Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
vtkSIProxyDefinitionManager Class Reference
object responsible for managing XML proxies definitions More...
#include <vtkSIProxyDefinitionManager.h>
Inheritance diagram for vtkSIProxyDefinitionManager:
Collaboration diagram for vtkSIProxyDefinitionManager:
struct  RegisteredDefinitionInformation
 Information object used in Event notification. More...
enum  Events { ProxyDefinitionsUpdated = 2000, CompoundProxyDefinitionsUpdated = 2001 }
enum  { ALL_DEFINITIONS = 0, CORE_DEFINITIONS = 1, CUSTOM_DEFINITIONS = 2 }
 Return a new configured iterator for traversing a set of proxy definition for all the available groups. More...
typedef vtkSIObject Superclass
- Public Types inherited from vtkSIObject
bool HasDefinition (const char *groupName, const char *proxyName)
 Return true if the XML Definition was found. More...
void RemoveCustomProxyDefinition (const char *group, const char *name)
 Given its name, remove a custom proxy definition. More...
void ClearCustomProxyDefinitions ()
 Remove all registered custom proxy definitions. More...
void SaveCustomProxyDefinitions (vtkPVXMLElement *root)
 Save registered custom proxy definitions. More...
VTK_NEWINSTANCE vtkPVProxyDefinitionIterator * NewIterator (int scope=ALL_DEFINITIONS)
 Return a NEW instance of vtkPVProxyDefinitionIterator configured to get through all the definition available for the requested scope. More...
vtkPVProxyDefinitionIterator * NewSingleGroupIterator (const char *groupName, int scope=ALL_DEFINITIONS)
 Return a new configured iterator for traversing a set of proxy definition for only one GroupName. More...
void EnableXMLProxyDefnitionUpdate (bool)
 Deactivate the modification of the ProxyDefinitions for that given vtkSIProxyDefinitionManager to make sure update only come from the remote server and not plugin loaded on the client. More...
void Push (vtkSMMessage *msg) override
 Push a new state to the underneath implementation The provided implementation just store the message and return it at the Pull one. More...
void Pull (vtkSMMessage *msg) override
 Pull the current state of the underneath implementation The provided implementation update the given message with the one that has been previously pushed. More...
vtkPVXMLElement * GetProxyDefinition (const char *group, const char *name, bool throwError)
 Returns a registered proxy definition or return a nullptr otherwise. More...
vtkPVXMLElement * GetProxyDefinition (const char *group, const char *name)
vtkPVXMLElement * GetCollapsedProxyDefinition (const char *group, const char *name, const char *subProxyName, bool throwError)
 Returns the same thing as GetProxyDefinition in a flatten manner. More...
vtkPVXMLElement * GetCollapsedProxyDefinition (const char *group, const char *name, const char *subProxyName)
void AddCustomProxyDefinition (const char *group, const char *name, vtkPVXMLElement *top)
 Add a custom proxy definition. More...
void AddCustomProxyDefinition (const char *groupName, const char *proxyName, const char *xmlcontents)
void LoadCustomProxyDefinitions (vtkPVXMLElement *root)
 Load custom proxy definitions and register them. More...
void LoadCustomProxyDefinitionsFromString (const char *xmlContent)
bool LoadConfigurationXML (vtkPVXMLElement *root)
 Loads server-manager configuration xml. More...
bool LoadConfigurationXMLFromString (const char *xmlContent)
- Public Member Functions inherited from vtkSIObject
virtual void AboutToDelete ()
 This method is called before the deletion of the SIObject. More...
virtual void Initialize (vtkPVSessionCore *session)
 Initializes the instance. More...
vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the Interpreter. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid) const
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void SetGlobalID (vtkTypeUInt32)
 Get/Set the global id for this object. More...
static vtkSIProxyDefinitionManager * New ()
static vtkSIProxyDefinitionManager * SafeDownCast (vtkObject *o)
static vtkTypeUInt32 GetReservedGlobalID ()
 Returns the ID reserved for the proxy definition manager. More...
static void PatchXMLProperty (vtkPVXMLElement *propElement)
 For now we dynamically convert InformationHelper into the correct si_class and attribute sets. More...
