Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Friends | List of all members
vtkSMColorMapEditorHelper Class Reference
helper for color map editor handling More...
#include <vtkSMColorMapEditorHelper.h>
Inheritance diagram for vtkSMColorMapEditorHelper:
Collaboration diagram for vtkSMColorMapEditorHelper:
enum  SelectedPropertiesTypes { Representation = 0, Blocks = 1 }
enum  BlockPropertyState : std::uint8_t {
  Disabled = 0x0, RepresentationInherited = 0x1, BlockInherited = 0x2, MixedInherited = 0x3,
  Set = 0x4, SetAndRepresentationInherited = 0x5, SetAndBlockInherited = 0x6, SetAndMixedInherited = 0x7,
  NumberOfStates = 0x8
using Color = std::array< double, 3 >
using ColorArray = std::pair< int, std::string >
virtual void SetSelectedPropertiesType (int)
 Set/Get the selected properties type. More...
void SetSelectedPropertiesTypeToRepresentation ()
void SetSelectedPropertiesTypeToBlocks ()
virtual int GetSelectedPropertiesType ()
static vtkSMColorMapEditorHelper * New ()
static vtkSMColorMapEditorHelper * SafeDownCast (vtkObject *o)
static SelectedPropertiesTypes GetPropertyType (vtkSMProperty *property)
 Determine if a property is a block property. More...
static std::vector< std::string > GetSelectedBlockSelectors (vtkSMProxy *proxy)
 Returns the selected block selectors for this representation. More...
static std::vector< std::string > GetColorArraysBlockSelectors (vtkSMProxy *proxy)
 Returns the selectors that use a color array for this representation. More...
static std::pair< std::string, BlockPropertyState > HasBlockProperty (vtkSMProxy *proxy, const std::string &blockSelector, const std::string &propertyName)
 Determine if a propert(y/ies) of a selector(s) is set, inherited from a block, or from the representation, or mixed. More...
static std::pair< std::string, BlockPropertyState > GetBlockPropertyStateFromBlockPropertyStates (const std::vector< std::pair< std::string, BlockPropertyState >> &states)
static std::pair< std::string, BlockPropertyState > HasBlockProperty (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::string &propertyName)
static std::pair< std::string, BlockPropertyState > HasBlockProperties (vtkSMProxy *proxy, const std::string &blockSelector, const std::vector< std::string > &propertyNames)
static std::pair< std::string, BlockPropertyState > HasBlocksProperties (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::vector< std::string > &propertyNames)
static void SetupLookupTable (vtkSMProxy *proxy)
 Given the input registered representation proxy, sets up a lookup table associated with the representation if a scalar bar is being used for proxy. More...
static void SetupBlocksLookupTables (vtkSMProxy *proxy)
static bool UpdateScalarBarRange (vtkSMProxy *proxy, vtkSMProxy *view, bool deleteRange)
 Updates the ranges shown in the scalar bar. More...
static std::vector< vtkTypeBool > UpdateBlocksScalarBarRange (vtkSMProxy *proxy, vtkSMProxy *view, bool deleteRange)
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view)
 Rescales the color transfer function and the opacity transfer function using the current data range, limited to the current visible elements. More...
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view, const char *arrayName, int attributeType)
static bool HideScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view)
 While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
static bool HideBlocksScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view)
static bool IsScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view)
 Check scalar bar visibility. More...
static bool IsBlockScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view, const std::string &blockSelector)
static std::vector< vtkTypeBool > IsBlocksScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
static vtkPVArrayInformation * GetArrayInformationForColorArray (vtkSMProxy *proxy, bool checkRepresentedData=true)
 Returns the array information for the data array used for scalar coloring, from input data. More...
static vtkPVArrayInformation * GetBlockArrayInformationForColorArray (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< vtkPVArrayInformation * > GetBlocksArrayInformationForColorArray (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static std::string GetDecoratedArrayName (vtkSMProxy *proxy, const std::string &arrayName)
 In case of UseSeparateColorMap enabled, this function prefix the given arrayName with unique identifier, otherwise it acts as a passthrough. More...
static std::string GetBlockDecoratedArrayName (vtkSMProxy *proxy, const std::string &blockSelector, const std::string &arrayName)
static std::vector< std::string > GetBlocksDecoratedArrayNames (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::string &arrayName)
static vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (vtkSMProxy *proxy, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
static vtkPVProminentValuesInformation * GetBlockProminentValuesInformationForColorArray (vtkSMProxy *proxy, const std::string &blockSelector, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
static std::vector< vtkPVProminentValuesInformation * > GetBlocksProminentValuesInformationForColorArray (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
static int IsScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view)
 Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
static int IsBlockScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector)
static std::vector< int > IsBlocksScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
static void ResetBlockProperty (vtkSMProxy *proxy, const std::string &blockSelector, const std::string &propertyName)
 Reset a block property. More...
static void RemoveBlockProperties (vtkSMProxy *proxy, const std::string &blockSelector, const std::vector< std::string > &propertyNames)
static void ResetBlocksProperty (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::string &propertyName)
static void ResetBlocksProperties (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::vector< std::string > &propertyNames)
 vtkSMColorMapEditorHelper ()
 ~vtkSMColorMapEditorHelper () override
std::vector< vtkTypeBool > SetSelectedScalarColoringInternal (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool useComponent, int component)
static bool SetScalarColoringInternal (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool useComponent, int component)
 Internal method to set scalar coloring, do not use directly. More...
static std::vector< vtkTypeBool > SetBlocksScalarColoringInternal (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, bool useComponent, int component)
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, vtkPVArrayInformation *info, bool extend=false, bool force=true)
 Rescales transfer function ranges using the array information provided. More...
static bool RescaleBlockTransferFunctionToDataRange (vtkSMProxy *proxy, const std::string &blockSelector, vtkPVArrayInformation *info, bool extend=false, bool force=true)
static std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRange (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, std::vector< vtkPVArrayInformation *> infos, bool extend=false, bool force=true)
static void SetColorArray (vtkSMProxy *proxy, int attributeType, std::string arrayName)
 Set the color array name. More...
