Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkPVSessionCore Class Reference
#include <vtkPVSessionCore.h>
Inheritance diagram for vtkPVSessionCore:
Collaboration diagram for vtkPVSessionCore:
enum  MessageTypes {
  PUSH_STATE = 12, PULL_STATE = 13, EXECUTE_STREAM = 14, GATHER_INFORMATION = 15,
  REGISTER_SI = 16, UNREGISTER_SI = 17
virtual void PushState (vtkSMMessage *message)
 Push the state message. More...
virtual void PullState (vtkSMMessage *message)
 Pull the state message from the local SI object instances. More...
virtual void ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false)
 Execute a command on the given processes. More...
 Returns the response of the ExecuteStream() call from the location. More...
virtual void UnRegisterSIObject (vtkSMMessage *message)
 Notify that the given SIObject is not used anymore . More...
virtual void RegisterSIObject (vtkSMMessage *message)
 Notify that the given SIObject is used. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Returns a vtkSIObject or subclass given its global id, if any otherwise return nullptr;. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Return a vtkObject given its global id if any otherwise return nullptr;. More...
void RegisterRemoteObject (vtkTypeUInt32 globalid, vtkObject *obj)
 Register a remote object. More...
void UnRegisterRemoteObject (vtkTypeUInt32 globalid)
 Unregister a remote object. More...
virtual bool GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid)
 Gather information about an object referred by the globalid. More...
int GetNumberOfProcesses ()
 Returns the number of processes. More...
virtual vtkTypeUInt32 GetNextGlobalUniqueIdentifier ()
 Provides the next available identifier. More...
virtual vtkTypeUInt32 GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize)
 Return the first Id of the requested chunk. More...
void PushStateSatelliteCallback ()
void ExecuteStreamSatelliteCallback ()
void GatherInformationStatelliteCallback ()
void RegisterSIObjectSatelliteCallback ()
void UnRegisterSIObjectSatelliteCallback ()
virtual void GetAllRemoteObjects (vtkCollection *collection)
 Allow the user to fill a vtkCollection with all RemoteObjects This is useful when you want to hold a reference to them to prevent any deletion across several method call. More...
void GarbageCollectSIObject (int *clientIds, int nbClients)
 Delete SIObject that are held by clients that disappeared from the given list. More...
virtual vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the interpreter. More...
virtual vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Provides access to the proxy definition manager. More...
void SetMPIMToNSocketConnection (vtkMPIMToNSocketConnection *)
 Get/Set the socket connection used to communicate between data=server and render-server processes. More...
virtual vtkMPIMToNSocketConnection * GetMPIMToNSocketConnection ()
static vtkPVSessionCore * New ()
static vtkPVSessionCore * SafeDownCast (vtkObject *o)
Protected Types
enum  { ROOT_SATELLITE_RMI_TAG = 887822, ROOT_SATELLITE_INFO_TAG = 887823 }
 vtkPVSessionCore ()
 ~vtkPVSessionCore () override
virtual void PushStateInternal (vtkSMMessage *)
 This will create a vtkSIObject and/or execute some update on the vtkObject that it own. More...
virtual void ExecuteStreamInternal (const vtkClientServerStream &stream, bool ignore_errors)
 This will execute localy the given vtkClientServerStream either by calling method on the vtkSIObject or its internal vtkObject. More...
bool GatherInformationInternal (vtkPVInformation *information, vtkTypeUInt32 globalid)
 This will gather information on the local vtkObjects through the local vtkSIObjects. More...
bool CollectInformation (vtkPVInformation *)
 Gather information across MPI satellites. More...
virtual void RegisterSIObjectInternal (vtkSMMessage *message)
 Increment reference count of a local vtkSIObject. More...
virtual void UnRegisterSIObjectInternal (vtkSMMessage *message)
 Decrement reference count of a local vtkSIObject. More...
void OnInterpreterError (vtkObject *, unsigned long, void *calldata)
 Callback for reporting interpreter errors. More...
vtkSIProxyDefinitionManager * ProxyDefinitionManager
vtkWeakPointer< vtkMultiProcessController > ParallelController
vtkClientServerInterpreter * Interpreter
vtkMPIMToNSocketConnection * MPIMToNSocketConnection
vtkPVSessionCore is used by vtkSMSession. vtkPVSessionCore handle the communication to MPI satellites and ServerImplementation code instantiation and execution. On the other hand, the vtkSMSession dispatch the request to the right process and therefore to the right vtkPVSessionCore instance.