- Static Public Member Functions inherited from vtkSIObject
static vtkSIObject * New ()
static vtkSIObject * SafeDownCast (vtkObject *o)
 vtkSIProxyDefinitionManager ()
 ~vtkSIProxyDefinitionManager () override
void AttachShowInMenuHintsToProxy (vtkPVXMLElement *proxy)
 Helper method that add a ShowInMenu Hint for a proxy definition. More...
void AttachShowInMenuHintsToProxyFromProxyGroups (vtkPVXMLElement *root)
 Helper method that add a ShowInMenu Hint for any proxy definition that lie in a sources or filters group. More...
void AddElement (const char *groupName, const char *proxyName, vtkPVXMLElement *element)
 Called by the XML parser to add an element from which a proxy can be created. More...
bool AddCustomProxyDefinitionInternal (const char *group, const char *name, vtkPVXMLElement *top)
 Implementation for add custom proxy definition. More...
void MergeProxyDefinition (vtkPVXMLElement *element, vtkPVXMLElement *elementToFill)
 Integrate a ProxyDefinition into another ProxyDefinition by merging them. More...
void InvalidateCollapsedDefinition ()
 Method used to clear the Flatten version of the definition. More...
vtkPVXMLElement * GetProxyElement (const char *groupName, const char *proxyName)
 Given the proxy name and group name, returns the XML element for the proxy. More...
vtkPVXMLElement * ExtractSubProxy (vtkPVXMLElement *proxyDefinition, const char *subProxyName)
 Convenient method used to extract sub-proxy definition inside a proxy definition. More...
void InvokeCustomDefitionsUpdated ()
 Called when custom definitions are updated. More...
bool LoadConfigurationXML (vtkPVXMLElement *root, bool attachShowInMenuHints)
bool LoadConfigurationXMLFromString (const char *xmlContent, bool attachShowInMenuHints)
void OnPluginLoaded (vtkObject *caller, unsigned long event, void *calldata)
 Callback called when a plugin is loaded. More...
void HandlePlugin (vtkPVPlugin *)
- Protected Member Functions inherited from vtkSIObject
 vtkSIObject ()
 ~vtkSIObject () override
- Protected Attributes inherited from vtkSIObject
vtkWeakPointer< vtkClientServerInterpreter > Interpreter
vtkWeakPointer< vtkPVSessionCore > SessionCore
vtkSMMessage * LastPushedMessage
vtkTypeUInt32 GlobalID
vtkSIProxyDefinitionManager is a class that manages XML proxies definition. It maintains a map of vtkPVXMLElement (populated by the XML parser) from which it can extract Hint, Documentation, Properties, Domains definition.
This class fires the following events:
Definition at line 40 of file vtkSIProxyDefinitionManager.h.
Definition at line 44 of file vtkSIProxyDefinitionManager.h.
◆ Events
Enumerator
Definition at line 148 of file vtkSIProxyDefinitionManager.h.
◆ anonymous enum
anonymous enum
Scope values: 0 : ALL (default in case) 1 : CORE_DEFINITIONS 2 : CUSTOM_DEFINITIONS
Enumerator
ALL_DEFINITIONS
CORE_DEFINITIONS
CUSTOM_DEFINITIONS
Definition at line 163 of file vtkSIProxyDefinitionManager.h.
