vtkSMExporterProxy Class Referenceabstract
proxy for view exporters. More...
#include <vtkSMExporterProxy.h>
Inheritance diagram for vtkSMExporterProxy:
Collaboration diagram for vtkSMExporterProxy:
typedef vtkSMProxy Superclass
virtual void Write ()=0
 Exports the view. More...
virtual bool CanExport (vtkSMProxy *)=0
 Returns if the view can be exported. More...
void SetView (vtkSMViewProxy *view)
 Set the view proxy to export. More...
virtual vtkSMViewProxy * GetView ()
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMExporterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMViewProxy * View
std::vector< std::string > FileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMExporterProxy is a proxy for vtkExporter subclasses. It makes it possible to export render views using these exporters.
Definition at line 22 of file vtkSMExporterProxy.h.
Definition at line 25 of file vtkSMExporterProxy.h.
◆ vtkSMExporterProxy()
vtkSMExporterProxy::vtkSMExporterProxy ( )
◆ ~vtkSMExporterProxy()
vtkSMExporterProxy::~vtkSMExporterProxy ( )
virtual const char* vtkSMExporterProxy::GetClassName ( )
static int vtkSMExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMExporterProxy::IsA ( const char *  type)
static vtkSMExporterProxy* vtkSMExporterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMExporterProxy::PrintSelf ( ostream &  os,
Reimplemented in vtkSMRenderViewExporterProxy, and vtkSMGL2PSExporterProxy.
◆ SetView()
void vtkSMExporterProxy::SetView ( vtkSMViewProxy *  view)
◆ GetView()
virtual vtkSMViewProxy* vtkSMExporterProxy::GetView ( )
◆ Write()
virtual void vtkSMExporterProxy::Write ( )
pure virtual
◆ CanExport()
virtual bool vtkSMExporterProxy::CanExport ( vtkSMProxy *  )
pure virtual
Default implementation return true if the view is a render view.
Implemented in vtkSMCSVExporterProxy, vtkSMRenderViewExporterProxy, and vtkSMGL2PSExporterProxy.
◆ GetFileExtensions()
const std::vector<std::string>& vtkSMExporterProxy::GetFileExtensions ( ) const
inline
Definition at line 51 of file vtkSMExporterProxy.h.
◆ ReadXMLAttributes()
int vtkSMExporterProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
overrideprotectedvirtual
Read attributes from an XML element.
Reimplemented in vtkSMGL2PSExporterProxy.
◆ View
vtkSMViewProxy* vtkSMExporterProxy::View
Definition at line 62 of file vtkSMExporterProxy.h.
◆ FileExtensions
std::vector<std::string> vtkSMExporterProxy::FileExtensions
Definition at line 63 of file vtkSMExporterProxy.h.