Definition at line 30 of file vtkPVSessionCore.h.
Definition at line 34 of file vtkPVSessionCore.h.
◆ MessageTypes
Enumerator
PUSH_STATE
PULL_STATE
EXECUTE_STREAM
GATHER_INFORMATION
REGISTER_SI
UNREGISTER_SI
Definition at line 150 of file vtkPVSessionCore.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 223 of file vtkPVSessionCore.h.
◆ vtkPVSessionCore()
vtkPVSessionCore::vtkPVSessionCore ( )
◆ ~vtkPVSessionCore()
vtkPVSessionCore::~vtkPVSessionCore ( )
static vtkPVSessionCore* vtkPVSessionCore::New ( )
virtual const char* vtkPVSessionCore::GetClassName ( )
Reimplemented in vtkPVCatalystSessionCore.
static int vtkPVSessionCore::IsTypeOf ( const char *  type)
virtual int vtkPVSessionCore::IsA ( const char *  type)
static vtkPVSessionCore* vtkPVSessionCore::SafeDownCast ( vtkObject *  o)
void vtkPVSessionCore::PrintSelf ( ostream &  os,
◆ GetInterpreter()
virtual vtkClientServerInterpreter* vtkPVSessionCore::GetInterpreter ( )
◆ GetProxyDefinitionManager()
virtual vtkSIProxyDefinitionManager* vtkPVSessionCore::GetProxyDefinitionManager ( )
◆ PushState()
virtual void vtkPVSessionCore::PushState ( vtkSMMessage *  message)
This might forward the message to the MPI statellites if needed.
◆ PullState()
virtual void vtkPVSessionCore::PullState ( vtkSMMessage *  message)
◆ ExecuteStream()
virtual void vtkPVSessionCore::ExecuteStream ( vtkTypeUInt32  location,
const vtkClientServerStream &  stream,
bool  ignore_errors = false
Use GetLastResult() to obtain the last result after the command stream is evaluated. Once can set ignore_errors to true, to ignore any interpreting errors.
◆ GetLastResult()
virtual const vtkClientServerStream& vtkPVSessionCore::GetLastResult ( )
Note if location refers to multiple processes, then the reply is only fetched from the "closest" process.
◆ UnRegisterSIObject()
virtual void vtkPVSessionCore::UnRegisterSIObject ( vtkSMMessage *  message)
This does not necessary delete the SIObject specially if this one is used by other local SIObject. It only decrease its reference count.
◆ RegisterSIObject()
virtual void vtkPVSessionCore::RegisterSIObject ( vtkSMMessage *  message)
It only increase its reference count.
◆ GetSIObject()
vtkSIObject* vtkPVSessionCore::GetSIObject ( vtkTypeUInt32  globalid)
◆ GetRemoteObject()
vtkObject* vtkPVSessionCore::GetRemoteObject ( vtkTypeUInt32  globalid)
◆ RegisterRemoteObject()
void vtkPVSessionCore::RegisterRemoteObject ( vtkTypeUInt32  globalid,
vtkObject *  obj
◆ UnRegisterRemoteObject()
void vtkPVSessionCore::UnRegisterRemoteObject ( vtkTypeUInt32  globalid)
◆ GatherInformation()
virtual bool vtkPVSessionCore::GatherInformation ( vtkTypeUInt32  location,
vtkPVInformation *  information,
location identifies the processes to gather the information from.
