virtual int LoadState(vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
Load the state of the domain from the XML.
Used to identify a proxy type.
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
ProxyType(const std::string &group, const std::string &name)
represents the possible values a property can have
static vtkSMDomain * New()
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
vtkSMDomainInternals * Internals
virtual void ChildSaveState(vtkPVXMLElement *domainElement)
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attribut...
