vtkSMViewLayoutProxy Class Reference
vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout. More...
#include <vtkSMViewLayoutProxy.h>
Inheritance diagram for vtkSMViewLayoutProxy:
Collaboration diagram for vtkSMViewLayoutProxy:
enum  Direction { NONE, VERTICAL, HORIZONTAL }
typedef vtkSMProxy Superclass
int Split (int location, int direction, double fraction)
 Split a frame at the given location. More...
int SplitVertical (int location, double fraction)
int SplitHorizontal (int location, double fraction)
bool AssignView (int location, vtkSMViewProxy *view)
 Assign a view at a particular location. More...
int AssignViewToAnyCell (vtkSMViewProxy *view, int location_hint)
 Similar to AssignView() except that is location specified is not available, then this method treats the location merely as a hint and tries to find a suitable place. More...
bool Collapse (int location)
 Collapses a cell. More...
bool SwapCells (int location1, int location2)
 Swaps the cells at the two locations. More...
bool SetSplitFraction (int location, double fraction)
 Update the split fraction for a split cell. More...
bool EqualizeViews ()
 Equalize views so they appear evenly sized. More...
bool EqualizeViews (Direction direction)
 Equalize views so they appear evenly sized along direction. More...
bool MaximizeCell (int location)
 One can maximize a particular (non-split) cell. More...
void RestoreMaximizedState ()
 Restores the maximized state. More...
bool IsSplitCell (int location)
 Returns true if the cell identified by the location is a split cell. More...
Direction GetSplitDirection (int location)
 Returns the split direction for a split cell at the given location. More...
double GetSplitFraction (int location)
 Returns the split-fraction for a split cell at the given location. More...
vtkSMViewProxy * GetView (int location)
 Returns the view, if any, assigned to the given cell location. More...
int GetViewLocation (vtkSMViewProxy *)
 Returns the location for the view, of any. More...
void UpdateViewPositions ()
 Updates positions for all views using the layout and current sizes. More...
void ShowViewsOnTileDisplay ()
 When in tile-display configuration, only 1 view-layout is shown on the tile-display (for obvious reasons). More...
vtkPVXMLElement * SaveXMLState (vtkPVXMLElement *root) override
 Overridden to save custom XML state. More...
vtkPVXMLElement * SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to load custom XML state. More...
void Reset ()
 Resets the layout. More...
void GetLayoutExtent (int extent[4])
 Returns the extents for all views in the layout. More...
vtkVector2i GetSize ()
 Returns the current size. More...
std::vector< vtkSMViewProxy * > GetViews ()
 Returns a vector of the view proxies added to his layout. More...
int RemoveView (vtkSMViewProxy *view)
 Removes a view. More...
bool RemoveView (int index)
virtual int GetMaximizedCell ()
 Returns the maximized cell, if any. More...
bool ContainsView (vtkSMViewProxy *view)
 Returns if a view is contained in this layout. More...
bool ContainsView (vtkSMProxy *view)
vtkImageData * CaptureWindow (int magnification)
 Captures an image from the layout (including all the views in the layout. More...
vtkImageData * CaptureWindow (int magnificationX, int magnificationY)
void SetSize (const int size[2])
 Update the size for all the views in the layout assuming the new size provided for the whole layout. More...
void SetSize (int width, int height)
void SaveAsPNG (int rank, const char *fname)
 This is only meant for testing and debugging purposes. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMViewLayoutProxy * New ()
static vtkSMViewLayoutProxy * SafeDownCast (vtkObject *o)
static int GetFirstChild (int location)
 Returns the index for the first child of the given location. More...
static int GetSecondChild (int location)
 Returns the index for the second child of the given location. More...
static int GetParent (int location)
 Returns the parent index. More...
static vtkSMViewLayoutProxy * FindLayout (vtkSMViewProxy *, const char *reggroup="layouts")
 Helper method to locate a layout, if any that contains the specified view proxy. More...
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMViewLayoutProxy ()
 ~vtkSMViewLayoutProxy () override
void LoadState (const vtkSMMessage *message, vtkSMProxyLocator *locator) override
 Called to load state from protobuf message. More...
virtual void UpdateState ()
 Although this class is a proxy, it's not really a proxy in the traditional sense. More...
int GetEmptyCell (int root)
 Starting with the cell-index, tries to find an empty cell in the sub-tree. More...
int GetSplittableCell (int root, Direction &suggested_direction)
 Starting with the root, finds a splittable cell. More...
int ComputeSteadySplitFraction (int location, Direction direction)
 Recompute SplitFraction recursively so cells appears evenly sized along direction. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int MaximizedCell
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout. This is proxy, hence can be registered with the proxy manager just like other regular proxies; participates in xml state saving/restoring, undo-redo, etc. Users can affects the GUI layout using this proxy instance from Python as well.
Every time the vtkSMViewLayoutProxy changes so that it would affect the UI, this class fires vtkCommand::ConfigureEvent.
