pqPropertiesPanel.h
3  Program: ParaView
4  Module: pqPropertiesPanel.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqPropertiesPanel_h
33 #define pqPropertiesPanel_h
35 #include "pqComponentsModule.h"
36 #include "vtkLegacy.h" // for legacy macros
37 #include <QWidget>
38
40 class pqOutputPort;
41 class pqPipelineSource;
42 class pqPropertyWidget;
43 class pqProxy;
44 class pqView;
45 class vtkSMProperty;
46 class vtkSMProxy;
47
60 class PQCOMPONENTS_EXPORT pqPropertiesPanel : public QWidget
61 {
62  Q_OBJECT
63  Q_PROPERTY(int panelMode READ panelMode WRITE setPanelMode);
64  typedef QWidget Superclass;
65
66 public:
67  pqPropertiesPanel(QWidget* parent = 0);
68  ~pqPropertiesPanel() override;
69
73  static void setAutoApply(bool enabled);
74
78  static bool autoApply();
79
83  static void setAutoApplyDelay(int delay);
84
88  static int autoApplyDelay();
89
93  pqView* view() const;
94
99  static int suggestedMargin() { return 0; }
100  static QMargins suggestedMargins() { return QMargins(0, 0, 0, 0); }
101  static int suggestedHorizontalSpacing() { return 4; }
102  static int suggestedVerticalSpacing() { return 4; }
103
104  enum
105  {
106  SOURCE_PROPERTIES = 0x01,
107  DISPLAY_PROPERTIES = 0x02,
108  VIEW_PROPERTIES = 0x04,
109  ALL_PROPERTIES = SOURCE_PROPERTIES | DISPLAY_PROPERTIES | VIEW_PROPERTIES
110  };
111
115  void setPanelMode(int val);
116  int panelMode() const { return this->PanelMode; }
117
123  VTK_LEGACY(void updatePanel(pqOutputPort* port));
124
128  bool canApply();
129
133  bool canReset();
134
141  VTK_LEGACY(void setOutputPort(pqOutputPort*));
142
143 public Q_SLOTS:
150  void apply();
151
158  void reset();
159
166  void showHelp();
167
174  void propertiesRestoreDefaults();
175
182  void propertiesSaveAsDefaults();
183
190  void displayRestoreDefaults();
191
198  void displaySaveAsDefaults();
199
206  void viewRestoreDefaults();
207
214  void viewSaveAsDefaults();
215
221  void setView(pqView*);
222
228  void setPipelineProxy(pqProxy*);
229
235  void setRepresentation(pqDataRepresentation*);
236 Q_SIGNALS:
240  void applied();
241
245  void applied(pqProxy*);
246
250  void viewChanged(pqView*);
251
255  void helpRequested(const QString& groupname, const QString& proxyType);
256
260  void deleteRequested(pqProxy* source);
261
267  void applyEnableStateChanged();
268
269 private Q_SLOTS:
275  void deleteProxy();
276
280  void proxyDeleted(pqProxy*);
281
286  void updatePanel();
287
291  void updateDisplayPanel();
292
296  void renderActiveView();
297
301  void sourcePropertyChanged(bool change_finished = true);
302  void sourcePropertyChangeAvailable() { this->sourcePropertyChanged(false); }
303
307  void updateButtonState();
308
313  void updateButtonEnableState();
314
319  void generalSettingsChanged();
320
321  void copyProperties();
322  void pasteProperties();
323  void copyDisplay();
324  void pasteDisplay();
325  void copyView();
326  void pasteView();
327
328 protected:
329  void updatePropertiesPanel(pqProxy* source);
330  void updateDisplayPanel(pqDataRepresentation* repr);
331  void updateViewPanel(pqView* view);
332
333 private:
334  static bool AutoApply;
335  static int AutoApplyDelay;
336
337  class pqInternals;
338  friend class pqInternals;
339
340  pqInternals* Internals;
341  int PanelMode;
342
343  Q_DISABLE_COPY(pqPropertiesPanel)
344 };
345
346 #endif
pqDataRepresentation is the superclass for a display for a pqPipelineSource i.e.
pqOutputPort is a server manager model item for an output port of any pqPipelineSource item...
Definition: pqOutputPort.h:58
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
methods used to obtain the recommended spacing and margins to be used for widgets.
#define VTK_LEGACY(method)
Definition: vtkLegacy.h:52
pqPropertiesPanel is the default panel used by paraview to edit source properties and display propert...
This is a PQ abstraction of a generic view module.
Definition: pqView.h:54
source
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:56
Definition: vtkSMProxy.h:152
PQ representation for a vtkSMProxy that can be involved in a pipeline.
port
