vtkSMSessionClient Class Reference
#include <vtkSMSessionClient.h>
Inheritance diagram for vtkSMSessionClient:
Collaboration diagram for vtkSMSessionClient:
typedef vtkSMSession Superclass
- Public Types inherited from vtkSMSession
enum  RenderingMode { RENDERING_NOT_AVAILABLE = 0x00, RENDERING_UNIFIED = 0x01, RENDERING_SPLIT = 0x02 }
typedef vtkPVSessionBase Superclass
- Public Types inherited from vtkPVSessionBase
enum  EventIds { RegisterRemoteObjectEvent = 1234, UnRegisterRemoteObjectEvent = 4321, ProcessingRemoteEnd = 2143, ConnectionLost = 6789 }
typedef vtkPVSession Superclass
enum  ServerFlags {
  NONE = 0, DATA_SERVER = 0x01, DATA_SERVER_ROOT = 0x02, RENDER_SERVER = 0x04,
  RENDER_SERVER_ROOT = 0x08, SERVERS = DATA_SERVER | RENDER_SERVER, CLIENT = 0x10, CLIENT_AND_SERVERS = DATA_SERVER | CLIENT | RENDER_SERVER
typedef vtkSession Superclass
- Public Types inherited from vtkSession
const char * GetURI () override
 Return the url used to connect the current session to a server. More...
bool GetIsAlive () override
 Returns true is this session is active/alive/valid. More...
ServerFlags GetProcessRoles () override
 Returns a ServerFlags indicate the nature of the current processes. More...
vtkMultiProcessController * GetController (ServerFlags processType) override
 Returns the controller used to communicate with the process. More...
vtkPVServerInformation * GetServerInformation () override
 vtkPVServerInformation is an information-object that provides information about the server processes. More...
void Initialize () override
 Called to do any initializations after a successful session has been established. More...
void CloseSession ()
 Gracefully exits the session. More...
bool GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) override
 Gather information about an object referred by the globalid. More...
int GetNumberOfProcesses (vtkTypeUInt32 servers) override
 Returns the number of processes on the given server/s. More...
bool IsMPIInitialized (vtkTypeUInt32 servers) override
 Returns whether or not MPI is initialized on the specified server/s. More...
void PreDisconnection () override
virtual bool IsNotBusy ()
 Flag used to know if it is a good time to handle server notification. More...
virtual void StartBusyWork ()
 BusyWork should be declared inside method that will request several network call that we don't want to interrupt such as GatherInformation and Pull. More...
virtual void EndBusyWork ()
vtkSMCollaborationManager * GetCollaborationManager () override
 Return the instance of vtkSMCollaborationManager that will be lazy created at the first call. More...
int GetConnectID ()
 Return the connect id of this client. More...
vtkTypeUInt32 GetNextGlobalUniqueIdentifier () override
 Provides the next available identifier. More...
vtkTypeUInt32 GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) override
 Return the first Id of the requested chunk. More...
void OnServerNotificationMessageRMI (void *message, int message_length)
virtual bool Connect (const char *url, int timeout=60)
 Connects a remote server. More...
virtual bool Connect (const char *url, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &connectionResult)
void PushState (vtkSMMessage *msg) override
 Push the state. More...
void PullState (vtkSMMessage *message) override
void ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false) override
const vtkClientServerStream & GetLastResult (vtkTypeUInt32 location) override
virtual void SetAbortConnect (bool)
 When Connect() is waiting for a server to connect back to the client (in reverse connect mode), then it periodically fires ProgressEvent. More...
void PrepareProgressInternal () override
 Should be called to begin/end receiving progresses on this session. More...
void CleanupPendingProgressInternal () override
- Public Member Functions inherited from vtkSMSession
virtual vtkSMProxyLocator * GetProxyLocator ()
virtual unsigned int GetRenderClientMode ()
 Convenient method to determine if the rendering is done in a pvrenderer or not. More...
void NotifyAllClients (const vtkSMMessage *msg) override
 Sends the message to all clients. More...
void NotifyOtherClients (const vtkSMMessage *) override
 Sends the message to all but the active client-session. More...
