ) | const |
| vtkSMProperty* vtkSMPropertyGroup::GetProperty | ( | const char * | function | ) | const |
| const char* vtkSMPropertyGroup::GetFunction | ( | vtkSMProperty * | property | ) | const |
Will return nullptr if the property is not present in this group.
| unsigned int vtkSMPropertyGroup::GetNumberOfProperties | ( | ) | const |
Returns the documentation for this proxy.
Hints are metadata associated with the property-group. The Server Manager does not (and should not) interpret the hints. Hints provide a mechanism to add GUI pertinent information to the server manager XML. Returns the XML element for the hints associated with this property, if any, otherwise returns nullptr;
| void vtkSMPropertyGroup::SetHints | ( | vtkPVXMLElement * | hints | ) |
protectedvirtual |
friend |
Definition at line 119 of file vtkSMPropertyGroup.h.
Definition at line 122 of file vtkSMPropertyGroup.h.
Definition at line 123 of file vtkSMPropertyGroup.h.