static void SetBlockColorArray (vtkSMProxy *proxy, const std::string &blockSelector, int attributeType, std::string arrayName)
static void SetBlocksColorArray (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, int attributeType, std::string arrayName)
static void RemoveBlockColorArray (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksColorArrays (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static ColorArray GetColorArray (vtkSMProxy *proxy)
static ColorArray GetBlockColorArray (vtkSMProxy *proxy, const std::string &blockSelector)
static void SetBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector, vtkSMProxy *lutProxy)
 Set the block lookup table proxy. More...
static void SetBlocksLookupTable (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, vtkSMProxy *lutProxy)
static void RemoveBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksLookupTables (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static vtkSMProxy * GetLastLookupTable (vtkSMProxy *proxy)
 Used as a memory of what was the last LUT proxy linked to this representation. More...
static void SetLastLookupTable (vtkSMProxy *proxy, vtkSMProxy *lutProxy)
static vtkSMProxy * GetLastBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< vtkSMProxy * > GetLastBlocksLookupTables (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static void SetLastBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector, vtkSMProxy *lutProxy)
static void SetLastBlocksLookupTable (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, vtkSMProxy *lutProxy)
Friends
class vtkSMPVRepresentationProxy
static vtkSMProxy * GetLUTProxy (vtkSMProxy *proxy, vtkSMProxy *view)
 Returns the lut proxy of this representation in the given view. More...
static vtkSMProxy * GetLookupTable (vtkSMProxy *proxy)
static vtkSMProxy * GetLookupTable (vtkSMProxy *proxy, vtkSMProxy *view)
static vtkSMProxy * GetBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< vtkSMProxy * > GetBlocksLookupTables (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static vtkSMProxy * GetBlockLookupTable (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector)
static std::vector< vtkSMProxy * > GetBlocksLookupTables (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
std::vector< vtkSMProxy * > GetSelectedLookupTables (vtkSMProxy *proxy)
std::vector< vtkSMProxy * > GetSelectedLookupTables (vtkSMProxy *proxy, vtkSMProxy *view)
static bool GetUsingScalarColoring (vtkSMProxy *proxy)
 Returns true if scalar coloring is enabled. More...
static bool GetBlockUsingScalarColoring (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< vtkTypeBool > GetBlocksUsingScalarColoring (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static bool GetAnyBlockUsingScalarColoring (vtkSMProxy *proxy)
std::vector< vtkTypeBool > GetSelectedUsingScalarColorings (vtkSMProxy *proxy)
bool GetAnySelectedUsingScalarColoring (vtkSMProxy *proxy)
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType)
 Enable/disable scalar coloring using the specified array. More...
static bool SetBlockScalarColoring (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType)
static std::vector< vtkTypeBool > SetBlocksScalarColoring (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType)
std::vector< vtkTypeBool > SetSelectedScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType)
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType, int component)
static bool SetBlockScalarColoring (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType, int component)
static std::vector< vtkTypeBool > SetBlocksScalarColoring (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, int component)
std::vector< vtkTypeBool > SetSelectedScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType, int component)
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range. More...
static bool RescaleBlockTransferFunctionToDataRange (vtkSMProxy *proxy, const std::string &blockSelector, bool extend=false, bool force=true)
static std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRange (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool extend=false, bool force=true)
std::vector< vtkTypeBool > RescaleSelectedTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true)
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
static bool RescaleBlockTransferFunctionToDataRange (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType, bool extend=false, bool force=true)
static std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRange (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, bool extend=false, bool force=true)
std::vector< vtkTypeBool > RescaleSelectedTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool extend=false, bool force=true)
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy)
 Rescales the color transfer function and opacity transfer function using the current data range over time. More...
static bool RescaleBlockTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
std::vector< vtkTypeBool > RescaleSelectedTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy)
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayName, int attributeType)
 Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
static bool RescaleBlockTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType)
static std::vector< vtkTypeBool > RescaleBlocksTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType)
std::vector< vtkTypeBool > RescaleSelectedTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayName, int attributeType)
static bool SetScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible)
 Set the scalar bar visibility. More...
static bool SetBlockScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector, bool visible)
static std::vector< vtkTypeBool > SetBlocksScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors, bool visible)
std::vector< vtkTypeBool > SetSelectedScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible)
static int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view)
 Get an estimated number of annotation shown on this representation scalar bar. More...
static int GetBlockEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector)
static std::vector< int > GetBlocksEstimatedNumberOfAnnotationsOnScalarBars (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors)
std::vector< int > GetSelectedEstimatedNumberOfAnnotationsOnScalarBars (vtkSMProxy *proxy, vtkSMProxy *view)
int GetAnySelectedEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view)
static bool IsColorValid (Color color)
 Set/Get the color of the representation. More...
static void SetColor (vtkSMProxy *proxy, Color color)
static void SetBlockColor (vtkSMProxy *proxy, const std::string &blockSelector, Color color)
static void SetBlocksColor (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, Color color)
static void RemoveBlockColor (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksColors (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static Color GetColor (vtkSMProxy *proxy)
static Color GetBlockColor (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< Color > GetBlocksColors (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
void SetSelectedColor (vtkSMProxy *proxy, Color color)
std::vector< Color > GetSelectedColors (vtkSMProxy *proxy)
static vtkSMProperty * GetColorArrayProperty (vtkSMProxy *proxy)
 Get Color array property. More...
static vtkSMProperty * GetBlockColorArrayProperty (vtkSMProxy *proxy)
vtkSMProperty * GetSelectedColorArrayProperty (vtkSMProxy *proxy)
static bool IsColorArrayValid (const ColorArray &array)
 Get the color array name. More...
static std::vector< ColorArray > GetBlocksColorArrays (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static int GetBlockColorArrayAssociation (vtkSMProxy *proxy, const std::string &blockSelector)
static std::string GetBlockColorArrayName (vtkSMProxy *proxy, const std::string &blockSelector)
static std::map< ColorArray, std::vector< std::string > > GetCommonColorArraysBlockSelectors (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
std::vector< ColorArray > GetSelectedColorArrays (vtkSMProxy *proxy)
static vtkSMProperty * GetUseSeparateColorMapProperty (vtkSMProxy *proxy)
 Get use separate color map property. More...
static vtkSMProperty * GetBlockUseSeparateColorMapProperty (vtkSMProxy *proxy)
vtkSMProperty * GetSelectedUseSeparateColorMapProperty (vtkSMProxy *proxy)
static bool IsUseSeparateColorMapValid (int useSeparateColorMap)
 Set/Get if we should use a separate color map. More...