 Returns the vtkSMSessionProxyManager associated with this session. More...
virtual vtkSMStateLocator * GetStateLocator ()
 Provide an access to the session state locator that can provide the last state of a given remote object that have been pushed. More...
- Public Member Functions inherited from vtkPVSessionBase
vtkMPIMToNSocketConnection * GetMPIMToNSocketConnection () override
 This is socket connection, if any to communicate between the data-server and render-server nodes. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Get the ProxyDefinitionManager. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Returns a vtkSIObject or subclass given its global id, if any. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More...
virtual void GetAllRemoteObjects (vtkCollection *collection)
 Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More...
virtual bool IsProcessingRemoteNotification ()
 This property is used to discard ignore_synchronization proxy property when we load protobuf states. More...
virtual void UseSessionCoreOf (vtkPVSessionBase *other)
 Update internal session core in order to use the one used in another session. More...
virtual vtkPVSessionCore * GetSessionCore ()
 Provides access to the session core. More...
bool HasProcessRole (vtkTypeUInt32 flag)
 Convenience method that returns true if the current session is serving the indicated role on this process. More...
virtual bool IsMultiClients ()
 Allow anyone to know easily if the current session is involved in collaboration or not. More...
bool GetPendingProgress ()
 Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More...
virtual vtkPVProgressHandler * GetProgressHandler ()
 Provides access to the progress handler. More...
void PrepareProgress ()
void CleanupPendingProgress ()
static vtkSMSessionClient * New ()
static vtkSMSessionClient * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSession
static vtkSMSession * New ()
static vtkSMSession * New (vtkPVSessionBase *otherSession)
static vtkSMSession * New (vtkPVSessionCore *otherSessionCore)
static vtkSMSession * SafeDownCast (vtkObject *o)
static vtkIdType ConnectToCatalyst ()
 These are static helper methods that help create Catalyst ParaView sessions. More...
static vtkIdType ConnectToSelf ()
 These are static helper methods that help create standard ParaView sessions. More...
static vtkIdType ConnectToRemote (const char *hostname, int port, int timeout=60)
static vtkIdType ConnectToRemote (const char *hostname, int port, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result)
static vtkIdType ReverseConnectToRemote (int port)
 Same as ConnectToRemote() except that it waits for a reverse connection for timeout seconds. More...
static vtkIdType ReverseConnectToRemoteWithTimeout (int port, int timeout)
static vtkIdType ReverseConnectToRemote (int port, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result)
static vtkIdType ConnectToRemote (const char *dshost, int dsport, const char *rshost, int rsport, int timeout=60)
static vtkIdType ConnectToRemote (const char *dshost, int dsport, const char *rshost, int rsport, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result)
static vtkIdType ReverseConnectToRemote (int dsport, int rsport)
static vtkIdType ReverseConnectToRemoteWithTimeout (int dsport, int rsport, int timeout)
static vtkIdType ReverseConnectToRemote (int dsport, int rsport, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result)
static void Disconnect (vtkIdType sessionid)
 Use this method to disconnect from a session. More...
static void Disconnect (vtkSMSession *session)
- Static Public Member Functions inherited from vtkPVSessionBase
static vtkPVSessionBase * SafeDownCast (vtkObject *o)
static vtkPVSession * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSession
static vtkSession * SafeDownCast (vtkObject *o)
 vtkSMSessionClient ()
 ~vtkSMSessionClient () override
void SetRenderServerController (vtkMultiProcessController *)
void SetDataServerController (vtkMultiProcessController *)
void SetupDataServerRenderServerConnection ()
void UnRegisterSIObject (vtkSMMessage *msg) override
 Delete server side object. More...
void RegisterSIObject (vtkSMMessage *msg) override
 Notify server side object that it is used by one more client. More...
vtkTypeUInt32 GetRealLocation (vtkTypeUInt32)
 Translates the location to a real location based on whether a separate render-server exists. More...
virtual void SetURI (const char *)
bool OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata) override
 Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More...
virtual void OnConnectionLost (vtkObject *caller, unsigned long eventid, void *calldata)
 Callback when any vtkMultiProcessController subclass fires a ErrorEvent. More...