View proxies that are to laid out in an layout should be "assigned" to a particular cell in a vtkSMViewLayoutProxy instance. vtkSMViewLayoutProxy takes over the responsibility of updating the view's Position property correctly.
Although, currently, there are no safe guards against assigning a view to more than one layout, this is strictly prohibited and can cause unexpected problems at run-time.
Definition at line 39 of file vtkSMViewLayoutProxy.h.
Definition at line 43 of file vtkSMViewLayoutProxy.h.
◆ Direction
Enumerator
NONE
VERTICAL
HORIZONTAL
Definition at line 46 of file vtkSMViewLayoutProxy.h.
◆ vtkSMViewLayoutProxy()
vtkSMViewLayoutProxy::vtkSMViewLayoutProxy ( )
◆ ~vtkSMViewLayoutProxy()
vtkSMViewLayoutProxy::~vtkSMViewLayoutProxy ( )
static vtkSMViewLayoutProxy* vtkSMViewLayoutProxy::New ( )
virtual const char* vtkSMViewLayoutProxy::GetClassName ( )
static int vtkSMViewLayoutProxy::IsTypeOf ( const char *  type)
virtual int vtkSMViewLayoutProxy::IsA ( const char *  type)
static vtkSMViewLayoutProxy* vtkSMViewLayoutProxy::SafeDownCast ( vtkObject *  o)
void vtkSMViewLayoutProxy::PrintSelf ( ostream &  os,
◆ Split()
int vtkSMViewLayoutProxy::Split ( int  location,
int  direction,
double  fraction
Location must point to an existing cell that's not split. If the location does not exist or is already split, then returns -1, to indicate failure. Otherwise returns the index of the left (or top) child node. The index for the sibling can be computed as (ret_val + 1). fraction indicates a value in the range [0.0, 1.0] at which the cell is split. If a View is set at the given location, it will be moved to the left (or top) child after the split.
◆ SplitVertical()
int vtkSMViewLayoutProxy::SplitVertical ( int  location,
double  fraction
inline
Definition at line 63 of file vtkSMViewLayoutProxy.h.
◆ SplitHorizontal()
int vtkSMViewLayoutProxy::SplitHorizontal ( int  location,
double  fraction
inline
Definition at line 67 of file vtkSMViewLayoutProxy.h.
◆ AssignView()
bool vtkSMViewLayoutProxy::AssignView ( int  location,
vtkSMViewProxy *  view
Note that the view's position may be changed by Split() calls. Returns true on success.
◆ AssignViewToAnyCell()
int vtkSMViewLayoutProxy::AssignViewToAnyCell ( vtkSMViewProxy *  view,
int  location_hint
First, if any empty cell is available, then that is used. Second, if no empty cell is available and location is a valid cell, then we either split the cell or traverse down the sub-tree from the cell and split a cell to make room for the view. Thus, this method will always assign the view to a frame. Returns the assigned location.
◆ RemoveView() [1/2]
int vtkSMViewLayoutProxy::RemoveView ( vtkSMViewProxy *  view)
Removes a view.
Returns the location of the cell emptied by the view, if any, otherwise -1.
◆ RemoveView() [2/2]
bool vtkSMViewLayoutProxy::RemoveView ( int  index)
Removes a view.
◆ Collapse()
bool vtkSMViewLayoutProxy::Collapse ( int  location)
Collapses a cell.
Only leaf cells without any assigned views can be collapsed. If the cell has a sibling, then that sibling is assigned to the parent node and the sibling cell is destroyed as well. Returns true on success, else false.
◆ SwapCells()
bool vtkSMViewLayoutProxy::SwapCells ( int  location1,
int  location2
Both locations must be leaf locations i.e. cannot be split-cells.
◆ SetSplitFraction()
bool vtkSMViewLayoutProxy::SetSplitFraction ( int  location,
double  fraction
If IsSplitCell(location) returns false, this method does not update the fraction.
◆ EqualizeViews() [1/2]
bool vtkSMViewLayoutProxy::EqualizeViews ( )
◆ EqualizeViews() [2/2]
bool vtkSMViewLayoutProxy::EqualizeViews ( Direction  direction)
◆ MaximizeCell()
bool vtkSMViewLayoutProxy::MaximizeCell ( int  location)
Note the maximized state is restored as soon as the layout is changed or when RestoreMaximizedState() is called. Returns false if the cell at the location cannot be maximized since it's a split cell or invalid cell, true otherwise.
◆ RestoreMaximizedState()
void vtkSMViewLayoutProxy::RestoreMaximizedState ( )
◆ GetMaximizedCell()
virtual int vtkSMViewLayoutProxy::GetMaximizedCell ( )
Returns -1 if no cell is currently maximized.
◆ IsSplitCell()
bool vtkSMViewLayoutProxy::IsSplitCell ( int  location)
◆ GetSplitDirection()
Direction vtkSMViewLayoutProxy::GetSplitDirection ( int  location)
◆ GetSplitFraction()
double vtkSMViewLayoutProxy::GetSplitFraction ( int  location)
◆ GetFirstChild()
static int vtkSMViewLayoutProxy::GetFirstChild ( int  location)
inlinestatic
This does not do any validity checks for the location, nor that of the child.