static void SetUseSeparateColorMap (vtkSMProxy *proxy, bool use)
static void SetBlockUseSeparateColorMap (vtkSMProxy *proxy, const std::string &blockSelector, bool use)
static void SetBlocksUseSeparateColorMap (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool use)
static void RemoveBlockUseSeparateColorMap (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksUseSeparateColorMaps (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static bool GetUseSeparateColorMap (vtkSMProxy *proxy)
static int GetBlockUseSeparateColorMap (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< int > GetBlocksUseSeparateColorMaps (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
void SetSelectedUseSeparateColorMap (vtkSMProxy *proxy, bool use)
std::vector< int > GetSelectedUseSeparateColorMaps (vtkSMProxy *proxy)
bool GetAnySelectedUseSeparateColorMap (vtkSMProxy *proxy)
static bool IsMapScalarsValid (int mapScalars)
 Set/Get the map scalars of the representation. More...
static void SetMapScalars (vtkSMProxy *proxy, bool mapScalars)
static void SetBlockMapScalars (vtkSMProxy *proxy, const std::string &blockSelector, bool mapScalars)
static void SetBlocksMapScalars (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool mapScalars)
static void RemoveBlockMapScalars (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksMapScalars (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static bool GetMapScalars (vtkSMProxy *proxy)
static int GetBlockMapScalars (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< int > GetBlocksMapScalars (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
void SetSelectedMapScalars (vtkSMProxy *proxy, bool mapScalars)
std::vector< int > GetSelectedMapScalars (vtkSMProxy *proxy)
bool GetAnySelectedMapScalars (vtkSMProxy *proxy)
static bool IsInterpolateScalarsBeforeMappingValid (int interpolate)
static void SetInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, bool interpolate)
static void SetBlockInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::string &blockSelector, bool interpolate)
static void SetBlocksInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool interpolate)
static void RemoveBlockInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksInterpolateScalarsBeforeMappings (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static bool GetInterpolateScalarsBeforeMapping (vtkSMProxy *proxy)
static int GetBlockInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< int > GetBlocksInterpolateScalarsBeforeMappings (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
void SetSelectedInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, bool interpolate)
std::vector< int > GetSelectedInterpolateScalarsBeforeMappings (vtkSMProxy *proxy)
bool GetAnySelectedInterpolateScalarsBeforeMapping (vtkSMProxy *proxy)
static bool IsOpacityValid (double opacity)
 Set/Get the opacity of the representation. More...
static void SetOpacity (vtkSMProxy *proxy, double opacity)
static void SetBlockOpacity (vtkSMProxy *proxy, const std::string &blockSelector, double opacity)
static void SetBlocksOpacity (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, double opacity)
static void RemoveBlockOpacity (vtkSMProxy *proxy, const std::string &blockSelector)
static void RemoveBlocksOpacities (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
static double GetOpacity (vtkSMProxy *proxy)
static double GetBlockOpacity (vtkSMProxy *proxy, const std::string &blockSelector)
static std::vector< double > GetBlocksOpacities (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors)
void SetSelectedOpacity (vtkSMProxy *proxy, double opacity)
std::vector< double > GetSelectedOpacities (vtkSMProxy *proxy)
It provides helper functions for controlling transfer functions, scalar coloring, etc. Scalar bar controlling is still working for RenderView only for now, as it's controlling the widget.
Definition at line 33 of file vtkSMColorMapEditorHelper.h.
Definition at line 37 of file vtkSMColorMapEditorHelper.h.
◆ Color
using vtkSMColorMapEditorHelper::Color = std::array<double, 3>
Definition at line 498 of file vtkSMColorMapEditorHelper.h.
◆ ColorArray
Definition at line 538 of file vtkSMColorMapEditorHelper.h.
◆ SelectedPropertiesTypes
Enumerator
Representation
Blocks
Definition at line 40 of file vtkSMColorMapEditorHelper.h.
◆ BlockPropertyState
Enumerator
Disabled
BlockInherited
MixedInherited
Set
NumberOfStates
Definition at line 46 of file vtkSMColorMapEditorHelper.h.
◆ vtkSMColorMapEditorHelper()
vtkSMColorMapEditorHelper::vtkSMColorMapEditorHelper ( )
◆ ~vtkSMColorMapEditorHelper()
vtkSMColorMapEditorHelper::~vtkSMColorMapEditorHelper ( )
static vtkSMColorMapEditorHelper* vtkSMColorMapEditorHelper::New ( )
virtual const char* vtkSMColorMapEditorHelper::GetClassName ( )
static int vtkSMColorMapEditorHelper::IsTypeOf ( const char *  type)
virtual int vtkSMColorMapEditorHelper::IsA ( const char *  type)
static vtkSMColorMapEditorHelper* vtkSMColorMapEditorHelper::SafeDownCast ( vtkObject *  o)
void vtkSMColorMapEditorHelper::PrintSelf ( ostream &  os,
◆ SetSelectedPropertiesType()
virtual void vtkSMColorMapEditorHelper::SetSelectedPropertiesType ( int  )
This variable is used in all instance functions with the Selected key-word in the name.
It decides whether to use a function that uses the representation's or blocks' properties.
Default is false.
◆ SetSelectedPropertiesTypeToRepresentation()
void vtkSMColorMapEditorHelper::SetSelectedPropertiesTypeToRepresentation ( )
inline
Default is false.
Definition at line 80 of file vtkSMColorMapEditorHelper.h.
◆ SetSelectedPropertiesTypeToBlocks()
void vtkSMColorMapEditorHelper::SetSelectedPropertiesTypeToBlocks ( )
inline
Default is false.
Definition at line 84 of file vtkSMColorMapEditorHelper.h.
◆ GetSelectedPropertiesType()
virtual int vtkSMColorMapEditorHelper::GetSelectedPropertiesType ( )
Default is false.
◆ GetPropertyType()
static SelectedPropertiesTypes vtkSMColorMapEditorHelper::GetPropertyType ( vtkSMProperty *  property)
◆ HasBlockProperty() [1/2]
static std::pair<std::string, BlockPropertyState> vtkSMColorMapEditorHelper::HasBlockProperty ( vtkSMProxy *  proxy,
const std::string &  blockSelector,
const std::string &  propertyName
if it's RepresentationInherited, the blockSelector will be empty. if it's BlockInherited, the blockSelector will be the inherited block. if it's MixedInherited, the blockSelector will be the inherited block. if it's Set, the block selector will be the block where the property is set. if it's SetAndRepresentationInherited, be the block where the property is set. if it's SetAndBlockInherited, be the block where the property is set. if it's SetAndMixedInherited, be the block where the property is set.
