vtkSMMultiplexerInputDomain Class Reference
input domain used for vtkSMMultiplexerSourceProxy More...
#include <vtkSMMultiplexerInputDomain.h>
Inheritance diagram for vtkSMMultiplexerInputDomain:
Collaboration diagram for vtkSMMultiplexerInputDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMMultiplexerInputDomain * New ()
static vtkSMMultiplexerInputDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMMultiplexerInputDomain ()
 ~vtkSMMultiplexerInputDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMMultiplexerInputDomain is intended to be used for input properties on vtkSMMultiplexerSourceProxy. It ensures that IsInDomain checks are forwarded for all available multiplexed proxies.
Definition at line 18 of file vtkSMMultiplexerInputDomain.h.
Definition at line 22 of file vtkSMMultiplexerInputDomain.h.
◆ vtkSMMultiplexerInputDomain()
vtkSMMultiplexerInputDomain::vtkSMMultiplexerInputDomain ( )
◆ ~vtkSMMultiplexerInputDomain()
vtkSMMultiplexerInputDomain::~vtkSMMultiplexerInputDomain ( )
static vtkSMMultiplexerInputDomain* vtkSMMultiplexerInputDomain::New ( )
virtual const char* vtkSMMultiplexerInputDomain::GetClassName ( )
static int vtkSMMultiplexerInputDomain::IsTypeOf ( const char *  type)
virtual int vtkSMMultiplexerInputDomain::IsA ( const char *  type)
static vtkSMMultiplexerInputDomain* vtkSMMultiplexerInputDomain::SafeDownCast ( vtkObject *  o)
void vtkSMMultiplexerInputDomain::PrintSelf ( ostream &  os,
◆ IsInDomain()
int vtkSMMultiplexerInputDomain::IsInDomain ( vtkSMProperty *  property)
override
