Signals | Public Member Functions | Properties | List of all members
pqScalarValueListPropertyWidget Class Reference
pqScalarValueListPropertyWidget provides a table widget to which users are add values e.g. More...
#include <pqScalarValueListPropertyWidget.h>
Inheritance diagram for pqScalarValueListPropertyWidget:
Collaboration diagram for pqScalarValueListPropertyWidget:
Signals
void scalarsChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqScalarValueListPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqScalarValueListPropertyWidget () override
void setScalars (const QVariantList &scalars)
QVariantList scalars () const
void setShowLabels (bool)
void setLabels (const std::vector< std::string > &labels)
void setRangeDomain (vtkSMDoubleRangeDomain *smRangeDomain)
 Sets range domain that will be used to initialize the scalar range. More...
void setRangeDomain (vtkSMIntRangeDomain *smRangeDomain)
void setRangeDomain (vtkSMTimeStepsDomain *timestepsDomain)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
for IsoValues for the Contour filter.
This widget supports the AllowRestoreDefaults hints, which adds a button that allow users to restore the default value of the property.
Definition at line 28 of file pqScalarValueListPropertyWidget.h.
◆ pqScalarValueListPropertyWidget()
pqScalarValueListPropertyWidget::pqScalarValueListPropertyWidget ( vtkSMProperty *  property,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqScalarValueListPropertyWidget()
pqScalarValueListPropertyWidget::~pqScalarValueListPropertyWidget ( )
override
◆ setScalars()
void pqScalarValueListPropertyWidget::setScalars ( const QVariantList &  scalars)
◆ scalars()
QVariantList pqScalarValueListPropertyWidget::scalars ( ) const
◆ setRangeDomain() [1/3]
void pqScalarValueListPropertyWidget::setRangeDomain ( vtkSMDoubleRangeDomain *  smRangeDomain)
vtkSMTimeStepsDomain does have a concept of min and max that can be used as a range.
◆ setRangeDomain() [2/3]
void pqScalarValueListPropertyWidget::setRangeDomain ( vtkSMIntRangeDomain *  smRangeDomain)
◆ setRangeDomain() [3/3]
void pqScalarValueListPropertyWidget::setRangeDomain ( vtkSMTimeStepsDomain *  timestepsDomain)
◆ setShowLabels()
void pqScalarValueListPropertyWidget::setShowLabels ( bool  )
◆ setLabels()
void pqScalarValueListPropertyWidget::setLabels ( const std::vector< std::string > &  labels)
◆ scalarsChanged
void pqScalarValueListPropertyWidget::scalarsChanged ( )
signal
Property Documentation
◆ scalars
readwrite
Definition at line 31 of file pqScalarValueListPropertyWidget.h.
