vtkSMTimeStepsDomain Class Reference
A domain providing timesteps from its "Input" property. More...
#include <vtkSMTimeStepsDomain.h>
Inheritance diagram for vtkSMTimeStepsDomain:
Collaboration diagram for vtkSMTimeStepsDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *prop) override
 Recovers timesteps from a required property "Input" and store them into the internal Values. More...
const std::vector< double > & GetValues ()
 Returns the vector of values containing the timesteps after Update. More...
double GetValue (unsigned int i)
 Returns the value at index from the timesteps after Update. More...
unsigned int GetNumberOfValues ()
 Returns the number of values containing the timesteps after Update. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMTimeStepsDomain * New ()
static vtkSMTimeStepsDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMTimeStepsDomain ()=default
 ~vtkSMTimeStepsDomain () override=default
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMTimeStepsDomain recovers input timesteps fromg its "Input" vtkSMInputProerty using vtkPVDataInformation API.
See also
vtkSMTimeStepIndexDomain
Definition at line 20 of file vtkSMTimeStepsDomain.h.
Definition at line 24 of file vtkSMTimeStepsDomain.h.
◆ vtkSMTimeStepsDomain()
vtkSMTimeStepsDomain::vtkSMTimeStepsDomain ( )
protecteddefault
◆ ~vtkSMTimeStepsDomain()
vtkSMTimeStepsDomain::~vtkSMTimeStepsDomain ( )
overrideprotecteddefault
static vtkSMTimeStepsDomain* vtkSMTimeStepsDomain::New ( )
virtual const char* vtkSMTimeStepsDomain::GetClassName ( )
static int vtkSMTimeStepsDomain::IsTypeOf ( const char *  type)
virtual int vtkSMTimeStepsDomain::IsA ( const char *  type)
static vtkSMTimeStepsDomain* vtkSMTimeStepsDomain::SafeDownCast ( vtkObject *  o)
◆ Update()
void vtkSMTimeStepsDomain::Update ( vtkSMProperty *  prop)
◆ GetValues()
const std::vector<double>& vtkSMTimeStepsDomain::GetValues ( )
inline
Definition at line 35 of file vtkSMTimeStepsDomain.h.
◆ GetValue()
double vtkSMTimeStepsDomain::GetValue ( unsigned int  i)
inline
Definition at line 40 of file vtkSMTimeStepsDomain.h.
◆ GetNumberOfValues()
unsigned int vtkSMTimeStepsDomain::GetNumberOfValues ( )
inline
Definition at line 45 of file vtkSMTimeStepsDomain.h.
