Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | Friends | List of all members
vtkPVProgressHandler Class Reference
progress handler. More...
#include <vtkPVProgressHandler.h>
Inheritance diagram for vtkPVProgressHandler:
Collaboration diagram for vtkPVProgressHandler:
void RegisterProgressEvent (vtkObject *object, int id)
 Listen to progress events from the object. More...
void PrepareProgress ()
 This method resets all the progress counters and prepares progress reporting. More...
void AddHandlers ()
 This method add wrong tag event handlers and rmi call back for progress related mathods. More...
bool GetEnableProgress ()
 Get whether or not progress is currently enable and if this progress handler is ready to receive progress events. More...
void CleanupPendingProgress ()
 This method collects all outstanding progress messages. More...
void LocalCleanupPendingProgress ()
 Local cleanup of progress flags. More...
void SetSession (vtkPVSession *conn)
 Get/Set the session. More...
virtual vtkPVSession * GetSession ()
virtual void SetProgressInterval (double)
 Get/Set the progress interval in seconds. More...
virtual double GetProgressInterval ()
virtual char * GetLastProgressText ()
 These are only valid in handler for the vtkCommand::ProgressEvent. More...
virtual int GetLastProgress ()
static vtkPVProgressHandler * New ()
static vtkPVProgressHandler * SafeDownCast (vtkObject *o)
Protected Types
enum  TAGS { CLEANUP_TAG = 188969, PROGRESS_EVENT_TAG = 188970, MESSAGE_EVENT_TAG = 188971 }
enum  RMI_TAGS { CLEANUP_TAG_RMI = 188972, MESSAGE_EVENT_TAG_RMI = 188973 }
 vtkPVProgressHandler ()
 ~vtkPVProgressHandler () override
void RefreshProgress (const char *progress_text, double progress)
 Update the last progress and progress text and invokes a progress event. More...
vtkPVSession * Session
double ProgressInterval
Friends
class RMICallback
progress handler.
vtkPVProgressHandler handles the progress messages. It handles progress in all configurations single process, client-server. It must be noted that when running in parallel, progress updates are fetched from the root node. Due to performance reasons, we no longer collect progress events (or messages) from satellites, only root-node events are reported back to the client. While this may not faithfully report the progress, this avoid nasty MPI issues that can be painful to debug and diagnose.
Progress events are currently not supported in multi-clients mode.
Events:
vtkCommand::StartEvent
  • fired to indicate beginning of progress handling
  • calldata: vtkPVProgressHandler* vtkCommand::ProgressEvent
  • fired to indicate a progress event.
  • calldata: vtkPVProgressHandler* vtkCommand::EndEvent
  • fired to indicate end of progress handling
Starting ParaView 5.5, vtkCommand::MessageEvent is no longer fired.
Definition at line 40 of file vtkPVProgressHandler.h.
Definition at line 44 of file vtkPVProgressHandler.h.
◆ TAGS
Enumerator
CLEANUP_TAG
PROGRESS_EVENT_TAG
MESSAGE_EVENT_TAG
Definition at line 111 of file vtkPVProgressHandler.h.
◆ RMI_TAGS
Enumerator
CLEANUP_TAG_RMI
Definition at line 118 of file vtkPVProgressHandler.h.
◆ vtkPVProgressHandler()
vtkPVProgressHandler::vtkPVProgressHandler ( )
◆ ~vtkPVProgressHandler()
vtkPVProgressHandler::~vtkPVProgressHandler ( )
static vtkPVProgressHandler* vtkPVProgressHandler::New ( )
virtual const char* vtkPVProgressHandler::GetClassName ( )
static int vtkPVProgressHandler::IsTypeOf ( const char *  type)
virtual int vtkPVProgressHandler::IsA ( const char *  type)
static vtkPVProgressHandler* vtkPVProgressHandler::SafeDownCast ( vtkObject *  o)
void vtkPVProgressHandler::PrintSelf ( ostream &  os,
◆ SetSession()
void vtkPVProgressHandler::SetSession ( vtkPVSession *  conn)
This is not reference-counted to avoid cycles.
◆ GetSession()
virtual vtkPVSession* vtkPVProgressHandler::GetSession ( )
◆ RegisterProgressEvent()
void vtkPVProgressHandler::RegisterProgressEvent ( vtkObject *  object,
int  id
◆ PrepareProgress()
void vtkPVProgressHandler::PrepareProgress ( )
All progress events before this call are ignored.
◆ AddHandlers()
void vtkPVProgressHandler::AddHandlers ( )
◆ GetEnableProgress()
bool vtkPVProgressHandler::GetEnableProgress ( )
◆ CleanupPendingProgress()
void vtkPVProgressHandler::CleanupPendingProgress ( )
All progress events after this call are ignored.
◆ LocalCleanupPendingProgress()
void vtkPVProgressHandler::LocalCleanupPendingProgress ( )
◆ SetProgressInterval()
virtual void vtkPVProgressHandler::SetProgressInterval ( double  )
Progress events occurring more frequently than this interval are skipped. Default is 0.1 seconds on client and 1 second on server and batch processes.
◆ GetProgressInterval()
virtual double vtkPVProgressHandler::GetProgressInterval ( )
◆ GetLastProgressText()
virtual char* vtkPVProgressHandler::GetLastProgressText ( )
◆ GetLastProgress()
virtual int vtkPVProgressHandler::GetLastProgress ( )
◆ RefreshProgress()
void vtkPVProgressHandler::RefreshProgress ( const char *  progress_text,
double  progress
◆ RMICallback
friend class RMICallback
friend
Definition at line 166 of file vtkPVProgressHandler.h.
◆ Session
vtkPVSession* vtkPVProgressHandler::Session
Definition at line 129 of file vtkPVProgressHandler.h.
◆ ProgressInterval
double vtkPVProgressHandler::ProgressInterval
Definition at line 130 of file vtkPVProgressHandler.h.
