Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkPVDataSetAttributesInformation Class Reference
List of array info. More...
#include <vtkPVDataSetAttributesInformation.h>
Inheritance diagram for vtkPVDataSetAttributesInformation:
Collaboration diagram for vtkPVDataSetAttributesInformation:
void Initialize ()
 Initialize this instances to its default state. More...
int GetNumberOfArrays () const
 Returns the number of array informations available in this instance. More...
int GetMaximumNumberOfTuples () const
 Returns the maximum number of tuples in all known arrays. More...
vtkPVArrayInformation * GetAttributeInformation (int attributeType)
 Returns array information for an array associated with a specific attribute type. More...
int IsArrayAnAttribute (int arrayIndex)
 Returns the attribute type if at the array at the given index is an attribute. More...
 Returns the field association to which the instance corresponds to. More...
vtkPVArrayInformation * GetArrayInformation (int idx) const
 Returns array information for the chosen array either by name or by index. More...
vtkPVArrayInformation * GetArrayInformation (const char *name) const
static vtkPVDataSetAttributesInformation * New ()
static vtkPVDataSetAttributesInformation * SafeDownCast (vtkObject *o)
 vtkPVDataSetAttributesInformation ()
 ~vtkPVDataSetAttributesInformation () override
virtual void SetFieldAssociation (int)
 Set field association. More...
void AddInformation (vtkPVDataSetAttributesInformation *)
 Combine with another vtkPVDataSetAttributesInformation instance. More...
void DeepCopy (vtkPVDataSetAttributesInformation *)
 Copies from another vtkPVDataSetAttributesInformation instance. More...
void CopyFromDataObject (vtkDataObject *dobj)
 Initializes this instance using the data object. More...
void CopyToStream (vtkClientServerStream *)
 Manage a serialized version of the information. More...
void CopyFromStream (const vtkClientServerStream *)
Friends
class vtkPVDataInformation
class vtkPVDataInformationAccumulator
List of array info.
Information associated with vtkDataSetAttributes object (i.e point data). This object does not have any user interface. It is created and destroyed on the fly as needed. It may be possible to add features of this object to vtkDataSetAttributes. That would eliminate all of the "Information" in ParaView.
Definition at line 24 of file vtkPVDataSetAttributesInformation.h.
Definition at line 28 of file vtkPVDataSetAttributesInformation.h.
◆ vtkPVDataSetAttributesInformation()
vtkPVDataSetAttributesInformation::vtkPVDataSetAttributesInformation ( )
◆ ~vtkPVDataSetAttributesInformation()
vtkPVDataSetAttributesInformation::~vtkPVDataSetAttributesInformation ( )
static vtkPVDataSetAttributesInformation* vtkPVDataSetAttributesInformation::New ( )
virtual const char* vtkPVDataSetAttributesInformation::GetClassName ( )
static int vtkPVDataSetAttributesInformation::IsTypeOf ( const char *  type)
virtual int vtkPVDataSetAttributesInformation::IsA ( const char *  type)
static vtkPVDataSetAttributesInformation* vtkPVDataSetAttributesInformation::SafeDownCast ( vtkObject *  o)
void vtkPVDataSetAttributesInformation::PrintSelf ( ostream &  os,
◆ GetFieldAssociation()
virtual int vtkPVDataSetAttributesInformation::GetFieldAssociation ( )
Returned value can be vtkDataObject::POINT, vtkDataObject::CELL, vtkDataObject::FIELD, etc i.e. vtkDataObject::FieldAssociations or vtkDataObject::AttributeTypes.
◆ Initialize()
void vtkPVDataSetAttributesInformation::Initialize ( )
◆ GetNumberOfArrays()
int vtkPVDataSetAttributesInformation::GetNumberOfArrays ( ) const
◆ GetMaximumNumberOfTuples()
int vtkPVDataSetAttributesInformation::GetMaximumNumberOfTuples ( ) const
◆ GetArrayInformation() [1/2]
vtkPVArrayInformation* vtkPVDataSetAttributesInformation::GetArrayInformation ( int  idx) const
◆ GetArrayInformation() [2/2]
vtkPVArrayInformation* vtkPVDataSetAttributesInformation::GetArrayInformation ( const char *  name) const
◆ GetAttributeInformation()
vtkPVArrayInformation* vtkPVDataSetAttributesInformation::GetAttributeInformation ( int  attributeType)
Supported attribute types are vtkDataSetAttributes::AttributeTypes.
◆ IsArrayAnAttribute()
int vtkPVDataSetAttributesInformation::IsArrayAnAttribute ( int  arrayIndex)
◆ SetFieldAssociation()
virtual void vtkPVDataSetAttributesInformation::SetFieldAssociation ( int  )
protectedvirtual
◆ CopyToStream()
void vtkPVDataSetAttributesInformation::CopyToStream ( vtkClientServerStream *  )
◆ CopyFromStream()
void vtkPVDataSetAttributesInformation::CopyFromStream ( const vtkClientServerStream *  )
◆ AddInformation()
void vtkPVDataSetAttributesInformation::AddInformation ( vtkPVDataSetAttributesInformation *  )
◆ DeepCopy()
void vtkPVDataSetAttributesInformation::DeepCopy ( vtkPVDataSetAttributesInformation *  )
◆ CopyFromDataObject()
void vtkPVDataSetAttributesInformation::CopyFromDataObject ( vtkDataObject *  dobj)
◆ vtkPVDataInformation
friend class vtkPVDataInformation
friend
Definition at line 80 of file vtkPVDataSetAttributesInformation.h.
◆ vtkPVDataInformationAccumulator
friend class vtkPVDataInformationAccumulator
friend
Definition at line 81 of file vtkPVDataSetAttributesInformation.h.