◆ GetBlockPropertyStateFromBlockPropertyStates()
static std::pair<std::string, BlockPropertyState> vtkSMColorMapEditorHelper::GetBlockPropertyStateFromBlockPropertyStates ( const std::vector< std::pair< std::string, BlockPropertyState >> &  states)
◆ HasBlockProperty() [2/2]
const std::vector< std::string > &  blockSelectors,
◆ HasBlockProperties()
static std::pair<std::string, BlockPropertyState> vtkSMColorMapEditorHelper::HasBlockProperties ( vtkSMProxy *  proxy,
const std::vector< std::string > &  propertyNames
◆ HasBlocksProperties()
static std::pair<std::string, BlockPropertyState> vtkSMColorMapEditorHelper::HasBlocksProperties ( vtkSMProxy *  proxy,
◆ GetSelectedBlockSelectors()
static std::vector<std::string> vtkSMColorMapEditorHelper::GetSelectedBlockSelectors ( vtkSMProxy *  proxy)
◆ GetColorArraysBlockSelectors()
static std::vector<std::string> vtkSMColorMapEditorHelper::GetColorArraysBlockSelectors ( vtkSMProxy *  proxy)
◆ GetLUTProxy()
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLUTProxy ( vtkSMProxy *  proxy,
vtkSMProxy *  view
inlinestatic
The methods with a view parameter will return nullptr if the view is not a render view.
Definition at line 138 of file vtkSMColorMapEditorHelper.h.
◆ GetLookupTable() [1/2]
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLookupTable ( vtkSMProxy *  proxy)
◆ GetLookupTable() [2/2]
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLookupTable ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ GetBlockLookupTable() [1/2]
static vtkSMProxy* vtkSMColorMapEditorHelper::GetBlockLookupTable ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 144 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksLookupTables() [1/2]
static std::vector<vtkSMProxy*> vtkSMColorMapEditorHelper::GetBlocksLookupTables ( vtkSMProxy *  proxy,
◆ GetBlockLookupTable() [2/2]
vtkSMProxy *  view,
inlinestatic
Definition at line 150 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksLookupTables() [2/2]
vtkSMProxy *  view,
◆ GetSelectedLookupTables() [1/2]
std::vector<vtkSMProxy*> vtkSMColorMapEditorHelper::GetSelectedLookupTables ( vtkSMProxy *  proxy)
◆ GetSelectedLookupTables() [2/2]
std::vector<vtkSMProxy*> vtkSMColorMapEditorHelper::GetSelectedLookupTables ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ GetUsingScalarColoring()
static bool vtkSMColorMapEditorHelper::GetUsingScalarColoring ( vtkSMProxy *  proxy)
This checks whether a property named "ColorArrayName" exists and has a non-empty string. This does not check for the validity of the array.
◆ GetBlockUsingScalarColoring()
static bool vtkSMColorMapEditorHelper::GetBlockUsingScalarColoring ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 168 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksUsingScalarColoring()
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::GetBlocksUsingScalarColoring ( vtkSMProxy *  proxy,
◆ GetAnyBlockUsingScalarColoring()
static bool vtkSMColorMapEditorHelper::GetAnyBlockUsingScalarColoring ( vtkSMProxy *  proxy)
◆ GetSelectedUsingScalarColorings()
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::GetSelectedUsingScalarColorings ( vtkSMProxy *  proxy)
◆ GetAnySelectedUsingScalarColoring()
bool vtkSMColorMapEditorHelper::GetAnySelectedUsingScalarColoring ( vtkSMProxy *  proxy)
◆ SetupLookupTable()
static void vtkSMColorMapEditorHelper::SetupLookupTable ( vtkSMProxy *  proxy)
◆ SetupBlocksLookupTables()
static void vtkSMColorMapEditorHelper::SetupBlocksLookupTables ( vtkSMProxy *  proxy)
◆ UpdateScalarBarRange()
static bool vtkSMColorMapEditorHelper::UpdateScalarBarRange ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  deleteRange
If deleteRange is true, then the range stored for current representation proxy is deleted. This should be done when the scalar bar gets separated or becomes not visible. If deleteRange is false, then the range stored for current representation proxy is updated with the new range value.
◆ UpdateBlocksScalarBarRange()
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::UpdateBlocksScalarBarRange ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  deleteRange
◆ SetScalarColoring() [1/2]
static bool vtkSMColorMapEditorHelper::SetScalarColoring ( vtkSMProxy *  proxy,
const char *  arrayName,
int  attributeType
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayName is nullptr, then scalar coloring is turned off. attributeType must be one of vtkDataObject::AttributeTypes.
◆ SetBlockScalarColoring() [1/2]
static bool vtkSMColorMapEditorHelper::SetBlockScalarColoring ( vtkSMProxy *  proxy,
int  attributeType
inlinestatic
Definition at line 210 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksScalarColoring() [1/2]
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetBlocksScalarColoring ( vtkSMProxy *  proxy,
int  attributeType
◆ SetSelectedScalarColoring() [1/2]
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetSelectedScalarColoring ( vtkSMProxy *  proxy,
int  attributeType
◆ SetScalarColoring() [2/2]
int  attributeType,
int  component
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayName is nullptr, then scalar coloring is turned off. attributeType must be one of vtkDataObject::AttributeTypes. component enables choosing a component to color with, -1 will change to Magnitude, >=0 will change to corresponding component.
◆ SetBlockScalarColoring() [2/2]
int  attributeType,
int  component
inlinestatic
Definition at line 234 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksScalarColoring() [2/2]
int  attributeType,
int  component
◆ SetSelectedScalarColoring() [2/2]
int  attributeType,
int  component
◆ RescaleTransferFunctionToDataRange() [1/3]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  extend = false,
bool  force = true
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force is false (true by default), then the transfer function range is not changed if locked.
◆ RescaleBlockTransferFunctionToDataRange() [1/3]
static bool vtkSMColorMapEditorHelper::RescaleBlockTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  force = true
inlinestatic
Definition at line 259 of file vtkSMColorMapEditorHelper.h.