◆ vtkSIProxyDefinitionManager()
vtkSIProxyDefinitionManager::vtkSIProxyDefinitionManager ( )
◆ ~vtkSIProxyDefinitionManager()
vtkSIProxyDefinitionManager::~vtkSIProxyDefinitionManager ( )
static vtkSIProxyDefinitionManager* vtkSIProxyDefinitionManager::New ( )
virtual const char* vtkSIProxyDefinitionManager::GetClassName ( )
Reimplemented from vtkSIObject.
static int vtkSIProxyDefinitionManager::IsTypeOf ( const char *  type)
virtual int vtkSIProxyDefinitionManager::IsA ( const char *  type)
static vtkSIProxyDefinitionManager* vtkSIProxyDefinitionManager::SafeDownCast ( vtkObject *  o)
void vtkSIProxyDefinitionManager::PrintSelf ( ostream &  os,
◆ GetReservedGlobalID()
static vtkTypeUInt32 vtkSIProxyDefinitionManager::GetReservedGlobalID ( )
◆ PatchXMLProperty()
static void vtkSIProxyDefinitionManager::PatchXMLProperty ( vtkPVXMLElement *  propElement)
THIS CODE SHOULD BE REMOVED once InformationHelper have been removed from legacy XML
◆ GetProxyDefinition() [1/2]
vtkPVXMLElement* vtkSIProxyDefinitionManager::GetProxyDefinition ( const char *  group,
const char *  name,
bool  throwError
Moreover, error can be throw if the definition was not found if the flag throwError is true.
◆ GetProxyDefinition() [2/2]
const char *  name
inline
Definition at line 67 of file vtkSIProxyDefinitionManager.h.
◆ HasDefinition()
bool vtkSIProxyDefinitionManager::HasDefinition ( const char *  groupName,
const char *  proxyName
◆ GetCollapsedProxyDefinition() [1/2]
vtkPVXMLElement* vtkSIProxyDefinitionManager::GetCollapsedProxyDefinition ( const char *  group,
const char *  name,
const char *  subProxyName,
bool  throwError
By flatten, we mean that the class hierarchy has been walked and merged into a single vtkPVXMLElement definition.
◆ GetCollapsedProxyDefinition() [2/2]
const char *  name,
inline
Definition at line 87 of file vtkSIProxyDefinitionManager.h.
◆ AddCustomProxyDefinition() [1/2]
void vtkSIProxyDefinitionManager::AddCustomProxyDefinition ( const char *  group,
const char *  name,
vtkPVXMLElement *  top
Custom definitions are NOT ALLOWED to overrive or overlap any ProxyDefinition that has been defined by parsing server manager proxy configuration files. This can be a compound proxy definition (look at vtkSMCompoundSourceProxy.h) or a regular proxy definition. For all practical purposes, there's no difference between a proxy definition added using this method or by parsing a server manager configuration file.
◆ AddCustomProxyDefinition() [2/2]
void vtkSIProxyDefinitionManager::AddCustomProxyDefinition ( const char *  groupName,
const char *  proxyName,
const char *  xmlcontents
◆ RemoveCustomProxyDefinition()
void vtkSIProxyDefinitionManager::RemoveCustomProxyDefinition ( const char *  group,
const char *  name
Note that this can only be used to remove definitions added using AddCustomProxyDefinition(), cannot be used to remove definitions loaded using vtkSMXMLParser.
◆ ClearCustomProxyDefinitions()
void vtkSIProxyDefinitionManager::ClearCustomProxyDefinitions ( )
◆ LoadCustomProxyDefinitions()
void vtkSIProxyDefinitionManager::LoadCustomProxyDefinitions ( vtkPVXMLElement *  root)
◆ LoadCustomProxyDefinitionsFromString()
void vtkSIProxyDefinitionManager::LoadCustomProxyDefinitionsFromString ( const char *  xmlContent)
◆ SaveCustomProxyDefinitions()
void vtkSIProxyDefinitionManager::SaveCustomProxyDefinitions ( vtkPVXMLElement *  root)
The caller must release the reference to the returned vtkPVXMLElement.
