vtkPVSessionBase Class Referenceabstract
#include <vtkPVSessionBase.h>
Inheritance diagram for vtkPVSessionBase:
Collaboration diagram for vtkPVSessionBase:
enum  EventIds { RegisterRemoteObjectEvent = 1234, UnRegisterRemoteObjectEvent = 4321, ProcessingRemoteEnd = 2143, ConnectionLost = 6789 }
typedef vtkPVSession Superclass
- Public Types inherited from vtkPVSession
enum  ServerFlags {
  NONE = 0, DATA_SERVER = 0x01, DATA_SERVER_ROOT = 0x02, RENDER_SERVER = 0x04,
  RENDER_SERVER_ROOT = 0x08, SERVERS = DATA_SERVER | RENDER_SERVER, CLIENT = 0x10, CLIENT_AND_SERVERS = DATA_SERVER | CLIENT | RENDER_SERVER
typedef vtkSession Superclass
- Public Types inherited from vtkSession
ServerFlags GetProcessRoles () override
 Returns a ServerFlags indicate the nature of the current processes. More...
vtkPVServerInformation * GetServerInformation () override
 vtkPVServerInformation is an information-object that provides information about the server processes. More...
vtkMPIMToNSocketConnection * GetMPIMToNSocketConnection () override
 This is socket connection, if any to communicate between the data-server and render-server nodes. More...
virtual void PushState (vtkSMMessage *msg)
 Push the state message. More...
virtual void PullState (vtkSMMessage *msg)
 Pull the state message. More...
virtual void ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false)
 Execute a command on the given processes. More...
 Returns the response of the ExecuteStream() call from the location. More...
virtual bool GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid)
 Gather information about an object referred by the globalid. More...
virtual void NotifyAllClients (const vtkSMMessage *)=0
 Sends the message to all clients. More...
virtual void NotifyOtherClients (const vtkSMMessage *)=0
 Sends the message to all but the active client-session. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Get the ProxyDefinitionManager. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Returns a vtkSIObject or subclass given its global id, if any. More...
virtual void UnRegisterSIObject (vtkSMMessage *msg)
 Unregister server side object. More...
virtual void RegisterSIObject (vtkSMMessage *msg)
 Register server side object. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More...
virtual void GetAllRemoteObjects (vtkCollection *collection)
 Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More...
virtual vtkTypeUInt32 GetNextGlobalUniqueIdentifier ()
 Provides the next available identifier. More...
virtual vtkTypeUInt32 GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize)
 Return the first Id of the requested chunk. More...
virtual bool IsProcessingRemoteNotification ()
 This property is used to discard ignore_synchronization proxy property when we load protobuf states. More...
virtual void UseSessionCoreOf (vtkPVSessionBase *other)
 Update internal session core in order to use the one used in another session. More...
virtual vtkPVSessionCore * GetSessionCore ()
 Provides access to the session core. More...
- Public Member Functions inherited from vtkPVSession
bool HasProcessRole (vtkTypeUInt32 flag)
 Convenience method that returns true if the current session is serving the indicated role on this process. More...
virtual vtkMultiProcessController * GetController (ServerFlags processType)
 Returns the controller used to communicate with the process. More...
virtual bool IsMultiClients ()
 Allow anyone to know easily if the current session is involved in collaboration or not. More...
bool GetPendingProgress ()
 Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More...
virtual vtkPVProgressHandler * GetProgressHandler ()
 Provides access to the progress handler. More...
void PrepareProgress ()
 Should be called to begin/end receiving progresses on this session. More...
void CleanupPendingProgress ()
- Public Member Functions inherited from vtkSession
virtual bool GetIsAlive ()=0
 Returns true is this session is active/alive/valid. More...
static vtkPVSessionBase * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVSession
static vtkPVSession * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSession
static vtkSession * SafeDownCast (vtkObject *o)
 vtkPVSessionBase ()
 vtkPVSessionBase (vtkPVSessionCore *coreToUse)
 ~vtkPVSessionBase () override
void RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj)
 Register a remote object. More...
void UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location)
 Unregister a remote object. More...
vtkPVSessionCore * GetSessionCore () const
 Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More...
void SetSessionCore (vtkPVSessionCore *)
void PrepareProgressInternal () override
void CleanupPendingProgressInternal () override
- Protected Member Functions inherited from vtkPVSession
 vtkPVSession ()
 ~vtkPVSession () override
virtual bool OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata)
 Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More...
