controller for extract generation More...
#include <vtkSMExtractsController.h>
| const char * | GetRealExtractsOutputDirectory () const |
| Returns the extract output directory to use. More... | |
| bool | Extract (vtkSMProxy *extractor) |
| Generate the extract for the current state. More... | |
| bool | Extract (vtkSMSessionProxyManager *pxm) |
| bool | Extract () |
| bool | Extract (vtkCollection *collection) |
| Generate extract s for the current state using only the extractors in the collection. More... | |
| bool | IsTriggerActivated (vtkSMProxy *extractor) |
Same as IsAnyTriggerActivated except only check the selected extractor's trigger definition. More... | |
| std::vector< vtkSMProxy * > | FindExtractors (vtkSMProxy *proxy) const |
| Returns a list of extractors associated with the proxy. More... | |
| std::vector< vtkSMProxy * > | GetSupportedExtractorPrototypes (vtkSMProxy *proxy) const |
Returns a list of prototype proxies for extractors that can be attached to the given proxy. More... | |
| bool | CanExtract (vtkSMProxy *extractor, const std::vector< vtkSMProxy *> &inputs) const |
| Returns true is the given extractor (or prototype of the same) can extract the selected set of proxies at the same time. More... | |
| bool | CanExtract (vtkSMProxy *extractor, vtkSMProxy *input) const |
| vtkSMProxy * | GetInputForExtractor (vtkSMProxy *extractor) const |
| Given an extractor proxy, returns the producer for the extractor, if any. More... | |
| vtkTable * | GetSummaryTable () const |
| Get access to the summary table generated so far. More... | |
| void | ResetSummaryTable () |
| Reset summary table. More... | |
| bool | SaveSummaryTable (const std::string &fname, vtkSMSessionProxyManager *pxm) |
| Saves summary table to a file. More... | |
| virtual void | SetTimeStep (int) |
| Information about current time/timestep. More... | |
| virtual int | GetTimeStep () |
| virtual void | SetTime (double) |
| virtual double | GetTime () |
| virtual void | SetExtractsOutputDirectory (const char *) |
| Get/Set the root directory to use for writing extracts. More... | |
| virtual char * | GetExtractsOutputDirectory () |
| bool | IsAnyTriggerActivated (vtkSMSessionProxyManager *pxm) |
| Check if any of the extractors registered with the chosen proxy-manager (or active proxy-manager, is none specified) has their trigger activated given the current state of the application and the values for Time and TimeStep set on the controller. More... | |
| bool | IsAnyTriggerActivated () |
| bool | IsAnyTriggerActivated (vtkCollection *collection) |
| vtkSMProxy * | CreateExtractor (vtkSMProxy *proxy, const char *xmlname, const char *registrationName=nullptr) const |
| Creates, initializes and registers a new extractor of the chosen type. More... | |
| static vtkSMExtractsController * | New () |
| static vtkSMExtractsController * | SafeDownCast (vtkObject *o) |
| static bool | IsExtractor (vtkSMProxy *extractor, vtkSMProxy *proxy) |
Returns true is the extractor is an extractor for the proxy. More... | |
| static bool | IsExtractorEnabled (vtkSMProxy *extractor) |
| Returns true of the extractor is enabled. More... | |
| static void | SetExtractorEnabled (vtkSMProxy *extractor, bool val) |
| Enable/disable an extractor. More... | |
| vtkSMExtractsController () | |
| ~vtkSMExtractsController () | |
| std::string | GetName (vtkSMExtractWriterProxy *writer) |
| Returns a friendly name derived from the extract writer. More... | |
| bool | CreateExtractsOutputDirectory (vtkSMSessionProxyManager *pxm) const |
| These methods are intended to be use by vtkSMExtractWriterProxy and subclasses to ensure chosen output directories are created before attempting to generate extracts. More... | |
| bool | CreateDirectory (const std::string &dname, vtkSMSessionProxyManager *pxm) const |
| using | SummaryParametersT = std::map< std::string, std::string > |
| Called by vtkSMExtractWriterProxy subclasses to add an entry to the summary table. More... | |
| bool | AddSummaryEntry (vtkSMExtractWriterProxy *writer, const std::string &filename, const SummaryParametersT ¶ms=SummaryParametersT{}) |
vtkSMExtractsController is a controllers that provides API to handle various aspects of extractors and extract generation mechanisms supported by ParaView.
