A widget with a tied slider and line edit for editing a double property.
#include <pqDoubleSliderWidget.h>
Definition at line 28 of file pqDoubleSliderWidget.h.
◆ pqDoubleSliderWidget()
| pqDoubleSliderWidget::pqDoubleSliderWidget |
QWidget * |
parent = NULL | ) |
◆ ~pqDoubleSliderWidget()
| pqDoubleSliderWidget::~pqDoubleSliderWidget |
◆ value()
| double pqDoubleSliderWidget::value |
const |
◆ notation()
Return the notation used to display the number.
- See also
- setNotation()
◆ precision()
| int pqDoubleSliderWidget::precision |
const |
Return the precision used to display the number.
- See also
- setPrecision()
◆ useGlobalPrecisionAndNotation()
| bool pqDoubleSliderWidget::useGlobalPrecisionAndNotation |
const |
useGlobalPrecisionAndNotation indicates if the pqDoubleLineEdit used by this widget should use global precision and notation values instead of the parameters specified on this instance.
◆ valueChanged
| void pqDoubleSliderWidget::valueChanged |
double |
signal |
◆ valueEdited
| void pqDoubleSliderWidget::valueEdited |
double |
signal |
signal the value was edited this means the user is done changing text or the user is done moving the slider.
It implies value was changed and editing has finished.
◆ setValue
| void pqDoubleSliderWidget::setValue |
double |
val | ) |
slot |
◆ setNotation
Set the notation used to display the number.
- See also
- notation()
◆ setPrecision
| void pqDoubleSliderWidget::setPrecision |
int |
precision | ) |
slot |
Set the precision used to display the number.
- See also
- precision()
◆ setUseGlobalPrecisionAndNotation
| void pqDoubleSliderWidget::setUseGlobalPrecisionAndNotation |
bool |
value | ) |
slot |
◆ valueToSliderPos()
| virtual int pqDoubleSliderWidget::valueToSliderPos |
double |
val | ) |
protectedvirtual |
◆ sliderPosToValue()
| virtual double pqDoubleSliderWidget::sliderPosToValue |
int |
pos | ) |
protectedvirtual |
◆ setValidator()
| void pqDoubleSliderWidget::setValidator |
QDoubleValidator * |
validator | ) |
◆ validator()
| const QDoubleValidator* pqDoubleSliderWidget::validator |
const |
◆ setSliderRange()
| void pqDoubleSliderWidget::setSliderRange |
int |
min, |
int |
max |
◆ updateSlider()
| void pqDoubleSliderWidget::updateSlider |
◆ value
readwrite |
◆ notation
◆ precision
readwrite |
readwrite |
