vtkNetworkAccessManager Class Referenceabstract
#include <vtkNetworkAccessManager.h>
Inheritance diagram for vtkNetworkAccessManager:
Collaboration diagram for vtkNetworkAccessManager:
enum  ConnectionResult {
  ConnectionResult::CONNECTION_SUCCESS, ConnectionResult::CONNECTION_TIMEOUT, ConnectionResult::CONNECTION_ABORT, ConnectionResult::CONNECTION_HANDSHAKE_ERROR,
  ConnectionResult::CONNECTION_FAILURE
 Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was sucessfull CONNECTION_TIMEOUT: After spending a specified amount of time, no connection was initiated CONNECTION_ABORT: User aborted the connection before it was successful or timed out CONNECTION_HANDSHAKE_ERROR: Connection was iniated but the handshake failed CONNECTION_FAILURE: Unspecified connection error. More...
virtual void AbortPendingConnection ()=0
 Used to abort pending connection creation, if any. More...
virtual int ProcessEvents (unsigned long timeout_msecs)=0
 Process any network activity. More...
virtual bool GetNetworkEventsAvailable ()=0
 Peeks to check if any activity is available. More...
virtual bool GetPendingConnectionsPresent ()=0
 Returns true is the manager is currently waiting for any connections. More...
virtual void DisableFurtherConnections (int port, bool disable)=0
 Enable/disable further connections for given port. More...
virtual bool GetWrongConnectID ()=0
 Returns true if the last check of connect ids was wrong. More...
virtual vtkMultiProcessController * NewConnection (const char *url)
 Creates a new connection given the url. More...
virtual vtkMultiProcessController * NewConnection (const char *url, ConnectionResult &result)=0
static vtkNetworkAccessManager * SafeDownCast (vtkObject *o)
 vtkNetworkAccessManager ()
 ~vtkNetworkAccessManager () override
vtkNetworkAccessManager is used to create new connections and monitor activity of those connections. This is an abstract class that defines the interface. Concrete implementations of this class can be written to support tcp/ip socket or ssl or ssh based network connections among processes.
Definition at line 20 of file vtkNetworkAccessManager.h.
Definition at line 23 of file vtkNetworkAccessManager.h.
◆ ConnectionResult
Enumerator
CONNECTION_SUCCESS
CONNECTION_TIMEOUT
CONNECTION_ABORT
CONNECTION_FAILURE
Definition at line 34 of file vtkNetworkAccessManager.h.
◆ vtkNetworkAccessManager()
vtkNetworkAccessManager::vtkNetworkAccessManager ( )
◆ ~vtkNetworkAccessManager()
vtkNetworkAccessManager::~vtkNetworkAccessManager ( )
virtual const char* vtkNetworkAccessManager::GetClassName ( )
Reimplemented in vtkTCPNetworkAccessManager.
static int vtkNetworkAccessManager::IsTypeOf ( const char *  type)
virtual int vtkNetworkAccessManager::IsA ( const char *  type)
static vtkNetworkAccessManager* vtkNetworkAccessManager::SafeDownCast ( vtkObject *  o)
void vtkNetworkAccessManager::PrintSelf ( ostream &  os,
◆ NewConnection() [1/2]
virtual vtkMultiProcessController* vtkNetworkAccessManager::NewConnection ( const char *  url)
inlinevirtual
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>://<address>
  • tcp://<hostname>:<port>
  • tcp://localhost:<port>/listen – listen for connection on port.
  • tcp://localhost:<port>/listenmultiple – listen for multiple Examples:
  • tcp://medea:12345
  • tcp://localhost:12345/listen
  • ssh://utkarsh@medea
  • http://kitware-server/session?id=12322&authorization=12
Definition at line 72 of file vtkNetworkAccessManager.h.
◆ NewConnection() [2/2]
virtual vtkMultiProcessController* vtkNetworkAccessManager::NewConnection ( const char *  url,
ConnectionResult &  result
pure virtual
  • tcp://medea:12345
Implemented in vtkTCPNetworkAccessManager.
◆ AbortPendingConnection()
virtual void vtkNetworkAccessManager::AbortPendingConnection ( )
pure virtual
Refer to NewConnection() for details.
◆ ProcessEvents()
virtual int vtkNetworkAccessManager::ProcessEvents ( unsigned long  timeout_msecs)
pure virtual
◆ GetNetworkEventsAvailable()
virtual bool vtkNetworkAccessManager::GetNetworkEventsAvailable ( )
pure virtual
When this call returns true, ProcessEvents() will always result in some activity processing if called afterword.
◆ GetPendingConnectionsPresent()
virtual bool vtkNetworkAccessManager::GetPendingConnectionsPresent ( )
pure virtual
◆ DisableFurtherConnections()
virtual void vtkNetworkAccessManager::DisableFurtherConnections ( int  port,
bool  disable
pure virtual
◆ GetWrongConnectID()
virtual bool vtkNetworkAccessManager::GetWrongConnectID ( )
pure virtual
