pqPropertyWidget for properties with vtkDataAssembly More...
#include <pqDataAssemblyPropertyWidget.h>
Signals | |
| void | selectorsChanged () |
| void | colorsChanged () |
| void | opacitiesChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqDataAssemblyPropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| pqDataAssemblyPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqDataAssemblyPropertyWidget () override | |
| void | updateWidget (bool showing_advanced_properties) override |
| void | setSelectors (const QStringList &paths) |
| API for getting/setting selected/chosen path strings. More... | |
| const QStringList & | selectors () const |
| void | setSelectors (const QList< QVariant > &paths) |
| QList< QVariant > | selectorsAsVariantList () const |
| void | setCompositeIndices (const QList< QVariant > &values) |
| API for getting/settings composite indices. More... | |
| QList< QVariant > | compositeIndicesAsVariantList () const |
| void | setCompositeIndexColors (const QList< QVariant > &values) |
| API to get/set colors. More... | |
| QList< QVariant > | compositeIndexColorsAsVariantList () const |
| void | setSelectorColors (const QList< QVariant > &values) |
| QList< QVariant > | selectorColorsAsVariantList () const |
| void | setCompositeIndexOpacities (const QList< QVariant > &values) |
| API to get/set opacities. More... | |
| QList< QVariant > | compositeIndexOpacitiesAsVariantList () const |
| void | setSelectorOpacities (const QList< QVariant > &values) |
| QList< QVariant > | selectorOpacitiesAsVariantList () const |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QList< QVariant > | selectors |
| Property with selectors/composite indices for checked nodes in the hierarchy. More... | |
| QList< QVariant > | compositeIndices |
| QList< QVariant > | selectorColors |
| Property with selectors/composite indices and associated colors (as RGB). More... | |
| QList< QVariant > | compositeIndexColors |
| QList< QVariant > | selectorOpacities |
| Properties with selectors/composite indieces and associated opacities. More... | |
| QList< QVariant > | compositeIndexOpacities |
| template<class T > | |
pqDataAssemblyPropertyWidget is intended for properties that rely on a vtkDataAssembly i.e. use a vtkSMDataAssemblyDomain. This supports getting/setting the list of selectors for checked nodes based on the chosen vtkDataAssembly. Further more, it supports show the state and resetting block properties.
pqDataAssemblyPropertyWidget can be used on a single property with a vtkSMDataAssemblyDomain or for a group of properties. For a single property, it allows for editing on selectors for checked nodes.
Here's an example proxy XML for a single property.
The widget will use the assembly provided by vtkSMDataAssemblyDomain::GetDataAssembly to render a tree in UI.
A property-group for choosing which named-assembly to use is as follows. All properties in the group are optional and one may specify on subset that is relevant for their use-case. It is assumed, however, that all properties in the group use the same data assembly. If that's not the case, one should use separate property groups, hence separate widgets, for each.
This widget is primarily intended for vtkSMDataAssemblyDomain. However, to support legacy code that uses vtkSMCompositeTreeDomain instead, we add support for vtkSMCompositeTreeDomain as well. It is required, however, that all properties in the group to consistently use vtkSMDataAssemblyDomain or vtkSMCompositeTreeDomain and mixing is not allowed.
TODO: Remove the usage of vtkSMCompositeTreeDomain.
This widget supports hints that can be added to the group (or property). For example:
is_checkable can be set to 0 to avoid showing checkboxes for items in the tree.
use_inputname_as_header, when set to 1 causes the widget to use the input's registration name as the header for the tree widget rather than the XML label for the group (or property) attached to the widget.
link_active_selection, when set to 1 causes the widget to track the active block-selection and vice-versa.
Definition at line 157 of file pqDataAssemblyPropertyWidget.h.
| pqDataAssemblyPropertyWidget::pqDataAssemblyPropertyWidget | ( | vtkSMProxy * | smproxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| vtkSMProperty * | smproperty, | ||
| void pqDataAssemblyPropertyWidget::setSelectors | ( | const QStringList & | paths | ) |
| const QStringList& pqDataAssemblyPropertyWidget::selectors | ( | ) | const |
| void pqDataAssemblyPropertyWidget::setSelectors | ( | const QList< QVariant > & | paths | ) |
| QList<QVariant> pqDataAssemblyPropertyWidget::selectorsAsVariantList | ( | ) | const |
| void pqDataAssemblyPropertyWidget::setCompositeIndices | ( | const QList< QVariant > & | values | ) |
| QList<QVariant> pqDataAssemblyPropertyWidget::compositeIndicesAsVariantList | ( | ) | const |
Colors are specified either as a list of selectors followed by corresponding RGB color or list of composite indices followed by the color.
Definition at line 227 of file pqDataAssemblyPropertyWidget.h.
Definition at line 229 of file pqDataAssemblyPropertyWidget.h.
Definition at line 232 of file pqDataAssemblyPropertyWidget.h.
Definition at line 234 of file pqDataAssemblyPropertyWidget.h.
Opacities are specified either as a list of selectors followed by corresponding opacity or list of composite indices followed by the opacity.
Definition at line 244 of file pqDataAssemblyPropertyWidget.h.
Definition at line 246 of file pqDataAssemblyPropertyWidget.h.
Definition at line 249 of file pqDataAssemblyPropertyWidget.h.
Definition at line 251 of file pqDataAssemblyPropertyWidget.h.
Reimplemented from pqPropertyWidget.
signal |
signal |
signal |
readwrite |
Definition at line 167 of file pqDataAssemblyPropertyWidget.h.
readwrite |
readwrite |
Definition at line 169 of file pqDataAssemblyPropertyWidget.h.
readwrite |
Definition at line 178 of file pqDataAssemblyPropertyWidget.h.
readwrite |
Definition at line 181 of file pqDataAssemblyPropertyWidget.h.
readwrite |
Definition at line 190 of file pqDataAssemblyPropertyWidget.h.