- Protected Member Functions inherited from vtkSMSession
 vtkSMSession (bool initialize_during_constructor=true, vtkPVSessionCore *preExistingSessionCore=nullptr)
 ~vtkSMSession () override
virtual void ProcessNotification (const vtkSMMessage *)
 Process the Notifation message sent using API to communicate from server-to-client. More...
void UpdateStateHistory (vtkSMMessage *msg)
 This method has been externalized so classes that heritate from vtkSMSession and override PushState could easily keep track of the StateHistory and maintain the UndoRedo mecanisme. More...
- Protected Member Functions inherited from vtkPVSessionBase
 vtkPVSessionBase ()
 vtkPVSessionBase (vtkPVSessionCore *coreToUse)
 ~vtkPVSessionBase () override
void RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj)
 Register a remote object. More...
void UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location)
 Unregister a remote object. More...
vtkPVSessionCore * GetSessionCore () const
 Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More...
void SetSessionCore (vtkPVSessionCore *)
virtual bool StartProcessingRemoteNotification ()
 Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More...
virtual void StopProcessingRemoteNotification (bool previousValue)
 vtkPVSession ()
 ~vtkPVSession () override
- Protected Member Functions inherited from vtkSession
 vtkSession ()
 ~vtkSession () override
virtual void Activate ()
 Subclasses must call this to mark the session active. More...
virtual void DeActivate ()
 Subclasses must call this to mark the session inactive. More...
vtkMultiProcessController * RenderServerController
vtkMultiProcessController * DataServerController
vtkPVServerInformation * DataServerInformation
vtkPVServerInformation * RenderServerInformation
vtkPVServerInformation * ServerInformation
vtkClientServerStream * ServerLastInvokeResult
bool AbortConnect
char * URI
bool NoMoreDelete
vtkSMCollaborationManager * CollaborationCommunicator
- Protected Attributes inherited from vtkSMSession
vtkSMSessionProxyManager * SessionProxyManager
vtkSMStateLocator * StateLocator
vtkSMProxyLocator * ProxyLocator
- Protected Attributes inherited from vtkPVSessionBase
vtkPVSessionCore * SessionCore
bool ProcessingRemoteNotification
vtkPVProgressHandler * ProgressHandler
- Protected Types inherited from vtkPVSession
enum  { EXCEPTION_EVENT_TAG = 31416 }
vtkSMSessionClient is a remote-session that connects to a remote server. vtkSMSessionClient supports both connecting a pvserver as well as connecting a pvdataserver/pvrenderserver.
Definition at line 23 of file vtkSMSessionClient.h.
Definition at line 27 of file vtkSMSessionClient.h.
◆ vtkSMSessionClient()
vtkSMSessionClient::vtkSMSessionClient ( )
◆ ~vtkSMSessionClient()
vtkSMSessionClient::~vtkSMSessionClient ( )
static vtkSMSessionClient* vtkSMSessionClient::New ( )
virtual const char* vtkSMSessionClient::GetClassName ( )
Reimplemented from vtkSMSession.
static int vtkSMSessionClient::IsTypeOf ( const char *  type)
virtual int vtkSMSessionClient::IsA ( const char *  type)
static vtkSMSessionClient* vtkSMSessionClient::SafeDownCast ( vtkObject *  o)
void vtkSMSessionClient::PrintSelf ( ostream &  os,
◆ GetURI()
const char* vtkSMSessionClient::GetURI ( )
inlineoverridevirtual
Definition at line 33 of file vtkSMSessionClient.h.
