vtkSMDataAssemblyDomain Class Reference
a domain that uses vtkDataAssembly More...
#include <vtkSMDataAssemblyDomain.h>
Inheritance diagram for vtkSMDataAssemblyDomain:
Collaboration diagram for vtkSMDataAssemblyDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
const char * GetDataAssemblyName () const
 Returns the name for the chosen assembly, if any. More...
vtkDataAssembly * GetDataAssembly () const
 Provides access to the data assembly. More...
void Update (vtkSMProperty *requestingProperty) override
 Update self based on the "unchecked" values of all required properties. More...
int SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMDataAssemblyDomain * New ()
static vtkSMDataAssemblyDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMDataAssemblyDomain ()
 ~vtkSMDataAssemblyDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMDataAssemblyDomain is intended for vtkSMStringVectorProperty that uses vtkDataAssembly to qualify values. For example, the "Paths" property on vtkExtractBlockUsingDataAssembly filter that lets the user select paths to extract uses this domain.
Example usage in a ServerManager XML is as follows:
<SourceProxy ...>
<StringVectorProperty clean_command="ClearNodePaths"
command="AddNodePath"
name="Paths"
number_of_elements_per_command="1"
panel_visibility="default"
repeat_command="1"
animateable="0">
<DataAssemblyDomain name="data_assembly" (optional)entity_type=3>
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyDomain>
<Documentation>
This property lists the paths for blocks to extract.
</Documentation>
</StringVectorProperty>
</SourceProxy>
vtkSMDataAssemblyDomain can also be used on readers. In that case, it uses vtkPVDataAssemblyInformation to obtain the data assembly from the reader. The following snippet shows how this domain can be used on a reader. Note, the 'Tag' required property is essential to use this domain on a reader. It is used to determine when to fetch the vtkDataAssembly from the reader.
<SourceProxy ...>
<IntVectorProperty name="AssemblyTag"
command="GetAssemblyTag"
information_only="1">
<Documentation>
This is simply an int that changes whenever a new assembly is built
by the reader. This can be used to determine if the assembly should be fetched from
the reader whenever the reader is updated.
</Documentation>
</IntVectorProperty>
<StringVectorProperty name="AssemmblySelectors"
command="AddSelector"
clean_command="ClearSelectors"
repeat_command="1"
panel_widget="data_assembly_editor" >
<DataAssemblyDomain name="data_assembly">
<Property function="Tag" name="AssemblyTag" />
<Documentation>
Specify the selectors for the data assembly chosen using **Assembly**
to choose the blocks to extract from the input dataset.
</Documentation>
<Hints>
<!-- AssemblyTag == 0 implies there's no assembly in the file,
in which case, we want to hide this widget entirely -->
<PropertyWidgetDecorator type="GenericDecorator"
mode="visibility"
property="AssemblyTag"
value="0"
inverse="1" />
</Hints>
</SourceProxy>
Definition at line 96 of file vtkSMDataAssemblyDomain.h.
Definition at line 100 of file vtkSMDataAssemblyDomain.h.
◆ vtkSMDataAssemblyDomain()
vtkSMDataAssemblyDomain::vtkSMDataAssemblyDomain ( )
◆ ~vtkSMDataAssemblyDomain()
vtkSMDataAssemblyDomain::~vtkSMDataAssemblyDomain ( )
static vtkSMDataAssemblyDomain* vtkSMDataAssemblyDomain::New ( )
virtual const char* vtkSMDataAssemblyDomain::GetClassName ( )
static int vtkSMDataAssemblyDomain::IsTypeOf ( const char *  type)
virtual int vtkSMDataAssemblyDomain::IsA ( const char *  type)
static vtkSMDataAssemblyDomain* vtkSMDataAssemblyDomain::SafeDownCast ( vtkObject *  o)
void vtkSMDataAssemblyDomain::PrintSelf ( ostream &  os,
◆ GetDataAssemblyName()
const char* vtkSMDataAssemblyDomain::GetDataAssemblyName ( ) const
inline
Definition at line 106 of file vtkSMDataAssemblyDomain.h.
◆ GetDataAssembly()
vtkDataAssembly* vtkSMDataAssemblyDomain::GetDataAssembly ( ) const
◆ Update()
void vtkSMDataAssemblyDomain::Update ( vtkSMProperty *  requestingProperty)
Subclasses must override this method to update the domain based on the requestingProperty (and/or other required properties).
◆ SetDefaultValues()
int vtkSMDataAssemblyDomain::SetDefaultValues ( vtkSMProperty *  prop,
override
