vtkSMCSVExporterProxy Class Reference
exporter used to export the spreadsheet view and supported chart views as to a CSV file. More...
#include <vtkSMCSVExporterProxy.h>
Inheritance diagram for vtkSMCSVExporterProxy:
Collaboration diagram for vtkSMCSVExporterProxy:
typedef vtkSMExporterProxy Superclass
- Public Types inherited from vtkSMExporterProxy
typedef vtkSMProxy Superclass
void Write () override
 Exports the view. More...
bool CanExport (vtkSMProxy *) override
 Returns if the view can be exported. More...
- Public Member Functions inherited from vtkSMExporterProxy
void SetView (vtkSMViewProxy *view)
 Set the view proxy to export. More...
virtual vtkSMViewProxy * GetView ()
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMCSVExporterProxy * New ()
static vtkSMCSVExporterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExporterProxy
static vtkSMExporterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMCSVExporterProxy ()
 ~vtkSMCSVExporterProxy () override
- Protected Member Functions inherited from vtkSMExporterProxy
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMExporterProxy
vtkSMViewProxy * View
std::vector< std::string > FileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMCSVExporterProxy is used to export the certain views to a CSV file. Currently, we support vtkSpreadSheetView and vtkPVXYChartView (which includes Bar/Line/Quartile/Parallel Coordinates views).
See also
vtkCSVExporter
Definition at line 21 of file vtkSMCSVExporterProxy.h.
Definition at line 25 of file vtkSMCSVExporterProxy.h.
◆ vtkSMCSVExporterProxy()
vtkSMCSVExporterProxy::vtkSMCSVExporterProxy ( )
◆ ~vtkSMCSVExporterProxy()
vtkSMCSVExporterProxy::~vtkSMCSVExporterProxy ( )
static vtkSMCSVExporterProxy* vtkSMCSVExporterProxy::New ( )
virtual const char* vtkSMCSVExporterProxy::GetClassName ( )
Reimplemented from vtkSMExporterProxy.
static int vtkSMCSVExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMCSVExporterProxy::IsA ( const char *  type)
static vtkSMCSVExporterProxy* vtkSMCSVExporterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMCSVExporterProxy::PrintSelf ( ostream &  os,
◆ Write()
void vtkSMCSVExporterProxy::Write ( )
Exports the view.
Implements vtkSMExporterProxy.
◆ CanExport()
bool vtkSMCSVExporterProxy::CanExport ( vtkSMProxy *  )
Default implementation return true if the view is a render view.
