vtkSMPlotlyJsonExtractWriterProxy Class Reference
extractor used to extract data from certain views to a json file folowing the plotly-json schema. More...
#include <vtkSMPlotlyJsonExtractWriterProxy.h>
Inheritance diagram for vtkSMPlotlyJsonExtractWriterProxy:
Collaboration diagram for vtkSMPlotlyJsonExtractWriterProxy:
typedef vtkSMExtractWriterProxy Superclass
- Public Types inherited from vtkSMExtractWriterProxy
typedef vtkSMProxy Superclass
virtual void SetView (vtkSMViewProxy *)
 Set the view proxy to export. More...
virtual vtkSMViewProxy * GetView ()
bool Write (vtkSMExtractsController *extractor) override
 Implementation for vtkSMExtractWriterProxy API. More...
bool CanExtract (vtkSMProxy *proxy) override
bool IsExtracting (vtkSMProxy *proxy) override
void SetInput (vtkSMProxy *proxy) override
vtkSMProxy * GetInput () override
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPlotlyJsonExtractWriterProxy * New ()
static vtkSMPlotlyJsonExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExtractWriterProxy
static vtkSMExtractWriterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMPlotlyJsonExtractWriterProxy ()
 ~vtkSMPlotlyJsonExtractWriterProxy () override
- Protected Member Functions inherited from vtkSMExtractWriterProxy
 vtkSMExtractWriterProxy ()
 ~vtkSMExtractWriterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Static Protected Member Functions inherited from vtkSMExtractWriterProxy
static std::string GenerateExtractsFileName (const std::string &filename, const char *outDir)
 Adds the output directory to the filename, replaces, in case of need, the old string format, and returns the formatted string using vtkPVStringFormatter. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Currently, we support vtkPVXYChartView (only line plots for now but could be extended in the future for other kinds of plots Bar etc.)
See also
vtkPlotlyJsonExporter
Definition at line 23 of file vtkSMPlotlyJsonExtractWriterProxy.h.
Definition at line 27 of file vtkSMPlotlyJsonExtractWriterProxy.h.
◆ vtkSMPlotlyJsonExtractWriterProxy()
vtkSMPlotlyJsonExtractWriterProxy::vtkSMPlotlyJsonExtractWriterProxy ( )
◆ ~vtkSMPlotlyJsonExtractWriterProxy()
vtkSMPlotlyJsonExtractWriterProxy::~vtkSMPlotlyJsonExtractWriterProxy ( )
static vtkSMPlotlyJsonExtractWriterProxy* vtkSMPlotlyJsonExtractWriterProxy::New ( )
virtual const char* vtkSMPlotlyJsonExtractWriterProxy::GetClassName ( )
Reimplemented from vtkSMExtractWriterProxy.
static int vtkSMPlotlyJsonExtractWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPlotlyJsonExtractWriterProxy::IsA ( const char *  type)
static vtkSMPlotlyJsonExtractWriterProxy* vtkSMPlotlyJsonExtractWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPlotlyJsonExtractWriterProxy::PrintSelf ( ostream &  os,
◆ SetView()
virtual void vtkSMPlotlyJsonExtractWriterProxy::SetView ( vtkSMViewProxy *  )
◆ GetView()
virtual vtkSMViewProxy* vtkSMPlotlyJsonExtractWriterProxy::GetView ( )
◆ Write()
bool vtkSMPlotlyJsonExtractWriterProxy::Write ( vtkSMExtractsController *  extractor)
Implements vtkSMExtractWriterProxy.
◆ CanExtract()
bool vtkSMPlotlyJsonExtractWriterProxy::CanExtract ( vtkSMProxy *  proxy)
◆ IsExtracting()
bool vtkSMPlotlyJsonExtractWriterProxy::IsExtracting ( vtkSMProxy *  proxy)
◆ SetInput()
void vtkSMPlotlyJsonExtractWriterProxy::SetInput ( vtkSMProxy *  proxy)
◆ GetInput()
vtkSMProxy* vtkSMPlotlyJsonExtractWriterProxy::GetInput ( )
