vtkSMSelectionQueryDomain Class Reference
domain used for QueryString for selection source. More...
#include <vtkSMSelectionQueryDomain.h>
Inheritance diagram for vtkSMSelectionQueryDomain:
Collaboration diagram for vtkSMSelectionQueryDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *requestingProperty) override
 Update self based on the "unchecked" values of all required properties. More...
int GetElementType ()
 Returns currently chosen element type. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMSelectionQueryDomain * New ()
static vtkSMSelectionQueryDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMSelectionQueryDomain ()
 ~vtkSMSelectionQueryDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMSelectionQueryDomain is used by "QueryString" property on a selection source. It is primarily intended to fire domain modified event when the selection query string's available options may have changed.
Definition at line 17 of file vtkSMSelectionQueryDomain.h.
Definition at line 21 of file vtkSMSelectionQueryDomain.h.
◆ vtkSMSelectionQueryDomain()
vtkSMSelectionQueryDomain::vtkSMSelectionQueryDomain ( )
◆ ~vtkSMSelectionQueryDomain()
vtkSMSelectionQueryDomain::~vtkSMSelectionQueryDomain ( )
static vtkSMSelectionQueryDomain* vtkSMSelectionQueryDomain::New ( )
virtual const char* vtkSMSelectionQueryDomain::GetClassName ( )
static int vtkSMSelectionQueryDomain::IsTypeOf ( const char *  type)
virtual int vtkSMSelectionQueryDomain::IsA ( const char *  type)
static vtkSMSelectionQueryDomain* vtkSMSelectionQueryDomain::SafeDownCast ( vtkObject *  o)
void vtkSMSelectionQueryDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMSelectionQueryDomain::Update ( vtkSMProperty *  requestingProperty)
Subclasses must override this method to update the domain based on the requestingProperty (and/or other required properties).
◆ GetElementType()
int vtkSMSelectionQueryDomain::GetElementType ( )
