Expose molecule mapper parameters to the user. More...
#include <pqMoleculePropertyWidget.h>
| pqMoleculePropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parentObject=nullptr) | |
| ~pqMoleculePropertyWidget () override=default | |
| void | updateWidget (bool showing_advanced_properties) override |
| Override to show/hide relevant widgets depending on the advanced properties status. More... | |
Public Member Functions inherited from pqPropertyGroupWidget | |
| pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) | |
| vtkSMPropertyGroup * | propertyGroup () const |
| void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
| char * | panelVisibility () const override |
| Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More... | |
| void | setPanelVisibility (const char *vis) override |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Protected Slots | |
| void | onPresetChanged (int) |
| Apply selected preset to the proxy. More... | |
| void | resetPreset () |
| Reset the preset widget. More... | |
| void | updateBondWidgetsVisibility () |
| Show/hide widgets depending on the states of other widgets. More... | |
| void | updateAtomWidgetsVisibility () |
| void | updateAtomicRadiusWidgetsVisibility () |
| void | updateBondColorWidgetVisibility () |
| void | onScaleAtomFactorChanged (double scale) |
| Update the atom/bond radius sliders bounds. More... | |
| void | onResetAtomFactorToggled () |
| void | onScaleBondRadiusChanged (double scale) |
| void | onResetBondRadiusToggled () |
| void | setDocumentationAsTooltip (vtkSMProperty *prop, QWidget *widget) |
| Set property documentation as widget tooltip. More... | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Some presets are defined for an easiest configuration.
Definition at line 19 of file pqMoleculePropertyWidget.h.
| pqMoleculePropertyWidget::pqMoleculePropertyWidget | ( | vtkSMProxy * | smproxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| QWidget * | parentObject = nullptr |
overridedefault |
Reimplemented from pqPropertyWidget.
protectedslot |
Handle advanced proprerties visibility.
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
If a property has changed, preset widget should display '(no preset)'.
protectedslot |
protectedslot |
protectedslot |
protectedslot |
