| | pqDisplaySizedImplicitPlanePropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| | ~pqDisplaySizedImplicitPlanePropertyWidget () override |
| void | apply () override |
| | Overridden to update the DrawPlane state. More...
| void | reset () override |
| | pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| | ~pqInteractivePropertyWidget () override |
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| | Returns the proxy for the 3D interactive widget. More...
| | pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) |
| | ~pqInteractivePropertyWidgetAbstract () override |
| | Overridden to call this->render() to ensure that the widget is redrawn. More...
| void | setView (pqView *view) override |
| | Overridden to show the widget proxy in the new view. More...
| bool | isWidgetVisible () const |
| | Returns the interactive widget's visibility. More...
| vtkSMProxy * | dataSource () const |
| | Returns the data source. More...
| vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
| | Returns bounds from the dataSource, if possible. More...
| vtkSMPropertyGroup * | propertyGroup () const |
| | Returns the vtkSMPropertyGroup pass to the constructor. More...
| void | hideEvent (QHideEvent *) override |
| | Overriden in order to hide the VTK widget. More...
| void | showEvent (QShowEvent *) override |
| | Overriden in order to show the VTK widget. More...
| void | select () override |
| | In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
| void | deselect () override |
| void | selectPort (int portIndex) final |
| | pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) |
| | ~pqPropertyWidget () override |
| pqView * | view () const |
| | Forward calls to vtkSMProperty. More...
| | Determines if the PropertyWidget must be constructed using a single row. More...
| bool | showLabel () const |
| | Provides access to the decorators for this widget. More...
| | These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
| void | widgetVisibilityToggled (bool) |
| | Fired whenever setWidgetVisible() changes the widget's visibility. More...
| void | widgetVisibilityUpdated (bool) |
| | Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
| void | startInteraction () |
| | Fired by the underlying interactive widget representation proxy, for each respective events. More...
| void | interaction () |
| void | endInteraction () |
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
| | Parse a XML element as a list of label to use for this widget. More...
| vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
| | Get the internal instance of the widget proxy. More...
| void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
| | Setup all the links and events for the given widget and SM property group. More...
| void | setupUserObserver (vtkSMProxy *smproxy) |
| bool | VisibleState = true |
| bool | WidgetVisibility = false |
| int | LinkedPortIndex = -1 |
| pqSMProxy | dataSource |
pqDisplaySizedImplicitPlanePropertyWidget is a custom property widget that uses "DisplaySizedImplicitPlaneWidgetRepresentation" to help users interactively set the origin and normal for a plane.
To use this widget for a property group (vtkSMPropertyGroup), use "InteractivePlane" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Definition at line 23 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