◆ LoadConfigurationXML() [1/2]
bool vtkSIProxyDefinitionManager::LoadConfigurationXML ( vtkPVXMLElement *  root)
◆ LoadConfigurationXMLFromString() [1/2]
bool vtkSIProxyDefinitionManager::LoadConfigurationXMLFromString ( const char *  xmlContent)
◆ NewIterator()
VTK_NEWINSTANCE vtkPVProxyDefinitionIterator* vtkSIProxyDefinitionManager::NewIterator ( int  scope = ALL_DEFINITIONS)
Possible scope defined as enum inside vtkSIProxyDefinitionManager: ALL_DEFINITIONS=0 / CORE_DEFINITIONS=1 / CUSTOM_DEFINITIONS=2 Some extra restriction can be set directly on the iterator itself by setting a set of GroupName...
◆ NewSingleGroupIterator()
vtkPVProxyDefinitionIterator* vtkSIProxyDefinitionManager::NewSingleGroupIterator ( const char *  groupName,
◆ EnableXMLProxyDefnitionUpdate()
void vtkSIProxyDefinitionManager::EnableXMLProxyDefnitionUpdate ( bool  )
◆ Push()
void vtkSIProxyDefinitionManager::Push ( vtkSMMessage *  msg)
◆ Pull()
void vtkSIProxyDefinitionManager::Pull ( vtkSMMessage *  msg)
◆ AttachShowInMenuHintsToProxy()
void vtkSIProxyDefinitionManager::AttachShowInMenuHintsToProxy ( vtkPVXMLElement *  proxy)
This allow that given proxy to show up inside the Sources/Filters menu inside the UI.
◆ AttachShowInMenuHintsToProxyFromProxyGroups()
void vtkSIProxyDefinitionManager::AttachShowInMenuHintsToProxyFromProxyGroups ( vtkPVXMLElement *  root)
See also
method AttachShowInMenuHintsToProxy
◆ LoadConfigurationXML() [2/2]
bool vtkSIProxyDefinitionManager::LoadConfigurationXML ( vtkPVXMLElement *  root,
Those method are protected as they allow to automatically add some extra hints for those loaded definition set. This is essentially used when proxy get loaded as legacy proxy don't have those expected Hints. FIXME: Once those pluging get updated, this extra hint attachment might be removed.
◆ LoadConfigurationXMLFromString() [2/2]
bool vtkSIProxyDefinitionManager::LoadConfigurationXMLFromString ( const char *  xmlContent,
◆ OnPluginLoaded()
void vtkSIProxyDefinitionManager::OnPluginLoaded ( vtkObject *  caller,
void *  calldata
◆ HandlePlugin()
void vtkSIProxyDefinitionManager::HandlePlugin ( vtkPVPlugin *  )
◆ AddElement()
void vtkSIProxyDefinitionManager::AddElement ( const char *  groupName,
vtkPVXMLElement *  element
Called during parsing.
◆ AddCustomProxyDefinitionInternal()
bool vtkSIProxyDefinitionManager::AddCustomProxyDefinitionInternal ( const char *  group,
const char *  name,
◆ MergeProxyDefinition()
void vtkSIProxyDefinitionManager::MergeProxyDefinition ( vtkPVXMLElement *  element,
vtkPVXMLElement *  elementToFill
If properties are overridden is the last property that will last. So when we build a merged definition hierarchy, we should start from the root and go down.
◆ InvalidateCollapsedDefinition()
void vtkSIProxyDefinitionManager::InvalidateCollapsedDefinition ( )
This will force its recomputation when needed. This should be called each time new definition get added. (Not the Custom one since those should NOT conflict with the core definitions.)
◆ GetProxyElement()
vtkPVXMLElement* vtkSIProxyDefinitionManager::GetProxyElement ( const char *  groupName,
◆ ExtractSubProxy()
vtkPVXMLElement* vtkSIProxyDefinitionManager::ExtractSubProxy ( vtkPVXMLElement *  proxyDefinition,
If (subProxyName == nullptr) return proxyDefinition;
◆ InvokeCustomDefitionsUpdated()
void vtkSIProxyDefinitionManager::InvokeCustomDefitionsUpdated ( )
Fires appropriate events.