◆ Connect() [1/2]
virtual bool vtkSMSessionClient::Connect ( const char *  url,
int  timeout = 60
inlinevirtual
URL can be of the following format: cs://<pvserver-host>:<pvserver-port> cdsrs://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In both cases the port is optional. When not provided default pvserver/pvdataserver port // is 11111, while default pvrenderserver port is 22221. For reverse connect i.e. the client waits for the server to connect back, simply add "rc" to the protocol e.g. csrc://<pvserver-host>:<pvserver-port> cdsrsrc://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In this case, the hostname is irrelevant and is ignored. Wait for timeout seconds for the connection. Default is 60, 0 means no retry. -1 means infinite retries. The callback should return true, if the connection should continue trying to connect, else return false to abort. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
Definition at line 55 of file vtkSMSessionClient.h.
◆ Connect() [2/2]
int  timeout,
bool(*)()  callback,
vtkNetworkAccessManager::ConnectionResult &  connectionResult
◆ GetIsAlive()
bool vtkSMSessionClient::GetIsAlive ( )
◆ GetProcessRoles()
ServerFlags vtkSMSessionClient::GetProcessRoles ( )
e.g. if the current processes acts as a data-server and a render-server, it returns DATA_SERVER | RENDER_SERVER. Overridden to return CLIENT since this process only acts as the client.
Definition at line 75 of file vtkSMSessionClient.h.
◆ GetController()
vtkMultiProcessController* vtkSMSessionClient::GetController ( ServerFlags  processType)
Value must be DATA_SERVER_ROOT or RENDER_SERVER_ROOT or CLIENT.
Reimplemented from vtkPVSession.
◆ GetServerInformation()
vtkPVServerInformation* vtkSMSessionClient::GetServerInformation ( )
These include server-side capabilities as well as server-side command line arguments e.g. tile-display parameters. Use this method to obtain the server-side information. Overridden to provide return the information gathered from data-server and render-server.
Reimplemented from vtkPVSessionBase.
Definition at line 91 of file vtkSMSessionClient.h.
◆ Initialize()
void vtkSMSessionClient::Initialize ( )
Initialize the data-server-render-server connection, if applicable.
◆ PushState()
void vtkSMSessionClient::PushState ( vtkSMMessage *  msg)
Push the state.
◆ PullState()
void vtkSMSessionClient::PullState ( vtkSMMessage *  message)
Push the state.
◆ ExecuteStream()
void vtkSMSessionClient::ExecuteStream ( vtkTypeUInt32  location,
const vtkClientServerStream &  stream,
bool  ignore_errors = false
Push the state.
◆ GetLastResult()
const vtkClientServerStream& vtkSMSessionClient::GetLastResult ( vtkTypeUInt32  location)
Push the state.
◆ SetAbortConnect()
virtual void vtkSMSessionClient::SetAbortConnect ( bool  )
Application can add observer to this signal and set this flag to true, if it wants to abort the wait for the server.
◆ CloseSession()
void vtkSMSessionClient::CloseSession ( )
◆ GatherInformation()
bool vtkSMSessionClient::GatherInformation ( vtkTypeUInt32  location,
vtkPVInformation *  information,
location identifies the processes to gather the information from. Overridden to fetch the information from server if needed, otherwise it's handled locally.
◆ GetNumberOfProcesses()
int vtkSMSessionClient::GetNumberOfProcesses ( vtkTypeUInt32  servers)
If more than 1 server is identified, than it returns the maximum number of processes e.g. is servers = DATA_SERVER | RENDER_SERVER and there are 3 data-server nodes and 2 render-server nodes, then this method will return 3.
◆ IsMPIInitialized()
bool vtkSMSessionClient::IsMPIInitialized ( vtkTypeUInt32  servers)
If more than 1 server is identified it will return true only if all of the servers have MPI initialized.
◆ PreDisconnection()
void vtkSMSessionClient::PreDisconnection ( )
◆ IsNotBusy()
virtual bool vtkSMSessionClient::IsNotBusy ( )
◆ StartBusyWork()
virtual void vtkSMSessionClient::StartBusyWork ( )
◆ EndBusyWork()
virtual void vtkSMSessionClient::EndBusyWork ( )
◆ GetCollaborationManager()
vtkSMCollaborationManager* vtkSMSessionClient::GetCollaborationManager ( )
◆ PrepareProgressInternal()
void vtkSMSessionClient::PrepareProgressInternal ( )
Overridden to relay to the server(s).