◆ RescaleBlocksTransferFunctionToDataRange() [1/3]
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleBlocksTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  force = true
◆ RescaleSelectedTransferFunctionToDataRange() [1/2]
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleSelectedTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  force = true
◆ RescaleTransferFunctionToDataRange() [2/3]
int  attributeType,
bool  force = true
Returns true if rescale was successful. attributeType must be one of vtkDataObject::AttributeTypes. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force is false (true by default), then the transfer function range is not changed if locked.
◆ RescaleBlockTransferFunctionToDataRange() [2/3]
int  attributeType,
bool  force = true
inlinestatic
Definition at line 285 of file vtkSMColorMapEditorHelper.h.
◆ RescaleBlocksTransferFunctionToDataRange() [2/3]
int  attributeType,
bool  force = true
◆ RescaleSelectedTransferFunctionToDataRange() [2/2]
int  attributeType,
bool  force = true
◆ RescaleTransferFunctionToDataRangeOverTime() [1/2]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy)
◆ RescaleBlockTransferFunctionToDataRangeOverTime() [1/2]
static bool vtkSMColorMapEditorHelper::RescaleBlockTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 306 of file vtkSMColorMapEditorHelper.h.
◆ RescaleBlocksTransferFunctionToDataRangeOverTime() [1/2]
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleBlocksTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy,
◆ RescaleSelectedTransferFunctionToDataRangeOverTime() [1/2]
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleSelectedTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy)
◆ RescaleTransferFunctionToDataRangeOverTime() [2/2]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy,
int  attributeType
Returns true if rescale was successful. attributeType must be one of vtkDataObject::AttributeTypes,
◆ RescaleBlockTransferFunctionToDataRangeOverTime() [2/2]
int  attributeType
inlinestatic
Definition at line 327 of file vtkSMColorMapEditorHelper.h.
◆ RescaleBlocksTransferFunctionToDataRangeOverTime() [2/2]
int  attributeType
◆ RescaleSelectedTransferFunctionToDataRangeOverTime() [2/2]
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleSelectedTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy,
int  attributeType
◆ RescaleTransferFunctionToVisibleRange() [1/2]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ RescaleTransferFunctionToVisibleRange() [2/2]
vtkSMProxy *  view,
int  attributeType
◆ SetScalarBarVisibility()
static bool vtkSMColorMapEditorHelper::SetScalarBarVisibility ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  visible
This will create a new scalar bar as needed. Scalar bar is only shown if scalar coloring is indeed being used.
◆ SetBlockScalarBarVisibility()
static bool vtkSMColorMapEditorHelper::SetBlockScalarBarVisibility ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  visible
inlinestatic
Definition at line 357 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksScalarBarVisibility()
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetBlocksScalarBarVisibility ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  visible
◆ SetSelectedScalarBarVisibility()
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetSelectedScalarBarVisibility ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  visible
◆ HideScalarBarIfNotNeeded()
static bool vtkSMColorMapEditorHelper::HideScalarBarIfNotNeeded ( vtkSMProxy *  repr,
vtkSMProxy *  view
Use this method instead to only hide the scalar/color bar if no other visible representation in the view is mapping data using the scalar bar.
◆ HideBlocksScalarBarIfNotNeeded()
static bool vtkSMColorMapEditorHelper::HideBlocksScalarBarIfNotNeeded ( vtkSMProxy *  repr,
vtkSMProxy *  view
◆ IsScalarBarVisible()
static bool vtkSMColorMapEditorHelper::IsScalarBarVisible ( vtkSMProxy *  repr,
vtkSMProxy *  view
Return true if the scalar bar for this representation and view is visible, return false otherwise.
◆ IsBlockScalarBarVisible()
static bool vtkSMColorMapEditorHelper::IsBlockScalarBarVisible ( vtkSMProxy *  repr,
vtkSMProxy *  view,
inlinestatic
Definition at line 388 of file vtkSMColorMapEditorHelper.h.
◆ IsBlocksScalarBarVisible()
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::IsBlocksScalarBarVisible ( vtkSMProxy *  repr,
vtkSMProxy *  view,
◆ GetArrayInformationForColorArray()
static vtkPVArrayInformation* vtkSMColorMapEditorHelper::GetArrayInformationForColorArray ( vtkSMProxy *  proxy,
bool  checkRepresentedData = true
If checkRepresentedData is true, it will also check in the represented data. Default is true. If none is found, returns nullptr.
◆ GetBlockArrayInformationForColorArray()
static vtkPVArrayInformation* vtkSMColorMapEditorHelper::GetBlockArrayInformationForColorArray ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 406 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksArrayInformationForColorArray()
static std::vector<vtkPVArrayInformation*> vtkSMColorMapEditorHelper::GetBlocksArrayInformationForColorArray ( vtkSMProxy *  proxy,
◆ GetDecoratedArrayName()
static std::string vtkSMColorMapEditorHelper::GetDecoratedArrayName ( vtkSMProxy *  proxy,
const std::string &  arrayName
◆ GetBlockDecoratedArrayName()
static std::string vtkSMColorMapEditorHelper::GetBlockDecoratedArrayName ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 423 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksDecoratedArrayNames()
static std::vector<std::string> vtkSMColorMapEditorHelper::GetBlocksDecoratedArrayNames ( vtkSMProxy *  proxy,
◆ GetProminentValuesInformationForColorArray()
static vtkPVProminentValuesInformation* vtkSMColorMapEditorHelper::GetProminentValuesInformationForColorArray ( vtkSMProxy *  proxy,
double  uncertaintyAllowed = 1e-6,
double  fraction = 1e-3,
bool  force = false
Otherwise returns nullptr.
◆ GetBlockProminentValuesInformationForColorArray()
static vtkPVProminentValuesInformation* vtkSMColorMapEditorHelper::GetBlockProminentValuesInformationForColorArray ( vtkSMProxy *  proxy,
bool  force = false
inlinestatic
Definition at line 442 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksProminentValuesInformationForColorArray()
static std::vector<vtkPVProminentValuesInformation*> vtkSMColorMapEditorHelper::GetBlocksProminentValuesInformationForColorArray ( vtkSMProxy *  proxy,
bool  force = false
◆ GetEstimatedNumberOfAnnotationsOnScalarBar()
static int vtkSMColorMapEditorHelper::GetEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  proxy,
vtkSMProxy *  view
If the return value is -1, then the value is not set.
