vtkChartRepresentation.h
16 #ifndef vtkChartRepresentation_h
17 #define vtkChartRepresentation_h
18
20 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
21 #include "vtkWeakPointer.h" // needed for vtkWeakPointer
22
23 #include <map> // needed for map
24 #include <set> //needed for ivars
25
29 class vtkPVContextView;
31 class vtkTable;
32
33 class VTKREMOTINGVIEWS_EXPORT vtkChartRepresentation : public vtkPVDataRepresentation
34 {
35 public:
36  static vtkChartRepresentation* New();
38  void PrintSelf(ostream& os, vtkIndent indent) override;
44  void SetSelectionRepresentation(vtkChartSelectionRepresentation*);
45
49  void SetVisibility(bool visible) override;
50
57  void MarkModified() override;
58
59  // *************************************************************************
60
62
66  void SetFieldAssociation(int);
67  vtkGetMacro(FieldAssociation, int);
69
70  // methods to control block selection.
71  // When changed, this will call MarkModified().
72  void SetCompositeDataSetIndex(unsigned int); // only used for single block selection
73  void AddCompositeDataSetIndex(unsigned int);
74  void ResetCompositeDataSetIndices();
75
80  unsigned int Initialize(unsigned int minIdAvailable, unsigned int maxIdAvailable) override;
81
90  vtkInformation* outInfo) override;
91
99  virtual std::string GetDefaultSeriesLabel(
100  const std::string& tableName, const std::string& columnName);
101
103
107  vtkSetMacro(FlattenTable, int);
108  vtkGetMacro(FlattenTable, int);
110
124  virtual bool MapSelectionToInput(vtkSelection* sel);
125
136  virtual bool MapSelectionToView(vtkSelection* sel);
137
143  virtual bool Export(vtkAbstractChartExporter* vtkNotUsed(exporter)) { return false; }
144
145 protected:
147  ~vtkChartRepresentation() override;
148
152  int FillInputPortInformation(int port, vtkInformation* info) override;
153
164  virtual void PrepareForRendering() {}
165
177
183  bool AddToView(vtkView* view) override;
184
190  bool RemoveFromView(vtkView* view) override;
191
198  vtkTable* GetLocalOutput(bool pre_delivery = false);
199
204  virtual vtkSmartPointer<vtkDataObject> TransformInputData(vtkDataObject* data);
205
213  virtual vtkSmartPointer<vtkDataObject> ReduceDataToRoot(vtkDataObject* data);
214
222
223  typedef std::map<std::string, std::pair<vtkSmartPointer<vtkTable>, unsigned int>> MapOfTables;
228  bool GetLocalOutput(MapOfTables& tables);
229
233
235  std::set<unsigned int> CompositeIndices; // the selected blocks
236
238
239 private:
241  void operator=(const vtkChartRepresentation&) = delete;
242
243  vtkTimeStamp PrepareForRenderingTime;
244  vtkMTimeType LastLocalOutputMTime;
246  vtkSmartPointer<vtkMultiBlockDataSet> LocalOutputRequestData;
247 };
248
249 #endif
vtkDataRepresentation::New
static vtkDataRepresentation * New()
vtkChartRepresentation::ContextView
vtkWeakPointer< vtkPVContextView > ContextView
Definition: vtkChartRepresentation.h:231
vtkChartRepresentation::MapOfTables
std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
Definition: vtkChartRepresentation.h:223
vtkChartRepresentation::PrepareForRendering
This method is called before actual render if this->MTime was modified since the last time this metho...
Definition: vtkChartRepresentation.h:164
vtkChartRepresentation::FlattenTable
int FlattenTable
Definition: vtkChartRepresentation.h:232
vtkPVDataRepresentation.h
vtkInformationVector
vtkTable
vtkTimeStamp
vtkChartRepresentation::LocalOutput
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
Definition: vtkChartRepresentation.h:234
vtkPVDataRepresentation::AddToView
bool AddToView(vtkView *view) override
Making these methods public.
vtkSmartPointer< vtkDataObject >
exporter used by certain views to export data into a file or stream.
Definition: vtkAbstractChartExporter.h:23
vtkPVContextView
Definition: vtkPVContextView.h:29
vtkSelectionDeliveryFilter
Definition: vtkSelectionDeliveryFilter.h:21
vtkPVDataRepresentation::SetVisibility
virtual void SetVisibility(bool val)
Definition: vtkPVDataRepresentation.h:89
vtkSelection
vtkMTimeType
vtkTypeUInt64 vtkMTimeType
vtkPVDataRepresentation::Initialize
virtual unsigned int Initialize(unsigned int minIdAvailable, unsigned int maxIdAvailable)
Initialize the representation with an identifier range so each internal representation can own a uniq...
vtkPVDataRepresentation::RequestData
int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
Overridden to invoke vtkCommand::UpdateDataEvent.
representation for showing selections in chart views.
Definition: vtkChartSelectionRepresentation.h:29
vtkPVDataRepresentation::RemoveFromView
bool RemoveFromView(vtkView *view) override
vtkChartRepresentation::FieldAssociation
int FieldAssociation
Definition: vtkChartRepresentation.h:230
vtkPassInputTypeAlgorithm::FillInputPortInformation
virtual int FillInputPortInformation(int port, vtkInformation *info)
vtkView
vtkIndent
vtkPVDataRepresentation::ProcessViewRequest
virtual int ProcessViewRequest(vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
vtkChartRepresentation::SelectionRepresentation
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
Definition: vtkChartRepresentation.h:237
vtkChartRepresentation::CompositeIndices
std::set< unsigned int > CompositeIndices
Definition: vtkChartRepresentation.h:235
vtkSmartPointer.h
vtkWeakPointer.h
vtkInformation
vtkPVDataRepresentation::PrintSelf
vtkPVDataRepresentation::MarkModified
virtual void MarkModified()
This is one of the most important functions.
vtkChartRepresentation::Export
virtual bool Export(vtkAbstractChartExporter *vtkNotUsed(exporter))
Called by vtkPVContextView::Export() to export the representation's data to a CSV file.
Definition: vtkChartRepresentation.h:143
Definition: vtkPVDataRepresentation.h:23
Definition: vtkChartRepresentation.h:33
vtkDataObject
