pqProxy.h
3  Program: ParaView
4  Module: pqProxy.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32
39 #ifndef _pqPipelineObject_h
40 #define _pqPipelineObject_h
41
43 #include <QPointer>
45 class pqProxyInternal;
46 class pqServer;
47 class vtkPVXMLElement;
48 class vtkSMProxy;
50
56 class PQCORE_EXPORT pqProxy : public pqServerManagerModelItem
57 {
58  Q_OBJECT
59 public:
64  {
67  UNMODIFIED
68  };
69
70  pqProxy(const QString& group, const QString& name, vtkSMProxy* proxy, pqServer* server,
71  QObject* parent = NULL);
72  ~pqProxy() override;
73
77  pqServer* getServer() const;
78
86  void rename(const QString& newname);
87
94  const QString& getSMName();
95  const QString& getSMGroup();
96
102  vtkSMProxy* getProxy() const;
103
110  ModifiedState modifiedState() const { return this->Modified; }
111
117  void setModifiedState(ModifiedState modified);
118
123  vtkPVXMLElement* getHints() const;
124
128  QList<vtkSMProxy*> getHelperProxies() const;
129
133  QList<vtkSMProxy*> getHelperProxies(const QString& key) const;
134
138  QList<QString> getHelperKeys() const;
139
141
144  static std::string rstToHtml(const char* rstStr);
145  static QString rstToHtml(const QString& rstStr);
147
158  virtual void addHelperProxy(const QString& key, vtkSMProxy*);
159  void removeHelperProxy(const QString& key, vtkSMProxy*);
160
166  void updateHelperProxies() const;
167
171  vtkSMSessionProxyManager* proxyManager() const;
172
178  static pqProxy* findProxyWithHelper(vtkSMProxy* aproxy, QString& key);
179
189  bool userModifiedSMName() { return this->UserModifiedSMName; }
190
191 Q_SIGNALS:
195  void nameChanged(pqServerManagerModelItem*);
196
200  void modifiedStateChanged(pqServerManagerModelItem*);
201
202 protected:
203  friend class pqServerManagerModel;
204
214  void setSMName(const QString& new_name);
215
216  // Use this method to initialize the pqObject state using the
217  // underlying vtkSMProxy. This needs to be done only once,
218  // after the object has been created.
219  virtual void initialize();
220
221  // Method used to update the internal structure without affecting
222  // the ProxyManager proxy registration
223  virtual void addInternalHelperProxy(const QString& key, vtkSMProxy*) const;
224  virtual void removeInternalHelperProxy(const QString& key, vtkSMProxy*) const;
225
226 protected Q_SLOTS:
227  // Used to monitor helper proxy registration when created on other clients
228  void onProxyRegistered(const QString&, const QString&, vtkSMProxy*);
229  void onProxyUnRegistered(const QString&, const QString&, vtkSMProxy*);
230
231 private:
232  QPointer<pqServer> Server;
233  QString SMName;
234  QString SMGroup;
235  pqProxyInternal* Internal;
236  ModifiedState Modified;
237  bool UserModifiedSMName;
238 };
239
240 #endif
Return whether or not the user has modified the GUI name of the source.
Definition: pqProxy.h:189
ModifiedState
The modification state of this proxy.
Definition: pqProxy.h:63
pqServerManagerModelItem is a element maintained by pqServerManagerModel.
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
virtual void onProxyUnRegistered(const QString &group, const QString &name, vtkSMProxy *proxy)
Called when a proxy is unregistered.
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:56
pqServerManagerModel is the model for the Server Manager.
Definition: vtkSMProxy.h:152
virtual void onProxyRegistered(const QString &group, const QString &name, vtkSMProxy *proxy)
Called when a proxy is registered.
Gets whether or not the source has been modified.
Definition: pqProxy.h:110
key
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