◆ GetNumberOfProcesses()
int vtkPVSessionCore::GetNumberOfProcesses ( )
This simply calls the GetNumberOfProcesses() on this->ParallelController
◆ SetMPIMToNSocketConnection()
void vtkPVSessionCore::SetMPIMToNSocketConnection ( vtkMPIMToNSocketConnection *  )
This is valid only on data-server and render-server processes.
◆ GetMPIMToNSocketConnection()
virtual vtkMPIMToNSocketConnection* vtkPVSessionCore::GetMPIMToNSocketConnection ( )
◆ GetNextGlobalUniqueIdentifier()
virtual vtkTypeUInt32 vtkPVSessionCore::GetNextGlobalUniqueIdentifier ( )
This implementation works locally. without any code distribution. To support the distributed architecture the vtkSMSessionClient override those method to call them on the DATA_SERVER vtkPVSessionBase instance.
◆ GetNextChunkGlobalUniqueIdentifier()
virtual vtkTypeUInt32 vtkPVSessionCore::GetNextChunkGlobalUniqueIdentifier ( vtkTypeUInt32  chunkSize)
1 = ReverveNextIdChunk(10); | Reserved ids [1,2,3,4,5,6,7,8,9,10] 11 = ReverveNextIdChunk(10);| Reserved ids [11,12,13,14,15,16,17,18,19,20] b = a + 10;
◆ PushStateSatelliteCallback()
void vtkPVSessionCore::PushStateSatelliteCallback ( )
◆ ExecuteStreamSatelliteCallback()
void vtkPVSessionCore::ExecuteStreamSatelliteCallback ( )
◆ GatherInformationStatelliteCallback()
void vtkPVSessionCore::GatherInformationStatelliteCallback ( )
◆ RegisterSIObjectSatelliteCallback()
void vtkPVSessionCore::RegisterSIObjectSatelliteCallback ( )
◆ UnRegisterSIObjectSatelliteCallback()
void vtkPVSessionCore::UnRegisterSIObjectSatelliteCallback ( )
◆ GetAllRemoteObjects()
virtual void vtkPVSessionCore::GetAllRemoteObjects ( vtkCollection *  collection)
◆ GarbageCollectSIObject()
void vtkPVSessionCore::GarbageCollectSIObject ( int *  clientIds,
int  nbClients
◆ PushStateInternal()
virtual void vtkPVSessionCore::PushStateInternal ( vtkSMMessage *  )
protectedvirtual
◆ ExecuteStreamInternal()
virtual void vtkPVSessionCore::ExecuteStreamInternal ( const vtkClientServerStream &  stream,
bool  ignore_errors
protectedvirtual
◆ GatherInformationInternal()
bool vtkPVSessionCore::GatherInformationInternal ( vtkPVInformation *  information,
◆ CollectInformation()
bool vtkPVSessionCore::CollectInformation ( vtkPVInformation *  )
◆ RegisterSIObjectInternal()
virtual void vtkPVSessionCore::RegisterSIObjectInternal ( vtkSMMessage *  message)
protectedvirtual
◆ UnRegisterSIObjectInternal()
virtual void vtkPVSessionCore::UnRegisterSIObjectInternal ( vtkSMMessage *  message)
protectedvirtual
This might not result in an actual deletion of the object if this one is used by another SIObject.
◆ OnInterpreterError()
void vtkPVSessionCore::OnInterpreterError ( vtkObject *  ,
unsigned long  ,
void *  calldata
◆ ProxyDefinitionManager
vtkSIProxyDefinitionManager* vtkPVSessionCore::ProxyDefinitionManager
Definition at line 229 of file vtkPVSessionCore.h.
◆ ParallelController
vtkWeakPointer<vtkMultiProcessController> vtkPVSessionCore::ParallelController
Definition at line 230 of file vtkPVSessionCore.h.
◆ Interpreter
vtkClientServerInterpreter* vtkPVSessionCore::Interpreter
Definition at line 231 of file vtkPVSessionCore.h.
◆ MPIMToNSocketConnection
vtkMPIMToNSocketConnection* vtkPVSessionCore::MPIMToNSocketConnection
Definition at line 232 of file vtkPVSessionCore.h.
