| | pqFontPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) |
| | ~pqFontPropertyWidget () override |
| QString | justification () const |
| | pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=0) |
| vtkSMPropertyGroup * | propertyGroup () const |
| void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
| char * | panelVisibility () const override |
| | Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
| void | setPanelVisibility (const char *vis) override |
| | pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) |
| | ~pqPropertyWidget () override |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| | These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
| pqView * | view () const |
| | Determines if the PropertyWidget must be constructed using a single row. More...
| bool | showLabel () const |
| | Provides access to the decorators for this widget. More...
| void | setJustification (QString &) |
| void | setupJustificationButton () |
pqFontPropertyWidget is a pqPropertyWidget that can be used to set properties relating to fonts.
The widget expects the property-group to have properties with functions set to "Color", "Opacity", "Family", "Size", "Bold", "Italics" and "Shadow". If any property is missing, the corresponding widget will be hidden.
Definition at line 47 of file pqFontPropertyWidget.h.
