vtkSMOrthographicSliceViewProxy Class Reference
#include <vtkSMOrthographicSliceViewProxy.h>
Inheritance diagram for vtkSMOrthographicSliceViewProxy:
Collaboration diagram for vtkSMOrthographicSliceViewProxy:
typedef vtkSMRenderViewProxy Superclass
- Public Types inherited from vtkSMRenderViewProxy
enum  CameraAdjustmentType : int { CameraAdjustmentType::Roll = 0, CameraAdjustmentType::Elevation, CameraAdjustmentType::Azimuth, CameraAdjustmentType::Zoom }
typedef vtkSMViewProxy Superclass
- Public Types inherited from vtkSMViewProxy
enum  { PrepareContextForRendering = vtkCommand::UserEvent + 1 }
typedef vtkSMProxy Superclass
const char * GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override
 Overridden to forward the call to the internal root view proxy. More...
vtkSMRepresentationProxy * CreateDefaultRepresentation (vtkSMProxy *proxy, int outputPort) override
 Overridden to set initial default slices when a representation is created. More...
- Public Member Functions inherited from vtkSMRenderViewProxy
vtkSMRepresentationProxy * Pick (int x, int y)
 Convenience method to pick a location. More...
vtkSMRepresentationProxy * PickBlock (int x, int y, unsigned int &flatIndex, int &rank)
 Convenience method to pick a block in a multi-block data set. More...
bool ConvertDisplayToPointOnSurface (const int display_position[2], double world_position[3], double world_normal[3], bool snapOnMeshPoint=false)
 Given a location is display coordinates (pixels), tries to compute and return the world location and normal on a surface, if possible. More...
virtual bool IsSelectionAvailable ()
 Checks if color depth is sufficient to support selection. More...
void SynchronizeGeometryBounds ()
 Call SynchronizeGeometryBounds server side. More...
virtual void ZoomTo (vtkSMProxy *representation, bool closest=false, double offsetRatio=0.9)
 Convenience method for zooming to a representation. More...
void SetupInteractor (vtkRenderWindowInteractor *iren) override
 A client process need to set the interactor to enable interactivity. More...
vtkRenderWindowInteractor * GetInteractor () override
 Returns the interactor. More...
vtkRenderer * GetRenderer ()
 Returns the client-side renderer (composited or 3D). More...
void UpdateVTKObjects () override
 Filter changes to the OSPRay rendering method, to transfer the pathtracing materials from client to server only when they are acutally needed. More...
void SynchronizeCameraProperties ()
 This method calls UpdateInformation on the Camera Proxy and sets the Camera properties according to the info properties. More...
virtual bool LastRenderWasInteractive ()
 Returns true if the most recent render indeed employed low-res rendering. More...
void Update () override
 Called vtkPVView::Update on the server-side. More...
bool GetNeedsUpdate () override
 We override that method to handle LOD and non-LOD NeedsUpdate in transparent manner. More...
bool StreamingUpdate (bool render_if_needed)
 Called to render a streaming pass. More...
 Overridden to check through the various representations that this view can create. More...
vtkRenderWindow * GetRenderWindow () override
 Returns the render window used by this view. More...
vtkSMViewProxyInteractorHelper * GetInteractorHelper ()
 Provides access to the vtkSMViewProxyInteractorHelper object that handles the interaction/view sync. More...
vtkFloatArray * CaptureDepthBuffer ()
 Access to the Z buffer. More...
virtual const char * GetSelectionRepresentationProxyName ()
 Get the SelectionRepresentation proxy name. More...
virtual void CopySelectionRepresentationProperties (vtkSMProxy *vtkNotUsed(fromSelectionRep), vtkSMProxy *vtkNotUsed(toSelectionRep))
 Function to copy selection representation properties. More...
void ComputeVisibleBounds (vtkSMProxy *representation, double *bounds)
 Compute the bounds of the visible data on the given representation. More...
bool ClearSelectionCache (bool force=false)
 Tries to clear the selection cache (if needed). More...
bool SelectSurfaceCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr)
 Makes a new selection source proxy. More...
bool SelectSurfacePoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr)
bool SelectFrustumCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false)
bool SelectFrustumPoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false)
bool SelectPolygonPoints (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false)
bool SelectPolygonCells (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false)
bool ComputeVisibleScalarRange (const int region[4], int fieldAssociation, const char *scalarName, int component, double range[])
 Returns the range for visible elements in the current view. More...