It provides API to query, create extractors of known types. It also provides API to generate extracts using the defined extractors.
vtkSMExtractsController generates a summary table for all extracts generated. Each row in this summary table corresponds to an extract generated. Each column provides information about that extract. Filename for the extract is stored in a column named FILE_[type] where [type] is replaced by the extension of the file. Other columns are used to stored named values that characterize the extract.
Currently, this summary table is used to generated a Cinema specification which can be used to explore the generated extracts using Cinema tools (https://cinemascience.github.io/).
Definition at line 57 of file vtkSMExtractsController.h.
Definition at line 61 of file vtkSMExtractsController.h.
| using vtkSMExtractsController::SummaryParametersT = std::map<std::string, std::string> |
Note, this must be called for every extract written out by the extract writer.
Definition at line 215 of file vtkSMExtractsController.h.
This must be set correctly before using Extract to generate extracts.
PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY. If set, the value specified here ignored and the environment variable is used instead.
PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY. If set, the value specified here ignored and the environment variable is used instead. | const char* vtkSMExtractsController::GetRealExtractsOutputDirectory | ( | ) | const |
If PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY is not set, this will be same as GetExtractsOutputDirectory else this will be the value of the PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY environment variable.
| bool vtkSMExtractsController::Extract | ( | vtkSMProxy * | extractor | ) |
Returns true if extract was generated, false if skipped or failed.
This overload generates extract from the specific extractor.
| bool vtkSMExtractsController::Extract | ( | vtkSMSessionProxyManager * | pxm | ) |
This overload generates extracts from all extractors registered with the proxy-manager.
| bool vtkSMExtractsController::Extract | ( | ) |
This overload locates the active session and then simply calls Extract(vtkSMSessionProxyManager*).
| bool vtkSMExtractsController::Extract | ( | vtkCollection * | collection | ) |
| bool vtkSMExtractsController::IsAnyTriggerActivated | ( | vtkSMSessionProxyManager * | pxm | ) |
| bool vtkSMExtractsController::IsAnyTriggerActivated | ( | ) |
| bool vtkSMExtractsController::IsAnyTriggerActivated | ( | vtkCollection * | collection | ) |
| bool vtkSMExtractsController::IsTriggerActivated | ( | vtkSMProxy * | extractor | ) |
| std::vector<vtkSMProxy*> vtkSMExtractsController::FindExtractors | ( | vtkSMProxy * | proxy | ) | const |
| std::vector<vtkSMProxy*> vtkSMExtractsController::GetSupportedExtractorPrototypes | ( | vtkSMProxy * | proxy | ) | const |
| bool vtkSMExtractsController::CanExtract | ( | vtkSMProxy * | extractor, |
| const std::vector< vtkSMProxy *> & | inputs | ||
| ) | const |
Definition at line 163 of file vtkSMExtractsController.h.
| vtkSMProxy* vtkSMExtractsController::CreateExtractor | ( | vtkSMProxy * | proxy, |
| const char * | xmlname, | ||
| const char * | registrationName = nullptr |
| ) | const |
| vtkSMProxy* vtkSMExtractsController::GetInputForExtractor | ( | vtkSMProxy * | extractor | ) | const |
May return a vtkSMViewProxy or a vtkSMOutputPort.
| vtkTable* vtkSMExtractsController::GetSummaryTable | ( | ) | const |
This will be nullptr until the first extract is generated.
See Summary of generated extracts for information about summary table.
| void vtkSMExtractsController::ResetSummaryTable | ( | ) |
Generally not needed since there is not much use for reusing vtkSMExtractsController, one should just create a new one when needed.
| bool vtkSMExtractsController::SaveSummaryTable | ( | const std::string & | fname, |
| vtkSMSessionProxyManager * | pxm | ||
Path is relative to the ExtractsOutputDirectory.
| bool vtkSMExtractsController::AddSummaryEntry | ( | vtkSMExtractWriterProxy * | writer, |
| const std::string & | filename, | ||
| const SummaryParametersT & | params = SummaryParametersT{} |
Return true on success, or false to failed to create writeable directories. Extract writers should not attempt to write any extracts when that happens.