◆ GetBlockEstimatedNumberOfAnnotationsOnScalarBar()
static int vtkSMColorMapEditorHelper::GetBlockEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
inlinestatic
Definition at line 463 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksEstimatedNumberOfAnnotationsOnScalarBars()
static std::vector<int> vtkSMColorMapEditorHelper::GetBlocksEstimatedNumberOfAnnotationsOnScalarBars ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
◆ GetSelectedEstimatedNumberOfAnnotationsOnScalarBars()
std::vector<int> vtkSMColorMapEditorHelper::GetSelectedEstimatedNumberOfAnnotationsOnScalarBars ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ GetAnySelectedEstimatedNumberOfAnnotationsOnScalarBar()
int vtkSMColorMapEditorHelper::GetAnySelectedEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ IsScalarBarStickyVisible()
static int vtkSMColorMapEditorHelper::IsScalarBarStickyVisible ( vtkSMProxy *  proxy,
vtkSMProxy *  view
should be visible whenever this representation is also visible. It returns 1 if the scalar bar is sticky visible, 0 other wise. If any problem is encountered, for example if view == nullptr, or if the scalar bar representation is not instantiated / found, it returns -1.
◆ IsBlockScalarBarStickyVisible()
static int vtkSMColorMapEditorHelper::IsBlockScalarBarStickyVisible ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
inlinestatic
Definition at line 488 of file vtkSMColorMapEditorHelper.h.
◆ IsBlocksScalarBarStickyVisible()
static std::vector<int> vtkSMColorMapEditorHelper::IsBlocksScalarBarStickyVisible ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
◆ IsColorValid()
static bool vtkSMColorMapEditorHelper::IsColorValid ( Color  color)
Note
Use IsColorValid to check if the returned value is valid/set.
◆ SetColor()
static void vtkSMColorMapEditorHelper::SetColor ( vtkSMProxy *  proxy,
Color  color
Note
◆ SetBlockColor()
static void vtkSMColorMapEditorHelper::SetBlockColor ( vtkSMProxy *  proxy,
Color  color
inlinestatic
Note
Definition at line 507 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksColor()
static void vtkSMColorMapEditorHelper::SetBlocksColor ( vtkSMProxy *  proxy,
Color  color
Note
◆ RemoveBlockColor()
static void vtkSMColorMapEditorHelper::RemoveBlockColor ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 513 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksColors()
static void vtkSMColorMapEditorHelper::RemoveBlocksColors ( vtkSMProxy *  proxy,
Note
◆ SetSelectedColor()
void vtkSMColorMapEditorHelper::SetSelectedColor ( vtkSMProxy *  proxy,
Color  color
Note
◆ GetColor()
static Color vtkSMColorMapEditorHelper::GetColor ( vtkSMProxy *  proxy)
Note
◆ GetBlockColor()
static Color vtkSMColorMapEditorHelper::GetBlockColor ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 520 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksColors()
static std::vector<Color> vtkSMColorMapEditorHelper::GetBlocksColors ( vtkSMProxy *  proxy,
Note
◆ GetSelectedColors()
std::vector<Color> vtkSMColorMapEditorHelper::GetSelectedColors ( vtkSMProxy *  proxy)
Note
◆ GetColorArrayProperty()
static vtkSMProperty* vtkSMColorMapEditorHelper::GetColorArrayProperty ( vtkSMProxy *  proxy)
◆ GetBlockColorArrayProperty()
static vtkSMProperty* vtkSMColorMapEditorHelper::GetBlockColorArrayProperty ( vtkSMProxy *  proxy)
◆ GetSelectedColorArrayProperty()
vtkSMProperty* vtkSMColorMapEditorHelper::GetSelectedColorArrayProperty ( vtkSMProxy *  proxy)
◆ IsColorArrayValid()
static bool vtkSMColorMapEditorHelper::IsColorArrayValid ( const ColorArray &  array)
Note
Use IsColorArrayValid to check if the returned value is valid/set.
◆ GetBlocksColorArrays()
static std::vector<ColorArray> vtkSMColorMapEditorHelper::GetBlocksColorArrays ( vtkSMProxy *  proxy,
Note
◆ GetBlockColorArrayAssociation()
static int vtkSMColorMapEditorHelper::GetBlockColorArrayAssociation ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 548 of file vtkSMColorMapEditorHelper.h.
◆ GetBlockColorArrayName()
static std::string vtkSMColorMapEditorHelper::GetBlockColorArrayName ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 552 of file vtkSMColorMapEditorHelper.h.
◆ GetCommonColorArraysBlockSelectors()
static std::map<ColorArray, std::vector<std::string> > vtkSMColorMapEditorHelper::GetCommonColorArraysBlockSelectors ( vtkSMProxy *  proxy,
Note
◆ GetSelectedColorArrays()
std::vector<ColorArray> vtkSMColorMapEditorHelper::GetSelectedColorArrays ( vtkSMProxy *  proxy)
Note
◆ GetUseSeparateColorMapProperty()
static vtkSMProperty* vtkSMColorMapEditorHelper::GetUseSeparateColorMapProperty ( vtkSMProxy *  proxy)
◆ GetBlockUseSeparateColorMapProperty()
static vtkSMProperty* vtkSMColorMapEditorHelper::GetBlockUseSeparateColorMapProperty ( vtkSMProxy *  proxy)
◆ GetSelectedUseSeparateColorMapProperty()
vtkSMProperty* vtkSMColorMapEditorHelper::GetSelectedUseSeparateColorMapProperty ( vtkSMProxy *  proxy)
◆ IsUseSeparateColorMapValid()
static bool vtkSMColorMapEditorHelper::IsUseSeparateColorMapValid ( int  useSeparateColorMap)
Note
Use IsUseSeparateColorMapValid to check if the returned value is valid/set.