bool ComputeVisibleScalarRange (int fieldAssociation, const char *scalarName, int component, double range[])
void ResetCamera (bool closest=false, double offsetRatio=0.9)
 For backwards compatibility in Python scripts. More...
void ResetCamera (double bounds[6], bool closest=false, double offsetRatio=0.9)
void ResetCamera (double xmin, double xmax, double ymin, double ymax, double zmin, double zmax, bool closest=false, double offsetRatio=0.9)
virtual const char * IsSelectVisibleCellsAvailable ()
 Similar to IsSelectionAvailable(), however, on failure returns the error message otherwise 0. More...
virtual const char * IsSelectVisiblePointsAvailable ()
vtkCamera * GetActiveCamera ()
 Returns the client-side active camera object. More...
void AdjustActiveCamera (const CameraAdjustmentType &, const double &)
void AdjustActiveCamera (const int &, const double &)
void AdjustAzimuth (const double &value)
void AdjustElevation (const double &value)
void AdjustRoll (const double &value)
void AdjustZoom (const double &value)
void ApplyIsometricView ()
void ResetActiveCameraToDirection (const double &look_x, const double &look_y, const double &look_z, const double &up_x, const double &up_y, const double &up_z)
void ResetActiveCameraToPositiveX ()
void ResetActiveCameraToNegativeX ()
void ResetActiveCameraToPositiveY ()
void ResetActiveCameraToNegativeY ()
void ResetActiveCameraToPositiveZ ()
void ResetActiveCameraToNegativeZ ()
- Public Member Functions inherited from vtkSMViewProxy
virtual void StillRender ()
 Renders the view using full resolution. More...
virtual void InteractiveRender ()
 Renders the view using lower resolution is possible. More...
virtual bool CanDisplayData (vtkSMSourceProxy *producer, int outputPort)
 Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * FindRepresentation (vtkSMSourceProxy *producer, int outputPort)
 Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * GetClientSideView ()
 Returns the client-side vtkView, if any. More...
int WriteImage (const char *filename, const char *writerName, int magnification=1)
 Saves a screenshot of the view to disk. More...
int WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY)
virtual bool HasDirtyRepresentation ()
 Return true any internal representation is dirty. More...
virtual bool MakeRenderWindowInteractor (bool quiet=false)
 Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void SetEnable (bool)
 Enable/Disable a view. More...
virtual bool GetEnable ()
virtual void EnableOn ()
virtual void EnableOff ()
vtkImageData * CaptureWindow (int magnification)
 Captures a image from this view. More...
vtkImageData * CaptureWindow (int magnificationX, int magnificationY)
virtual bool HideOtherRepresentationsIfNeeded (vtkSMProxy *repr)
 Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility)
 Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMOrthographicSliceViewProxy * New ()
static vtkSMOrthographicSliceViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMRenderViewProxy
static vtkSMRenderViewProxy * New ()
static vtkSMRenderViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMViewProxy
static vtkSMViewProxy * New ()
static vtkSMViewProxy * SafeDownCast (vtkObject *o)
static vtkSMViewProxy * FindView (vtkSMProxy *repr, const char *reggroup="views")
 Helper method to locate a view to which the representation has been added. More...
static void SetTransparentBackground (bool val)
 Sets whether screenshots have a transparent background. More...
static bool GetTransparentBackground ()
static bool HideOtherRepresentationsIfNeeded (vtkSMViewProxy *self, vtkSMProxy *repr)
static void RepresentationVisibilityChanged (vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMOrthographicSliceViewProxy ()
 ~vtkSMOrthographicSliceViewProxy () override
void InitDefaultSlices (vtkSMSourceProxy *source, int opport, vtkSMRepresentationProxy *repr)
void OnMouseWheelBackwardEvent (vtkObject *, unsigned long, void *calldata)
void OnMouseWheelForwardEvent (vtkObject *, unsigned long, void *calldata)
void OnPlacePointEvent (vtkObject *, unsigned long, void *calldata)
- Protected Member Functions inherited from vtkSMRenderViewProxy
 vtkSMRenderViewProxy ()
 ~vtkSMRenderViewProxy () override
void RenderForImageCapture () override
 Overridden to call this->InteractiveRender() if "UseInteractiveRenderingForScreenshots" is true. More...
void UpdateLOD ()
 Calls UpdateLOD() on the vtkPVRenderView. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Overridden to ensure that we clean up the selection cache on the server side. More...
bool SelectFrustumInternal (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections, int fieldAssociation)
bool SelectPolygonInternal (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections, int fieldAssociation, int modifier, bool selectBlocks)
vtkTypeUInt32 PreRender (bool interactive) override
void PostRender (bool interactive) override
bool FetchLastSelection (bool multiple_selections, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, int modifier, bool selectBlocks)
 Fetches the LastSelection from the data-server and then converts it to a selection source proxy and returns that. More...
