pqProxySelectionWidget.h
3  Program: ParaView
4  Module: pqProxySelectionWidget.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef pqProxySelectionWidget_h
33 #define pqProxySelectionWidget_h
35 #include "pqComponentsModule.h"
36 #include "pqPropertyWidget.h"
37 #include "pqSMProxy.h"
38 #include <QScopedPointer>
40 class vtkSMProxy;
41 class vtkSMProperty;
42 class pqView;
43
49 class PQCOMPONENTS_EXPORT pqProxySelectionWidget : public pqPropertyWidget
50 {
51  Q_OBJECT
52  typedef pqPropertyWidget Superclass;
53  Q_PROPERTY(pqSMProxy chosenProxy READ chosenProxy WRITE setChosenProxy)
54
55 public:
60  pqProxySelectionWidget(vtkSMProperty* property, vtkSMProxy* proxy, QWidget* parent = 0);
61  ~pqProxySelectionWidget() override;
62
66  vtkSMProxy* chosenProxy() const;
67  void setChosenProxy(vtkSMProxy* proxy);
68
73  void apply() override;
74  void reset() override;
75  void select() override;
76  void deselect() override;
77  void updateWidget(bool showing_advanced_properties) override;
78  void setPanelVisibility(const char* vis) override;
79  void setView(pqView*) override;
80
81 Q_SIGNALS:
85  void chosenProxyChanged();
86
87 private Q_SLOTS:
93  void currentIndexChanged(int);
94
95 private:
96  class pqInternal;
97  const QScopedPointer<pqInternal> Internal;
98
99  Q_DISABLE_COPY(pqProxySelectionWidget)
100 };
101
102 #endif
virtual void setPanelVisibility(const char *vis)
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
virtual void updateWidget(bool showing_advanced_properties)
pqPropertyWidget that can be used for any proxy with a vtkSMProxyListDomain.
virtual void deselect()
virtual void select()
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive.
This is a PQ abstraction of a generic view module.
Definition: pqView.h:54
virtual void reset()
virtual void setView(pqView *)
called to set the active view.
Definition: vtkSMProxy.h:152
virtual void apply()