◆ SetUseSeparateColorMap()
static void vtkSMColorMapEditorHelper::SetUseSeparateColorMap ( vtkSMProxy *  proxy,
bool  use
Note
◆ SetBlockUseSeparateColorMap()
static void vtkSMColorMapEditorHelper::SetBlockUseSeparateColorMap ( vtkSMProxy *  proxy,
bool  use
inlinestatic
Note
Definition at line 578 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksUseSeparateColorMap()
static void vtkSMColorMapEditorHelper::SetBlocksUseSeparateColorMap ( vtkSMProxy *  proxy,
bool  use
Note
◆ RemoveBlockUseSeparateColorMap()
static void vtkSMColorMapEditorHelper::RemoveBlockUseSeparateColorMap ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 585 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksUseSeparateColorMaps()
static void vtkSMColorMapEditorHelper::RemoveBlocksUseSeparateColorMaps ( vtkSMProxy *  proxy,
Note
◆ SetSelectedUseSeparateColorMap()
void vtkSMColorMapEditorHelper::SetSelectedUseSeparateColorMap ( vtkSMProxy *  proxy,
bool  use
Note
◆ GetUseSeparateColorMap()
static bool vtkSMColorMapEditorHelper::GetUseSeparateColorMap ( vtkSMProxy *  proxy)
Note
◆ GetBlockUseSeparateColorMap()
static int vtkSMColorMapEditorHelper::GetBlockUseSeparateColorMap ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 593 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksUseSeparateColorMaps()
static std::vector<int> vtkSMColorMapEditorHelper::GetBlocksUseSeparateColorMaps ( vtkSMProxy *  proxy,
Note
◆ GetSelectedUseSeparateColorMaps()
std::vector<int> vtkSMColorMapEditorHelper::GetSelectedUseSeparateColorMaps ( vtkSMProxy *  proxy)
Note
◆ GetAnySelectedUseSeparateColorMap()
bool vtkSMColorMapEditorHelper::GetAnySelectedUseSeparateColorMap ( vtkSMProxy *  proxy)
Note
◆ IsMapScalarsValid()
static bool vtkSMColorMapEditorHelper::IsMapScalarsValid ( int  mapScalars)
Note
Use IsMapScalarsValid to check if the returned value is valid/set.
◆ SetMapScalars()
static void vtkSMColorMapEditorHelper::SetMapScalars ( vtkSMProxy *  proxy,
bool  mapScalars
Note
◆ SetBlockMapScalars()
static void vtkSMColorMapEditorHelper::SetBlockMapScalars ( vtkSMProxy *  proxy,
bool  mapScalars
inlinestatic
Note
Definition at line 612 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksMapScalars()
static void vtkSMColorMapEditorHelper::SetBlocksMapScalars ( vtkSMProxy *  proxy,
bool  mapScalars
Note
◆ RemoveBlockMapScalars()
static void vtkSMColorMapEditorHelper::RemoveBlockMapScalars ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 619 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksMapScalars()
static void vtkSMColorMapEditorHelper::RemoveBlocksMapScalars ( vtkSMProxy *  proxy,
Note
◆ SetSelectedMapScalars()
void vtkSMColorMapEditorHelper::SetSelectedMapScalars ( vtkSMProxy *  proxy,
bool  mapScalars
Note
◆ GetMapScalars()
static bool vtkSMColorMapEditorHelper::GetMapScalars ( vtkSMProxy *  proxy)
Note
◆ GetBlockMapScalars()
static int vtkSMColorMapEditorHelper::GetBlockMapScalars ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 627 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksMapScalars()
static std::vector<int> vtkSMColorMapEditorHelper::GetBlocksMapScalars ( vtkSMProxy *  proxy,
Note
◆ GetSelectedMapScalars()
std::vector<int> vtkSMColorMapEditorHelper::GetSelectedMapScalars ( vtkSMProxy *  proxy)
Note
◆ GetAnySelectedMapScalars()
bool vtkSMColorMapEditorHelper::GetAnySelectedMapScalars ( vtkSMProxy *  proxy)
Note
◆ IsInterpolateScalarsBeforeMappingValid()
static bool vtkSMColorMapEditorHelper::IsInterpolateScalarsBeforeMappingValid ( int  interpolate)
Note
Use IsInterpolateScalarsBeforeMappingValid to check if the returned value is valid/set.
◆ SetInterpolateScalarsBeforeMapping()
static void vtkSMColorMapEditorHelper::SetInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy,
bool  interpolate
Note
◆ SetBlockInterpolateScalarsBeforeMapping()
static void vtkSMColorMapEditorHelper::SetBlockInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy,
bool  interpolate
inlinestatic
Note
Definition at line 645 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksInterpolateScalarsBeforeMapping()
static void vtkSMColorMapEditorHelper::SetBlocksInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy,
bool  interpolate
Note
◆ RemoveBlockInterpolateScalarsBeforeMapping()
static void vtkSMColorMapEditorHelper::RemoveBlockInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 653 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksInterpolateScalarsBeforeMappings()
static void vtkSMColorMapEditorHelper::RemoveBlocksInterpolateScalarsBeforeMappings ( vtkSMProxy *  proxy,
Note
◆ SetSelectedInterpolateScalarsBeforeMapping()
void vtkSMColorMapEditorHelper::SetSelectedInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy,
bool  interpolate
Note
◆ GetInterpolateScalarsBeforeMapping()
static bool vtkSMColorMapEditorHelper::GetInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy)
Note
◆ GetBlockInterpolateScalarsBeforeMapping()
static int vtkSMColorMapEditorHelper::GetBlockInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 663 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksInterpolateScalarsBeforeMappings()
static std::vector<int> vtkSMColorMapEditorHelper::GetBlocksInterpolateScalarsBeforeMappings ( vtkSMProxy *  proxy,
Note
◆ GetSelectedInterpolateScalarsBeforeMappings()
std::vector<int> vtkSMColorMapEditorHelper::GetSelectedInterpolateScalarsBeforeMappings ( vtkSMProxy *  proxy)
Note
◆ GetAnySelectedInterpolateScalarsBeforeMapping()
bool vtkSMColorMapEditorHelper::GetAnySelectedInterpolateScalarsBeforeMapping ( vtkSMProxy *  proxy)
Note
◆ IsOpacityValid()
static bool vtkSMColorMapEditorHelper::IsOpacityValid ( double  opacity)
Note
Use IsOpacityValid to check if the returned value is valid/set.