 Called at the end of CreateVTKObjects(). More...
bool IsInSelectionMode ()
 Returns true if the proxy is in interaction mode that corresponds to making a selection i.e. More...
void NewMasterCallback (vtkObject *src, unsigned long event, void *data)
- Protected Member Functions inherited from vtkSMViewProxy
 vtkSMViewProxy ()
 ~vtkSMViewProxy () override
virtual vtkImageData * CaptureWindowInternal (int magnificationX, int magnificationY)
 Capture an image from the view's render window. More...
virtual vtkTypeUInt32 PreRender (bool vtkNotUsed(interactive))
 This method is called before executing code that could cause a render on the underlying vtkPVView. More...
virtual void PostRender (bool vtkNotUsed(interactive))
virtual bool IsContextReadyForRendering ()
 Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
bool GetLocalProcessSupportsInteraction ()
 Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
virtual vtkSMDataDeliveryManagerProxy * GetDeliveryManager ()
 Provides access to the delivery manager proxy, if any. More...
virtual void SetDefaultRepresentationName (const char *)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMRenderViewProxy
bool IsSelectionCached
unsigned long NewMasterObserverId
bool NeedsUpdateLOD
- Protected Attributes inherited from vtkSMViewProxy
char * DefaultRepresentationName
bool Enable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 15 of file vtkSMOrthographicSliceViewProxy.h.
Definition at line 19 of file vtkSMOrthographicSliceViewProxy.h.
◆ vtkSMOrthographicSliceViewProxy()
vtkSMOrthographicSliceViewProxy::vtkSMOrthographicSliceViewProxy ( )
◆ ~vtkSMOrthographicSliceViewProxy()
vtkSMOrthographicSliceViewProxy::~vtkSMOrthographicSliceViewProxy ( )
static vtkSMOrthographicSliceViewProxy* vtkSMOrthographicSliceViewProxy::New ( )
virtual const char* vtkSMOrthographicSliceViewProxy::GetClassName ( )
Reimplemented from vtkSMRenderViewProxy.
static int vtkSMOrthographicSliceViewProxy::IsTypeOf ( const char *  type)
virtual int vtkSMOrthographicSliceViewProxy::IsA ( const char *  type)
static vtkSMOrthographicSliceViewProxy* vtkSMOrthographicSliceViewProxy::SafeDownCast ( vtkObject *  o)
void vtkSMOrthographicSliceViewProxy::PrintSelf ( ostream &  os,
◆ GetRepresentationType()
const char* vtkSMOrthographicSliceViewProxy::GetRepresentationType ( vtkSMSourceProxy *  producer,
int  outputPort
Reimplemented from vtkSMViewProxy.
◆ CreateDefaultRepresentation()
vtkSMRepresentationProxy* vtkSMOrthographicSliceViewProxy::CreateDefaultRepresentation ( vtkSMProxy *  proxy,
int  outputPort
Not sure that's the best way to do this, but leaving the logic unchanged in this pass.
◆ InitDefaultSlices()
void vtkSMOrthographicSliceViewProxy::InitDefaultSlices ( vtkSMSourceProxy *  source,
int  opport,
vtkSMRepresentationProxy *  repr
◆ CreateVTKObjects()
void vtkSMOrthographicSliceViewProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
◆ OnMouseWheelBackwardEvent()
void vtkSMOrthographicSliceViewProxy::OnMouseWheelBackwardEvent ( vtkObject *  ,
unsigned long  ,
void *  calldata
◆ OnMouseWheelForwardEvent()
void vtkSMOrthographicSliceViewProxy::OnMouseWheelForwardEvent ( vtkObject *  ,
unsigned long  ,
void *  calldata
◆ OnPlacePointEvent()
void vtkSMOrthographicSliceViewProxy::OnPlacePointEvent ( vtkObject *  ,
unsigned long  ,
void *  calldata
