vtkSMFieldDataDomain.h
45 #ifndef vtkSMFieldDataDomain_h
46 #define vtkSMFieldDataDomain_h
47
48 #include "vtkRemotingServerManagerModule.h" //needed for exports
49 #include "vtkSMEnumerationDomain.h"
50
52
53 class VTKREMOTINGSERVERMANAGER_EXPORT vtkSMFieldDataDomain : public vtkSMEnumerationDomain
54 {
55 public:
56  static vtkSMFieldDataDomain* New();
58  void PrintSelf(ostream& os, vtkIndent indent) override;
59
64  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
65
70  static const char* GetAttributeTypeAsString(int attrType);
71
76  static const char* GetElementTypeAsString(int attrType);
77
82  void Update(vtkSMProperty* property) override;
83
84 protected:
86  ~vtkSMFieldDataDomain() override;
87
92  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* elem) override;
93
94  // When true, "Field Data" option is added to the domain.
96
98
99 private:
101  void operator=(const vtkSMFieldDataDomain&) = delete;
102
109  int ComputeDefaultValue(int originalDefaultValue);
110 };
111
112 #endif
enumeration domain to select array association or attribute type.
Definition: vtkSMFieldDataDomain.h:53
vtkSMEnumerationDomain::ReadXMLAttributes
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
vtkSMEnumerationDomain::New
static vtkSMEnumerationDomain * New()
vtkSMEnumerationDomain::Update
void Update(vtkSMProperty *property) override
Update self based on the "unchecked" values of all required properties.
vtkSMProperty
Definition: vtkSMProperty.h:144
vtkSMEnumerationDomain::SetDefaultValues
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
Overridden to ensure that the property's default value is valid for the enumeration,...
vtkSMFieldDataDomain::UseElementTypes
bool UseElementTypes
Definition: vtkSMFieldDataDomain.h:97
vtkIndent
vtkSMEnumerationDomain::PrintSelf
vtkPVDataInformation
provides meta data about a vtkDataObject subclass.
Definition: vtkPVDataInformation.h:42
vtkPVXMLElement
Definition: vtkPVXMLElement.h:23
list of integers with associated strings
Definition: vtkSMEnumerationDomain.h:67
vtkSMFieldDataDomain::EnableFieldDataSelection
bool EnableFieldDataSelection
Definition: vtkSMFieldDataDomain.h:95
