vtkSMCompositeTreeDomain Class Reference
domain used to restrict an vtkSMIntVectorProperty values to valid flat-index for a vtkCompositeDataSet. More...
#include <vtkSMCompositeTreeDomain.h>
Inheritance diagram for vtkSMCompositeTreeDomain:
Collaboration diagram for vtkSMCompositeTreeDomain:
enum  {
  ALL = 0, LEAVES = 1, NON_LEAVES = 2, NONE = 3,
  AMR = 4
enum  DefaultModes { DEFAULT = 0, NONEMPTY_LEAF = 1 }
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *input) override
 Called when the 'required-property' is modified. More...
vtkDataAssembly * GetHierarchy () const
 Returns vtkDataAssembly representing the hierarchy. More...
int IsInDomain (vtkSMProperty *vtkNotUsed(property)) override
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 A vtkSMProperty is often defined with a default value in the XML itself. More...
virtual vtkPVDataInformation * GetInformation ()
 Get the vtkPVDataInformation which provides the tree structure for the composite dataset. More...
virtual int GetMode ()
 Mode indicates if the property is interested in all nodes, leaves only or non-leaves only. More...
virtual void SetMode (int)
virtual int GetDefaultMode ()
 DefaultMode controls how the default value for the property is set by SetDefaultValues(). More...
virtual void SetDefaultMode (int)
- Public Member Functions inherited from vtkSMDomain
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMCompositeTreeDomain * New ()
static vtkSMCompositeTreeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMCompositeTreeDomain ()
 ~vtkSMCompositeTreeDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void SetInformation (vtkPVDataInformation *)
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkPVDataInformation * Information
int Mode
int DefaultMode
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMCompositeTreeDomain should be considered deprecated. New code should no longer use this domain. Developers are encouraged to update filters to not rely on composite-index and instead use selectors to select blocks. See vtkSMDataAssemblyDomain.
vtkSMCompositeTreeDomain can be added to a vtkSMIntVectorProperty. This domain requires a vtkSMInputProperty which is used to provide the input to the filter. This domain obtains data information from the input selected on the required input property and then decides the range for values the property can have.
Broadly speaking, there are two ways of identifying unique node in a composite dataset: flat-index (also called composite-index) and level-block-index. flat-index applies to all types of composite datasets while level-block-index (or just level-index) applies only to AMR datasets. flat-index for any node in an arbitrary composite-dataset is simply the index of that node in a pre-order traversal of the tree with the root composite-dataset getting the index 0. level-index for an AMR dataset is the AMR level number while level-block-index is a pair of the AMR level number and block number for the node in that level.
The type of index the property expects, is defined by the domain's mode. Supported modes are:
  1. vtkSMCompositeTreeDomain::ALL: (default)
    The property uses flat-index and can accept index for any node (leaf or non-leaf). This can be specified in XML using the mode="all".
  2. vtkSMCompositeTreeDomain::LEAVES:
    The property uses flat-index however can only accept flat-indices for leaf-nodes. This can be specified in XML using the mode="leaves".
  3. vtkSMCompositeTreeDomain::AMR:
    The property uses level-index i.e. AMR level number or level-block-index. If the property has 2 elements (or for repeatable properties, if number of elements per command is 2) then level-block-index is used, otherwise simply the level-index is used. This only makes sense for filters dealing with AMR datasets. This can be specified in XML using the mode="amr".
  4. vtkSMCompositeTreeDomain::NON_LEAVES: (deprecated)
    No longer supported (as of ParaView 5.4) and simply interpreted as vtkSMCompositeTreeDomain::ALL. This used to be specified in XML using the mode="non-leaves".
vtkSMCompositeTreeDomain also provides ability to set default value on the property. If mode is LEAVES, then the default value selected is the first non-null leaf node. If mode is ALL, the same behaviour for default value is possible by using default_mode="nonempty-leaf" in XML. e.g.
<CompositeTreeDomain name="tree" mode="all" default_mode="nonempty-leaf">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</CompositeTreeDomain>
Definition at line 78 of file vtkSMCompositeTreeDomain.h.
Definition at line 82 of file vtkSMCompositeTreeDomain.h.
◆ anonymous enum
anonymous enum
Enumerator
ALL
LEAVES
NON_LEAVES
NONE
AMR
Definition at line 121 of file vtkSMCompositeTreeDomain.h.
◆ DefaultModes
Enumerator
DEFAULT
NONEMPTY_LEAF
Definition at line 130 of file vtkSMCompositeTreeDomain.h.
◆ vtkSMCompositeTreeDomain()
vtkSMCompositeTreeDomain::vtkSMCompositeTreeDomain ( )
◆ ~vtkSMCompositeTreeDomain()
vtkSMCompositeTreeDomain::~vtkSMCompositeTreeDomain ( )
static vtkSMCompositeTreeDomain* vtkSMCompositeTreeDomain::New ( )
virtual const char* vtkSMCompositeTreeDomain::GetClassName ( )
static int vtkSMCompositeTreeDomain::IsTypeOf ( const char *  type)
virtual int vtkSMCompositeTreeDomain::IsA ( const char *  type)
static vtkSMCompositeTreeDomain* vtkSMCompositeTreeDomain::SafeDownCast ( vtkObject *  o)
void vtkSMCompositeTreeDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMCompositeTreeDomain::Update ( vtkSMProperty *  input)
The property must be a vtkSMInputProperty. This will obtain the composite data information for the input source and then determine the valid range for the flat-index.
◆ GetInformation()
virtual vtkPVDataInformation* vtkSMCompositeTreeDomain::GetInformation ( )
◆ GetHierarchy()
vtkDataAssembly* vtkSMCompositeTreeDomain::GetHierarchy ( ) const
◆ IsInDomain()
int vtkSMCompositeTreeDomain::IsInDomain ( vtkSMProperty *  vtkNotUsedproperty)
inlineoverridevirtual
Definition at line 109 of file vtkSMCompositeTreeDomain.h.
◆ GetMode()
virtual int vtkSMCompositeTreeDomain::GetMode ( )
Can be configured in XML using the "mode" attribute. Values can be "all", "leaves", "non-leaves". Default is all nodes.
◆ SetMode()
virtual void vtkSMCompositeTreeDomain::SetMode ( int  )
◆ GetDefaultMode()
virtual int vtkSMCompositeTreeDomain::GetDefaultMode ( )
DEFAULT implies the default value is picked based on the default strategy for the selected Mode. NONEMPTY_LEAF indicates that the first non-empty leaf node is set as the default value, if possible.
◆ SetDefaultMode()
virtual void vtkSMCompositeTreeDomain::SetDefaultMode ( int  )
◆ SetDefaultValues()
int vtkSMCompositeTreeDomain::SetDefaultValues ( vtkSMProperty *  ,
override
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property. Returns 1 if the domain updated the property.
◆ ReadXMLAttributes()
int vtkSMCompositeTreeDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  elem
overrideprotectedvirtual
◆ SetInformation()
void vtkSMCompositeTreeDomain::SetInformation ( vtkPVDataInformation *  )
◆ Information
vtkPVDataInformation* vtkSMCompositeTreeDomain::Information
Definition at line 166 of file vtkSMCompositeTreeDomain.h.
◆ Mode
int vtkSMCompositeTreeDomain::Mode
Definition at line 167 of file vtkSMCompositeTreeDomain.h.
◆ DefaultMode
int vtkSMCompositeTreeDomain::DefaultMode
Definition at line 168 of file vtkSMCompositeTreeDomain.h.
