vtkSMRenderViewExporterProxy Class Reference
proxy for vtkExporter subclasses which work with render windows. More...
#include <vtkSMRenderViewExporterProxy.h>
Inheritance diagram for vtkSMRenderViewExporterProxy:
Collaboration diagram for vtkSMRenderViewExporterProxy:
typedef vtkSMExporterProxy Superclass
- Public Types inherited from vtkSMExporterProxy
typedef vtkSMProxy Superclass
void Write () override
 Exports the view. More...
bool CanExport (vtkSMProxy *) override
 Returns if the view can be exported. More...
- Public Member Functions inherited from vtkSMExporterProxy
void SetView (vtkSMViewProxy *view)
 Set the view proxy to export. More...
virtual vtkSMViewProxy * GetView ()
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMRenderViewExporterProxy * New ()
static vtkSMRenderViewExporterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExporterProxy
static vtkSMExporterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMRenderViewExporterProxy ()
 ~vtkSMRenderViewExporterProxy () override
- Protected Member Functions inherited from vtkSMExporterProxy
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMExporterProxy
vtkSMViewProxy * View
std::vector< std::string > FileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMRenderViewExporterProxy is a proxy for vtkExporter subclasses. It makes it possible to export render views using these exporters.
Definition at line 18 of file vtkSMRenderViewExporterProxy.h.
Definition at line 22 of file vtkSMRenderViewExporterProxy.h.
◆ vtkSMRenderViewExporterProxy()
vtkSMRenderViewExporterProxy::vtkSMRenderViewExporterProxy ( )
◆ ~vtkSMRenderViewExporterProxy()
vtkSMRenderViewExporterProxy::~vtkSMRenderViewExporterProxy ( )
static vtkSMRenderViewExporterProxy* vtkSMRenderViewExporterProxy::New ( )
virtual const char* vtkSMRenderViewExporterProxy::GetClassName ( )
Reimplemented from vtkSMExporterProxy.
Reimplemented in vtkSMGL2PSExporterProxy.
static int vtkSMRenderViewExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMRenderViewExporterProxy::IsA ( const char *  type)
static vtkSMRenderViewExporterProxy* vtkSMRenderViewExporterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMRenderViewExporterProxy::PrintSelf ( ostream &  os,
◆ Write()
void vtkSMRenderViewExporterProxy::Write ( )
Exports the view.
Implements vtkSMExporterProxy.
◆ CanExport()
bool vtkSMRenderViewExporterProxy::CanExport ( vtkSMProxy *  )
Default implementation return true if the view is a render view.