◆ CleanupPendingProgressInternal()
void vtkSMSessionClient::CleanupPendingProgressInternal ( )
◆ GetConnectID()
int vtkSMSessionClient::GetConnectID ( )
◆ GetNextGlobalUniqueIdentifier()
vtkTypeUInt32 vtkSMSessionClient::GetNextGlobalUniqueIdentifier ( )
This implementation works locally. without any code distribution. To support the distributed architecture the vtkSMSessionClient override those method to call them on the DATA_SERVER vtkPVSessionBase instance.
◆ GetNextChunkGlobalUniqueIdentifier()
vtkTypeUInt32 vtkSMSessionClient::GetNextChunkGlobalUniqueIdentifier ( vtkTypeUInt32  chunkSize)
1 = ReverveNextIdChunk(10); | Reserved ids [1,2,3,4,5,6,7,8,9,10] 11 = ReverveNextIdChunk(10);| Reserved ids [11,12,13,14,15,16,17,18,19,20] b = a + 10;
◆ OnServerNotificationMessageRMI()
void vtkSMSessionClient::OnServerNotificationMessageRMI ( void *  message,
int  message_length
◆ SetRenderServerController()
void vtkSMSessionClient::SetRenderServerController ( vtkMultiProcessController *  )
◆ SetDataServerController()
void vtkSMSessionClient::SetDataServerController ( vtkMultiProcessController *  )
◆ SetupDataServerRenderServerConnection()
void vtkSMSessionClient::SetupDataServerRenderServerConnection ( )
◆ UnRegisterSIObject()
void vtkSMSessionClient::UnRegisterSIObject ( vtkSMMessage *  msg)
overrideprotectedvirtual
(SIObject)
◆ RegisterSIObject()
void vtkSMSessionClient::RegisterSIObject ( vtkSMMessage *  msg)
(SIObject)
◆ GetRealLocation()
vtkTypeUInt32 vtkSMSessionClient::GetRealLocation ( vtkTypeUInt32  )
◆ SetURI()
virtual void vtkSMSessionClient::SetURI ( const char *  )
protectedvirtual
◆ OnWrongTagEvent()
bool vtkSMSessionClient::OnWrongTagEvent ( vtkObject *  caller,
void *  calldata
Return true if the event was handle locally.
◆ OnConnectionLost()
virtual void vtkSMSessionClient::OnConnectionLost ( vtkObject *  caller,
void *  calldata
protectedvirtual
◆ RenderServerController
vtkMultiProcessController* vtkSMSessionClient::RenderServerController
Definition at line 243 of file vtkSMSessionClient.h.
◆ DataServerController
vtkMultiProcessController* vtkSMSessionClient::DataServerController
Definition at line 244 of file vtkSMSessionClient.h.
◆ DataServerInformation
vtkPVServerInformation* vtkSMSessionClient::DataServerInformation
Definition at line 246 of file vtkSMSessionClient.h.
◆ RenderServerInformation
vtkPVServerInformation* vtkSMSessionClient::RenderServerInformation
Definition at line 247 of file vtkSMSessionClient.h.
◆ ServerInformation
vtkPVServerInformation* vtkSMSessionClient::ServerInformation
Definition at line 248 of file vtkSMSessionClient.h.
◆ ServerLastInvokeResult
vtkClientServerStream* vtkSMSessionClient::ServerLastInvokeResult
Definition at line 249 of file vtkSMSessionClient.h.
◆ AbortConnect
bool vtkSMSessionClient::AbortConnect
Definition at line 251 of file vtkSMSessionClient.h.
◆ URI
char* vtkSMSessionClient::URI
Definition at line 254 of file vtkSMSessionClient.h.
◆ NoMoreDelete
bool vtkSMSessionClient::NoMoreDelete
Definition at line 260 of file vtkSMSessionClient.h.
◆ CollaborationCommunicator
vtkSMCollaborationManager* vtkSMSessionClient::CollaborationCommunicator
Definition at line 263 of file vtkSMSessionClient.h.