◆ SetOpacity()
static void vtkSMColorMapEditorHelper::SetOpacity ( vtkSMProxy *  proxy,
double  opacity
Note
◆ SetBlockOpacity()
static void vtkSMColorMapEditorHelper::SetBlockOpacity ( vtkSMProxy *  proxy,
double  opacity
inlinestatic
Note
Definition at line 684 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksOpacity()
static void vtkSMColorMapEditorHelper::SetBlocksOpacity ( vtkSMProxy *  proxy,
double  opacity
Note
◆ RemoveBlockOpacity()
static void vtkSMColorMapEditorHelper::RemoveBlockOpacity ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 690 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksOpacities()
static void vtkSMColorMapEditorHelper::RemoveBlocksOpacities ( vtkSMProxy *  proxy,
Note
◆ SetSelectedOpacity()
void vtkSMColorMapEditorHelper::SetSelectedOpacity ( vtkSMProxy *  proxy,
double  opacity
Note
◆ GetOpacity()
static double vtkSMColorMapEditorHelper::GetOpacity ( vtkSMProxy *  proxy)
Note
◆ GetBlockOpacity()
static double vtkSMColorMapEditorHelper::GetBlockOpacity ( vtkSMProxy *  proxy,
inlinestatic
Note
Definition at line 698 of file vtkSMColorMapEditorHelper.h.
◆ GetBlocksOpacities()
static std::vector<double> vtkSMColorMapEditorHelper::GetBlocksOpacities ( vtkSMProxy *  proxy,
Note
◆ GetSelectedOpacities()
std::vector<double> vtkSMColorMapEditorHelper::GetSelectedOpacities ( vtkSMProxy *  proxy)
Note
◆ ResetBlockProperty()
static void vtkSMColorMapEditorHelper::ResetBlockProperty ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 711 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlockProperties()
static void vtkSMColorMapEditorHelper::RemoveBlockProperties ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 716 of file vtkSMColorMapEditorHelper.h.
◆ ResetBlocksProperty()
static void vtkSMColorMapEditorHelper::ResetBlocksProperty ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 721 of file vtkSMColorMapEditorHelper.h.
◆ ResetBlocksProperties()
static void vtkSMColorMapEditorHelper::ResetBlocksProperties ( vtkSMProxy *  proxy,
◆ RescaleTransferFunctionToDataRange() [3/3]
vtkPVArrayInformation *  info,
bool  force = true
staticprotected
◆ RescaleBlockTransferFunctionToDataRange() [3/3]
bool  force = true
inlinestaticprotected
Definition at line 741 of file vtkSMColorMapEditorHelper.h.
◆ RescaleBlocksTransferFunctionToDataRange() [3/3]
bool  force = true
staticprotected
◆ SetColorArray()
static void vtkSMColorMapEditorHelper::SetColorArray ( vtkSMProxy *  proxy,
int  attributeType,
staticprotected
◆ SetBlockColorArray()
static void vtkSMColorMapEditorHelper::SetBlockColorArray ( vtkSMProxy *  proxy,
int  attributeType,
Definition at line 759 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksColorArray()
static void vtkSMColorMapEditorHelper::SetBlocksColorArray ( vtkSMProxy *  proxy,
int  attributeType,
staticprotected
◆ RemoveBlockColorArray()
static void vtkSMColorMapEditorHelper::RemoveBlockColorArray ( vtkSMProxy *  proxy,
Definition at line 767 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksColorArrays()
static void vtkSMColorMapEditorHelper::RemoveBlocksColorArrays ( vtkSMProxy *  proxy,
staticprotected
◆ GetColorArray()
static ColorArray vtkSMColorMapEditorHelper::GetColorArray ( vtkSMProxy *  proxy)
staticprotected
◆ GetBlockColorArray()
static ColorArray vtkSMColorMapEditorHelper::GetBlockColorArray ( vtkSMProxy *  proxy,
Definition at line 774 of file vtkSMColorMapEditorHelper.h.
◆ SetBlockLookupTable()
static void vtkSMColorMapEditorHelper::SetBlockLookupTable ( vtkSMProxy *  proxy,
vtkSMProxy *  lutProxy
Definition at line 784 of file vtkSMColorMapEditorHelper.h.
◆ SetBlocksLookupTable()
static void vtkSMColorMapEditorHelper::SetBlocksLookupTable ( vtkSMProxy *  proxy,
staticprotected
◆ RemoveBlockLookupTable()
static void vtkSMColorMapEditorHelper::RemoveBlockLookupTable ( vtkSMProxy *  proxy,
Definition at line 791 of file vtkSMColorMapEditorHelper.h.
◆ RemoveBlocksLookupTables()
static void vtkSMColorMapEditorHelper::RemoveBlocksLookupTables ( vtkSMProxy *  proxy,
staticprotected
◆ SetScalarColoringInternal()
static bool vtkSMColorMapEditorHelper::SetScalarColoringInternal ( vtkSMProxy *  proxy,
int  attributeType,
bool  useComponent,
int  component
staticprotected
◆ SetBlocksScalarColoringInternal()
static std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetBlocksScalarColoringInternal ( vtkSMProxy *  proxy,
int  attributeType,
bool  useComponent,
int  component
staticprotected
◆ SetSelectedScalarColoringInternal()
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetSelectedScalarColoringInternal ( vtkSMProxy *  proxy,
int  attributeType,
bool  useComponent,
int  component
◆ GetLastLookupTable()
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLastLookupTable ( vtkSMProxy *  proxy)
staticprotected
This is used in UpdateScalarBarRange to update the scalar bar range when turning off the coloring for this representation.
◆ SetLastLookupTable()
static void vtkSMColorMapEditorHelper::SetLastLookupTable ( vtkSMProxy *  proxy,
staticprotected
◆ GetLastBlockLookupTable()
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLastBlockLookupTable ( vtkSMProxy *  proxy,
Definition at line 819 of file vtkSMColorMapEditorHelper.h.
◆ GetLastBlocksLookupTables()
static std::vector<vtkSMProxy*> vtkSMColorMapEditorHelper::GetLastBlocksLookupTables ( vtkSMProxy *  proxy,
staticprotected
◆ SetLastBlockLookupTable()
static void vtkSMColorMapEditorHelper::SetLastBlockLookupTable ( vtkSMProxy *  proxy,
Definition at line 825 of file vtkSMColorMapEditorHelper.h.
◆ SetLastBlocksLookupTable()
static void vtkSMColorMapEditorHelper::SetLastBlocksLookupTable ( vtkSMProxy *  proxy,
staticprotected
◆ vtkSMPVRepresentationProxy
friend class vtkSMPVRepresentationProxy
friend
Definition at line 834 of file vtkSMColorMapEditorHelper.h.
