vtkSMNumberOfComponentsDomain Class Reference
int range domain based on the number of components available in a particular data array. More...
#include <vtkSMNumberOfComponentsDomain.h>
Inheritance diagram for vtkSMNumberOfComponentsDomain:
Collaboration diagram for vtkSMNumberOfComponentsDomain:
typedef vtkSMEnumerationDomain Superclass
- Public Types inherited from vtkSMEnumerationDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *prop) override
 Updates the range based on the scalar range of the currently selected array. More...
- Public Member Functions inherited from vtkSMEnumerationDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (int val, unsigned int &idx)
 Returns true if the int is in the domain. More...
unsigned int GetNumberOfEntries ()
 Returns the number of entries in the enumeration. More...
int GetEntryValue (unsigned int idx)
 Returns the integer value of an enumeration entry. More...
const char * GetEntryText (unsigned int idx)
 Returns the descriptive string of an enumeration entry. More...
const char * GetEntryTextForValue (int value)
 Returns the text for an enumeration value. More...
int HasEntryText (const char *text)
 Return 1 is the text is present in the enumeration, otherwise 0. More...
int GetEntryValueForText (const char *text)
 Get the value for an enumeration text. More...
int GetEntryValue (const char *text, int &valid)
 Given an entry text, return the integer value. More...
const char * GetInfoText (unsigned int idx)
 Returns the info text for an enumeration entry. More...
void AddEntry (const char *text, int value, const char *info=nullptr)
 Add a new enumeration entry. More...
void RemoveAllEntries ()
 Clear all entries. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMNumberOfComponentsDomain * New ()
static vtkSMNumberOfComponentsDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMEnumerationDomain
static vtkSMEnumerationDomain * New ()
static vtkSMEnumerationDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMNumberOfComponentsDomain ()
 ~vtkSMNumberOfComponentsDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void Update (const char *arrayname, vtkSMSourceProxy *sp, vtkSMInputArrayDomain *iad, int outputport)
 Internal update method doing the actual work. More...
- Protected Member Functions inherited from vtkSMEnumerationDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
 vtkSMEnumerationDomain ()
 ~vtkSMEnumerationDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMNumberOfComponentsDomain is used for properties that allow the user to choose the component number (or associated name) to process for the chosen array. It needs two required properties with following functions:
Definition at line 25 of file vtkSMNumberOfComponentsDomain.h.
Definition at line 29 of file vtkSMNumberOfComponentsDomain.h.
◆ vtkSMNumberOfComponentsDomain()
vtkSMNumberOfComponentsDomain::vtkSMNumberOfComponentsDomain ( )
◆ ~vtkSMNumberOfComponentsDomain()
vtkSMNumberOfComponentsDomain::~vtkSMNumberOfComponentsDomain ( )
static vtkSMNumberOfComponentsDomain* vtkSMNumberOfComponentsDomain::New ( )
virtual const char* vtkSMNumberOfComponentsDomain::GetClassName ( )
Reimplemented from vtkSMEnumerationDomain.
static int vtkSMNumberOfComponentsDomain::IsTypeOf ( const char *  type)
virtual int vtkSMNumberOfComponentsDomain::IsA ( const char *  type)
static vtkSMNumberOfComponentsDomain* vtkSMNumberOfComponentsDomain::SafeDownCast ( vtkObject *  o)
void vtkSMNumberOfComponentsDomain::PrintSelf ( ostream &  os,
◆ Update() [1/2]
void vtkSMNumberOfComponentsDomain::Update ( vtkSMProperty *  prop)
This requires Input (vtkSMProxyProperty) and ArraySelection (vtkSMStringVectorProperty) properties. Currently, this uses only the first component of the array.
◆ ReadXMLAttributes()
int vtkSMNumberOfComponentsDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ Update() [2/2]
void vtkSMNumberOfComponentsDomain::Update ( const char *  arrayname,
vtkSMSourceProxy *  sp,
vtkSMInputArrayDomain *  iad,
int  outputport