- Protected Member Functions inherited from vtkSession
 vtkSession ()
 ~vtkSession () override
virtual void Activate ()
 Subclasses must call this to mark the session active. More...
virtual void DeActivate ()
 Subclasses must call this to mark the session inactive. More...
vtkPVSessionCore * SessionCore
- Protected Attributes inherited from vtkPVSession
vtkPVProgressHandler * ProgressHandler
Friends
class vtkSMRemoteObject
class vtkSMSessionProxyManager
class vtkSMLiveInsituLinkProxy
bool ProcessingRemoteNotification
 Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More...
virtual bool StartProcessingRemoteNotification ()
virtual void StopProcessingRemoteNotification (bool previousValue)
- Protected Types inherited from vtkPVSession
enum  { EXCEPTION_EVENT_TAG = 31416 }
Abstract class used to provide the main implementation of the ParaView session methods for the following classes: vtkSMSession, vtkSMSessionClient, vtkSMSessionServer
Definition at line 27 of file vtkPVSessionBase.h.
Definition at line 30 of file vtkPVSessionBase.h.
◆ EventIds
Enumerator
ProcessingRemoteEnd
ConnectionLost
Definition at line 33 of file vtkPVSessionBase.h.
◆ vtkPVSessionBase() [1/2]
vtkPVSessionBase::vtkPVSessionBase ( )
◆ vtkPVSessionBase() [2/2]
vtkPVSessionBase::vtkPVSessionBase ( vtkPVSessionCore *  coreToUse)
◆ ~vtkPVSessionBase()
vtkPVSessionBase::~vtkPVSessionBase ( )
virtual const char* vtkPVSessionBase::GetClassName ( )
Reimplemented from vtkPVSession.
Reimplemented in vtkSMSession, vtkSMSessionClient, and vtkPVSessionServer.
static int vtkPVSessionBase::IsTypeOf ( const char *  type)
virtual int vtkPVSessionBase::IsA ( const char *  type)
static vtkPVSessionBase* vtkPVSessionBase::SafeDownCast ( vtkObject *  o)
void vtkPVSessionBase::PrintSelf ( ostream &  os,
◆ GetProcessRoles()
ServerFlags vtkPVSessionBase::GetProcessRoles ( )
e.g. if the current processes acts as a data-server and a render-server, it returns DATA_SERVER | RENDER_SERVER. The implementation provided is suitable for server processes such as pvserver, pvdataserver (both root and satellites).
Reimplemented in vtkSMSession, and vtkSMSessionClient.
◆ GetServerInformation()
vtkPVServerInformation* vtkPVSessionBase::GetServerInformation ( )
These include server-side capabilities as well as server-side command line arguments e.g. tile-display parameters. Use this method to obtain the server-side information. Overridden to provide support for non-remote-server case. We simply read the local process information and return it.
Implements vtkPVSession.
Reimplemented in vtkSMSessionClient.
◆ GetMPIMToNSocketConnection()
vtkMPIMToNSocketConnection* vtkPVSessionBase::GetMPIMToNSocketConnection ( )
Forwarded for vtkPVSessionCore.
◆ PushState()
virtual void vtkPVSessionBase::PushState ( vtkSMMessage *  msg)
◆ PullState()
virtual void vtkPVSessionBase::PullState ( vtkSMMessage *  msg)
◆ ExecuteStream()
virtual void vtkPVSessionBase::ExecuteStream ( vtkTypeUInt32  location,
const vtkClientServerStream &  stream,
bool  ignore_errors = false
Use GetLastResult() to obtain the last result after the command stream is evaluated. Once can set ignore_errors to true, to ignore any interpreting errors.
◆ GetLastResult()
virtual const vtkClientServerStream& vtkPVSessionBase::GetLastResult ( vtkTypeUInt32  location)
Note if location refers to multiple processes, then the reply is only fetched from the "closest" process.
◆ GatherInformation()
virtual bool vtkPVSessionBase::GatherInformation ( vtkTypeUInt32  location,
vtkPVInformation *  information,
location identifies the processes to gather the information from.
◆ NotifyAllClients()
virtual void vtkPVSessionBase::NotifyAllClients ( const vtkSMMessage *  )
pure virtual
Implemented in vtkSMSession, and vtkPVSessionServer.
