vtkSMChartSeriesSelectionDomain.h
29 #ifndef vtkSMChartSeriesSelectionDomain_h
30 #define vtkSMChartSeriesSelectionDomain_h
31
32 #include "vtkParaViewDeprecation.h"
33 #include "vtkRemotingViewsModule.h" // needed for exports
34 #include "vtkSMStringListDomain.h"
35
36 #include <set> // For std::set
37
41
42 class VTKREMOTINGVIEWS_EXPORT vtkSMChartSeriesSelectionDomain : public vtkSMStringListDomain
43 {
44 public:
47  void PrintSelf(ostream& os, vtkIndent indent) override;
48
53  void Update(vtkSMProperty*) override;
54
56  {
61  VALUE
62  };
63
68  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
69
71
74  vtkGetMacro(DefaultMode, int);
76
83  "See vtkPVRepresentedArrayListSettings::SetChartsHiddenAttributes instead")
84  static void AddSeriesVisibilityDefault(const char*, bool) {}
85
90  static void SetLoadNoChartVariables(bool choice)
91  {
93  }
94  static bool GetLoadNoChartVariables() { return vtkSMChartSeriesSelectionDomain::LoadNoVariables; }
95
96  vtkSetStringMacro(DefaultValue);
97
98 protected:
101
105  vtkPVDataInformation* GetInputInformation();
106
110  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
111
115  virtual bool GetDefaultSeriesVisibility(const char*);
116
121  virtual std::vector<std::string> GetDefaultValue(const char* series);
122
128  virtual void PopulateAvailableArrays(const std::string& blockName,
129  std::vector<std::string>& strings, vtkPVDataInformation* dataInfo, int fieldAssociation,
130  bool flattenTable);
131
137  virtual void PopulateArrayComponents(vtkChartRepresentation* chartRepr,
138  const std::string& blockName, std::vector<std::string>& strings,
139  std::set<std::string>& unique_strings, vtkPVArrayInformation* dataInfo, bool flattenTable);
140
146  virtual void SetDefaultVisibilityOverride(const std::string& arrayname, bool visibility);
147
149
151
156
161
166
167  static bool LoadNoVariables;
168
169 private:
171  void operator=(const vtkSMChartSeriesSelectionDomain&) = delete;
172
173  class vtkInternals;
174  vtkInternals* Internals;
175
176  // The EXPERIMENTAL feature: everytime domain is modified we update the
177  // property's value.
178  void OnDomainModified();
179  void UpdateDefaultValues(vtkSMProperty*, bool preserve_previous_values);
180 };
181
182 #endif
Definition: vtkSMChartSeriesSelectionDomain.h:167
vtkSMChartSeriesSelectionDomain::COLOR
@ COLOR
Definition: vtkSMChartSeriesSelectionDomain.h:60
vtkSMStringListDomain::SetDefaultValues
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
vtkSMChartSeriesSelectionDomain::HidePartialArrays
bool HidePartialArrays
Specify if Partial Arrays should be hidden.
Definition: vtkSMChartSeriesSelectionDomain.h:165
vtkSMChartSeriesSelectionDomain::VISIBILITY
@ VISIBILITY
Definition: vtkSMChartSeriesSelectionDomain.h:58
vtkSMChartSeriesSelectionDomain::DefaultValue
char * DefaultValue
Value used when DefaultMode==VALUE.
Definition: vtkSMChartSeriesSelectionDomain.h:154
vtkSMStringListDomain::Update
void Update(vtkSMProperty *) override
Update self checking the "unchecked" values of all required properties.
vtkSMChartSeriesSelectionDomain::FlattenTable
bool FlattenTable
Specify if table components should be split.
Definition: vtkSMChartSeriesSelectionDomain.h:160
vtkSMProperty
Definition: vtkSMProperty.h:144
vtkSMChartSeriesSelectionDomain::DefaultMode
int DefaultMode
Definition: vtkSMChartSeriesSelectionDomain.h:148
vtkIndent
vtkSMStringListDomain::ReadXMLAttributes
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
vtkSMStringListDomain::PrintSelf
provides meta data about a vtkDataObject subclass.
Definition: vtkPVDataInformation.h:42
vtkPVXMLElement
Definition: vtkPVXMLElement.h:23
provides meta data about arrays.
Definition: vtkPVArrayInformation.h:30
extends vtkSMChartSeriesListDomain to add logic to better handle default values suitable for series-p...
Definition: vtkSMChartSeriesSelectionDomain.h:42
vtkSMChartSeriesSelectionDomain::UNDEFINED
@ UNDEFINED
Definition: vtkSMChartSeriesSelectionDomain.h:57
list of strings
Definition: vtkSMStringListDomain.h:32
vtkSMDomain::Internals
vtkSMDomainInternals * Internals
Definition: vtkSMDomain.h:273
vtkSMChartSeriesSelectionDomain::LABEL
@ LABEL
Definition: vtkSMChartSeriesSelectionDomain.h:59
PARAVIEW_DEPRECATED_IN_5_12_0
#define PARAVIEW_DEPRECATED_IN_5_12_0(reason)
Definition: vtkParaViewDeprecation.h:100
Definition: vtkChartRepresentation.h:33
vtkSMStringListDomain::New
static vtkSMStringListDomain * New()
vtkSMChartSeriesSelectionDomain::DefaultModes
DefaultModes
Definition: vtkSMChartSeriesSelectionDomain.h:55
