vtkSMFieldDataDomain Class Reference
enumeration domain to select array association or attribute type. More...
#include <vtkSMFieldDataDomain.h>
Inheritance diagram for vtkSMFieldDataDomain:
Collaboration diagram for vtkSMFieldDataDomain:
typedef vtkSMEnumerationDomain Superclass
- Public Types inherited from vtkSMEnumerationDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
void Update (vtkSMProperty *property) override
 Updates the available field data based on the input dataset type, if possible. More...
- Public Member Functions inherited from vtkSMEnumerationDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (int val, unsigned int &idx)
 Returns true if the int is in the domain. More...
unsigned int GetNumberOfEntries ()
 Returns the number of entries in the enumeration. More...
int GetEntryValue (unsigned int idx)
 Returns the integer value of an enumeration entry. More...
const char * GetEntryText (unsigned int idx)
 Returns the descriptive string of an enumeration entry. More...
const char * GetEntryTextForValue (int value)
 Returns the text for an enumeration value. More...
int HasEntryText (const char *text)
 Return 1 is the text is present in the enumeration, otherwise 0. More...
int GetEntryValueForText (const char *text)
 Get the value for an enumeration text. More...
int GetEntryValue (const char *text, int &valid)
 Given an entry text, return the integer value. More...
const char * GetInfoText (unsigned int idx)
 Returns the info text for an enumeration entry. More...
void AddEntry (const char *text, int value, const char *info=nullptr)
 Add a new enumeration entry. More...
void RemoveAllEntries ()
 Clear all entries. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMFieldDataDomain * New ()
static vtkSMFieldDataDomain * SafeDownCast (vtkObject *o)
static const char * GetAttributeTypeAsString (int attrType)
 Convenience method to return the string for an attribute type. More...
static const char * GetElementTypeAsString (int attrType)
 Convenience method to return the string for an element type. More...
- Static Public Member Functions inherited from vtkSMEnumerationDomain
static vtkSMEnumerationDomain * New ()
static vtkSMEnumerationDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMFieldDataDomain ()
 ~vtkSMFieldDataDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override
- Protected Member Functions inherited from vtkSMEnumerationDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
 vtkSMEnumerationDomain ()
 ~vtkSMEnumerationDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableFieldDataSelection
bool UseElementTypes
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMFieldDataDomain can be used on a vtkSMIntVectorProperty that is intended to specify the attribute type (vtkDataObject::AttributeTypes) or field association (vtkDataObject::FieldAssociations).
By default, vtkDataObject::Field (or vtkDataObject::FIELD_ASSOCIATION_NONE) is not added to the domain. If you want to support field data, then use enable_field_data="1" attribute in the XML configuration.
By default, the domain is assumed to represent field associations and hence the enumeration text is populated as "Point Data", "Cell Data", etc. To use element types for text, add attribute use_element_types="1" to the XML. In that case, the domain is populated with "Point", "Cell", etc.
Selecting the default value
vtkSMFieldDataDomain tries to respect the provided default_values. eg default_values=1 correspond to vtkDataObject::CELL If it is non-positive or not available, it will pick the default value to be the first attribute type that has non empty arrays and non-zero tuples. If all attributes have no tuples, then the first attribute with non empty arrays is selected. If all attributes have no arrays, then vtkSMEnumerationDomain picks the default. For this to work, the domain must be provided an Input property as a required property for function "Input".
Deprecated Usage
Previously (5.6 and earlier), vtkSMFieldDataDomain was added to vtkSMStringVectorProperty instances that allowed user to choose the array to process. This is no longer needed or supported. Simply remove the vtkSMFieldDataDomain from the XML for such properties.
The domain provided ability to limit the attribute types to the data type of the input dataset. This was clumsy since it did not correctly handle cases where data type changes or non empty attribute types changed. Hence we've dropped support for that. Simply remove disable_update_domain_entries and force_point_cell_data attributes from the XML for this domain since they are no longer supported.
Definition at line 53 of file vtkSMFieldDataDomain.h.
Definition at line 57 of file vtkSMFieldDataDomain.h.
◆ vtkSMFieldDataDomain()
vtkSMFieldDataDomain::vtkSMFieldDataDomain ( )
◆ ~vtkSMFieldDataDomain()
vtkSMFieldDataDomain::~vtkSMFieldDataDomain ( )
static vtkSMFieldDataDomain* vtkSMFieldDataDomain::New ( )
virtual const char* vtkSMFieldDataDomain::GetClassName ( )
Reimplemented from vtkSMEnumerationDomain.
static int vtkSMFieldDataDomain::IsTypeOf ( const char *  type)
virtual int vtkSMFieldDataDomain::IsA ( const char *  type)
static vtkSMFieldDataDomain* vtkSMFieldDataDomain::SafeDownCast ( vtkObject *  o)
void vtkSMFieldDataDomain::PrintSelf ( ostream &  os,
◆ SetDefaultValues()
int vtkSMFieldDataDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ GetAttributeTypeAsString()
static const char* vtkSMFieldDataDomain::GetAttributeTypeAsString ( int  attrType)
Will return nullptr for unsupported or invalid type.
◆ GetElementTypeAsString()
static const char* vtkSMFieldDataDomain::GetElementTypeAsString ( int  attrType)
◆ Update()
void vtkSMFieldDataDomain::Update ( vtkSMProperty *  property)
The provided property is not used.
◆ ReadXMLAttributes()
int vtkSMFieldDataDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  elem
overrideprotectedvirtual
◆ EnableFieldDataSelection
bool vtkSMFieldDataDomain::EnableFieldDataSelection
Definition at line 95 of file vtkSMFieldDataDomain.h.
◆ UseElementTypes
bool vtkSMFieldDataDomain::UseElementTypes
Definition at line 97 of file vtkSMFieldDataDomain.h.