Definition at line 168 of file vtkSMViewLayoutProxy.h.
◆ GetSecondChild()
static int vtkSMViewLayoutProxy::GetSecondChild ( int  location)
inlinestatic
Definition at line 174 of file vtkSMViewLayoutProxy.h.
◆ GetParent()
static int vtkSMViewLayoutProxy::GetParent ( int  location)
inlinestatic
Definition at line 179 of file vtkSMViewLayoutProxy.h.
◆ GetView()
vtkSMViewProxy* vtkSMViewLayoutProxy::GetView ( int  location)
◆ GetViewLocation()
int vtkSMViewLayoutProxy::GetViewLocation ( vtkSMViewProxy *  )
Returns -1 if the view is not found.
◆ ContainsView() [1/2]
bool vtkSMViewLayoutProxy::ContainsView ( vtkSMViewProxy *  view)
inline
Definition at line 196 of file vtkSMViewLayoutProxy.h.
◆ ContainsView() [2/2]
bool vtkSMViewLayoutProxy::ContainsView ( vtkSMProxy *  view)
◆ UpdateViewPositions()
void vtkSMViewLayoutProxy::UpdateViewPositions ( )
This method is called automatically when the layout changes or the "ViewSize" property on the assigned views changes.
◆ ShowViewsOnTileDisplay()
void vtkSMViewLayoutProxy::ShowViewsOnTileDisplay ( )
To show any particular layout on the tile display, simply call this method.
◆ CaptureWindow() [1/2]
vtkImageData* vtkSMViewLayoutProxy::CaptureWindow ( int  magnification)
inline
Definition at line 218 of file vtkSMViewLayoutProxy.h.
◆ CaptureWindow() [2/2]
vtkImageData* vtkSMViewLayoutProxy::CaptureWindow ( int  magnificationX,
int  magnificationY
◆ SaveXMLState() [1/2]
vtkPVXMLElement* vtkSMViewLayoutProxy::SaveXMLState ( vtkPVXMLElement *  root)
inlineoverridevirtual
Definition at line 228 of file vtkSMViewLayoutProxy.h.
◆ SaveXMLState() [2/2]
vtkPVXMLElement* vtkSMViewLayoutProxy::SaveXMLState ( vtkPVXMLElement *  root,
vtkSMPropertyIterator *  iter
The iterator is use to filter the property available on the given proxy.
◆ LoadXMLState()
int vtkSMViewLayoutProxy::LoadXMLState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  locator
◆ Reset()
void vtkSMViewLayoutProxy::Reset ( )
Resets the layout.
◆ GetLayoutExtent()
void vtkSMViewLayoutProxy::GetLayoutExtent ( int  extent[4])
◆ SetSize() [1/2]
void vtkSMViewLayoutProxy::SetSize ( const int  size[2])
This resizes and repositions each view based the recursive split ratios for all the cells in the layout.
◆ SetSize() [2/2]
void vtkSMViewLayoutProxy::SetSize ( int  width,
int  height
inline
Definition at line 256 of file vtkSMViewLayoutProxy.h.
◆ GetSize()
vtkVector2i vtkSMViewLayoutProxy::GetSize ( )
inline
Definition at line 266 of file vtkSMViewLayoutProxy.h.
◆ FindLayout()
static vtkSMViewLayoutProxy* vtkSMViewLayoutProxy::FindLayout ( vtkSMViewProxy *  ,
const char *  reggroup = "layouts"
◆ GetViews()
std::vector<vtkSMViewProxy*> vtkSMViewLayoutProxy::GetViews ( )
◆ SaveAsPNG()
void vtkSMViewLayoutProxy::SaveAsPNG ( int  rank,
const char *  fname
This allows the application to save the image rendered on the server side in certain configurations (tile display and cave) to a png file for regression testing.
◆ LoadState()
void vtkSMViewLayoutProxy::LoadState ( const vtkSMMessage *  message,
overrideprotectedvirtual
◆ UpdateState()
virtual void vtkSMViewLayoutProxy::UpdateState ( )
protectedvirtual
So instead of using UpdateVTKObjects() to push state changes to the server (or undo-redo stack), this new method is provided.
◆ GetEmptyCell()
int vtkSMViewLayoutProxy::GetEmptyCell ( int  root)
Returns -1 if none found. May return root, if root is indeed an empty cell. Note this assumes that root is valid.
◆ GetSplittableCell()
int vtkSMViewLayoutProxy::GetSplittableCell ( int  root,
Direction &  suggested_direction
Assumes root is valid.
◆ ComputeSteadySplitFraction()
int vtkSMViewLayoutProxy::ComputeSteadySplitFraction ( int  location,
Direction  direction
return the weight of the cell at location, i.e. the number of impacted children.
◆ MaximizedCell
int vtkSMViewLayoutProxy::MaximizedCell
Definition at line 328 of file vtkSMViewLayoutProxy.h.