◆ NotifyOtherClients()
virtual void vtkPVSessionBase::NotifyOtherClients ( const vtkSMMessage *  )
pure virtual
◆ GetSessionCore() [1/2]
virtual vtkPVSessionCore* vtkPVSessionBase::GetSessionCore ( )
◆ GetProxyDefinitionManager()
vtkSIProxyDefinitionManager* vtkPVSessionBase::GetProxyDefinitionManager ( )
◆ GetSIObject()
vtkSIObject* vtkPVSessionBase::GetSIObject ( vtkTypeUInt32  globalid)
◆ UnRegisterSIObject()
virtual void vtkPVSessionBase::UnRegisterSIObject ( vtkSMMessage *  msg)
(SIObject)
◆ RegisterSIObject()
virtual void vtkPVSessionBase::RegisterSIObject ( vtkSMMessage *  msg)
(SIObject)
◆ GetRemoteObject()
vtkObject* vtkPVSessionBase::GetRemoteObject ( vtkTypeUInt32  globalid)
◆ GetAllRemoteObjects()
virtual void vtkPVSessionBase::GetAllRemoteObjects ( vtkCollection *  collection)
◆ GetNextGlobalUniqueIdentifier()
virtual vtkTypeUInt32 vtkPVSessionBase::GetNextGlobalUniqueIdentifier ( )
This implementation works locally. without any code distribution. To support the distributed architecture the vtkSMSessionClient override those method to call them on the DATA_SERVER vtkPVSessionBase instance.
◆ GetNextChunkGlobalUniqueIdentifier()
virtual vtkTypeUInt32 vtkPVSessionBase::GetNextChunkGlobalUniqueIdentifier ( vtkTypeUInt32  chunkSize)
1 = ReverveNextIdChunk(10); | Reserved ids [1,2,3,4,5,6,7,8,9,10] 11 = ReverveNextIdChunk(10);| Reserved ids [11,12,13,14,15,16,17,18,19,20] b = a + 10;
◆ IsProcessingRemoteNotification()
virtual bool vtkPVSessionBase::IsProcessingRemoteNotification ( )
Therefore, if we load any camera state while that property is true, this won't affect the proxy/property state at all. It will simply remain the same.
◆ UseSessionCoreOf()
virtual void vtkPVSessionBase::UseSessionCoreOf ( vtkPVSessionBase *  other)
◆ GetSessionCore() [2/2]
vtkPVSessionCore* vtkPVSessionBase::GetSessionCore ( ) const
◆ SetSessionCore()
void vtkPVSessionBase::SetSessionCore ( vtkPVSessionCore *  )
◆ PrepareProgressInternal()
void vtkPVSessionBase::PrepareProgressInternal ( )
overrideprotectedvirtual
Overridden to relay to the server(s).
◆ CleanupPendingProgressInternal()
void vtkPVSessionBase::CleanupPendingProgressInternal ( )
◆ StartProcessingRemoteNotification()
virtual bool vtkPVSessionBase::StartProcessingRemoteNotification ( )
protectedvirtual
◆ StopProcessingRemoteNotification()
virtual void vtkPVSessionBase::StopProcessingRemoteNotification ( bool  previousValue)
protectedvirtual
◆ RegisterRemoteObject()
void vtkPVSessionBase::RegisterRemoteObject ( vtkTypeUInt32  globalid,
vtkObject *  obj
◆ UnRegisterRemoteObject()
void vtkPVSessionBase::UnRegisterRemoteObject ( vtkTypeUInt32  globalid,
◆ vtkSMRemoteObject
friend class vtkSMRemoteObject
friend
Definition at line 225 of file vtkPVSessionBase.h.
◆ vtkSMSessionProxyManager
friend class vtkSMSessionProxyManager
friend
Definition at line 226 of file vtkPVSessionBase.h.
◆ vtkSMLiveInsituLinkProxy
friend class vtkSMLiveInsituLinkProxy
friend
Definition at line 227 of file vtkPVSessionBase.h.
◆ ProcessingRemoteNotification
bool vtkPVSessionBase::ProcessingRemoteNotification
Definition at line 237 of file vtkPVSessionBase.h.
◆ SessionCore
vtkPVSessionCore* vtkPVSessionBase::SessionCore
Definition at line 250 of file vtkPVSessionBase.h.
