exporter used by certain views to export data into a file or stream. More...
#include <vtkPlotlyJsonExporter.h>
| typedef vtkAbstractChartExporter | Superclass |
| enum | ExporterModes |
Public Types inherited from vtkAbstractChartExporter | |
| enum | ExporterModes { STREAM_ROWS, STREAM_COLUMNS } |
| bool | Open (ExporterModes mode=STREAM_ROWS) override |
| Open the file and set mode in which the exporter is operating. More... | |
| void | Close () override |
| Closes the file cleanly. More... | |
| void | Abort () override |
| Same as Close except deletes the file, if created. More... | |
| void | AddColumn (vtkAbstractArray *yarray, const char *yarrayname=nullptr, vtkDataArray *xarray=nullptr) override |
| Add a new plot using xarray as "x" values and yarray as "y" values. More... | |
| void | AddStyle (vtkPlot *plot, const char *plotName) override |
Add the stringified attribute under then name attributeName in the Adios file. More... | |
| void | SetGlobalStyle (vtkChart *chart) override |
| Set Global style elements like graph and axis titles. More... | |
| std::string | GetOutputString () const |
| virtual void | SetFileName (const char *) |
| Get/Set the filename for the file. More... | |
| virtual char * | GetFileName () |
| void | WriteHeader (vtkFieldData *) override |
| No Supported by vtkPlotlyJsonExporter. More... | |
| void | WriteData (vtkFieldData *) override |
| virtual void | SetWriteToOutputString (bool) |
| Whether to output to a string instead of to a file which is the default. More... | |
| virtual bool | GetWriteToOutputString () |
| virtual void | WriteToOutputStringOn () |
| virtual void | WriteToOutputStringOff () |
| static vtkPlotlyJsonExporter * | New () |
| static vtkPlotlyJsonExporter * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkAbstractChartExporter | |
| static vtkAbstractChartExporter * | New () |
| static vtkAbstractChartExporter * | SafeDownCast (vtkObject *o) |
| vtkPlotlyJsonExporter () | |
| ~vtkPlotlyJsonExporter () override | |
Protected Member Functions inherited from vtkAbstractChartExporter | |
| vtkAbstractChartExporter () | |
| ~vtkAbstractChartExporter () override | |
Definition at line 17 of file vtkPlotlyJsonExporter.h.
Definition at line 22 of file vtkPlotlyJsonExporter.h.
Definition at line 30 of file vtkAbstractChartExporter.h.
Reimplemented from vtkAbstractChartExporter.
Implements vtkAbstractChartExporter.
Call this at the end to close the file and dump out any cached data.
This is useful to interrupt the exporting on failure.
The name of the plot will be yarrayname
Each implementation is expected to get what it can support from the public vtkChart API.
| std::string vtkPlotlyJsonExporter::GetOutputString | ( | ) | const |
