widget for view resolution. More...
#include <pqViewResolutionPropertyWidget.h>
Signals | |
| void | highlightResetButton () |
| internal signals used to highlight (or not) the "reset-to-domain" button. More... | |
| void | clearHighlight () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqViewResolutionPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqViewResolutionPropertyWidget () override | |
| void | apply () override |
| Overridden to clear the state for the highlight state for "reset-to-domain" button. More... | |
| void | reset () override |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
| template<class T > | |
pqViewResolutionPropertyWidget is desined to be used with properties that allow users to set resolution for things like views, images, movies etc. It provides UI elements to lock aspect ratio, scale size up or down, and reset to default.
This widget works with any vtkSMIntVectorProperty with 2 elements interpreted as (width, height).
As specified in pqStandardPropertyWidgetInterface, to use this widget for a property you can use panel_widget="view_resolution" attribute in ServerManager XML.
Definition at line 27 of file pqViewResolutionPropertyWidget.h.
| pqViewResolutionPropertyWidget::pqViewResolutionPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | smproperty, | ||
The implementation simply fires clearHighlight signal.
Reimplemented from pqPropertyWidget.
signal |
signal |
