vtkSIPVRepresentationProxy Class Reference
#include <vtkSIPVRepresentationProxy.h>
Inheritance diagram for vtkSIPVRepresentationProxy:
Collaboration diagram for vtkSIPVRepresentationProxy:
typedef vtkSIProxy Superclass
- Public Types inherited from vtkSIProxy
typedef vtkSIObject Superclass
- Public Types inherited from vtkSIObject
void AboutToDelete () override
 This method is called before the deletion of the SIObject. More...
- Public Member Functions inherited from vtkSIProxy
void Push (vtkSMMessage *msg) override
 Push a new state to the underneath implementation. More...
void Pull (vtkSMMessage *msg) override
 Pull the current state of the underneath implementation. More...
vtkSIProperty * GetSIProperty (const char *name)
 Provides access to the property helper. More...
bool IsNullProxy ()
 Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More...
 Triggers UpdateInformation() on vtkObject if possible. More...
 Called by vtkSMProxy::RecreateVTKObjects() to re-create the VTK objects. More...
virtual bool ExtendDefinition (const char *xml)
 Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More...
vtkObjectBase * GetVTKObject ()
 Returns access to the VTKObject pointer, if any. More...
void SetVTKObject (vtkObjectBase *)
 Returns the VTKClassName. More...
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual void AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method)
 These methods are called to add/remove input connections by vtkSIInputProperty. More...
virtual void CleanInputs (const char *method)
- Public Member Functions inherited from vtkSIObject
virtual void Initialize (vtkPVSessionCore *session)
 Initializes the instance. More...
vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the Interpreter. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid) const
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void SetGlobalID (vtkTypeUInt32)
 Get/Set the global id for this object. More...
static vtkSIPVRepresentationProxy * New ()
static vtkSIPVRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProxy
static vtkSIProxy * New ()
static vtkSIProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIObject
static vtkSIObject * New ()
static vtkSIObject * SafeDownCast (vtkObject *o)
 vtkSIPVRepresentationProxy ()
 ~vtkSIPVRepresentationProxy () override
bool ReadXMLAttributes (vtkPVXMLElement *element) override
 Parses the XML to create property/subproxy helpers. More...
- Protected Member Functions inherited from vtkSIProxy
 vtkSIProxy ()
 ~vtkSIProxy () override
virtual vtkObjectBase * NewVTKObject (const char *className)
 Create an instance of the class specified. More...
vtkSIProxy * GetSubSIProxy (const char *name)
 Returns the subproxy helper for the subproxy with the given name, if any. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Provides access to the vtkSIProxyDefinitionManager held by the session. More...
virtual bool CreateVTKObjects ()
 Creates the VTK objects. More...
virtual void DeleteVTKObjects ()
 Called to delete VTK objects. More...
virtual void OnCreateVTKObjects ()
 Called after CreateVTKObjects(). More...
bool InitializeAndCreateVTKObjects (vtkSMMessage *message)
 Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More...
void AddSIProperty (const char *name, vtkSIProperty *)
 Adds a vtkSMProperty's server-implementation. More...
virtual void SetPostPush (const char *)
virtual void SetPostCreation (const char *)
virtual char * GetLogName ()
unsigned int GetNumberOfSubSIProxys ()
 API to iterate over subproxy helpers. More...
vtkSIProxy * GetSubSIProxy (unsigned int cc)
virtual bool ReadXMLProperty (vtkPVXMLElement *property_element)
virtual bool ReadXMLSubProxy (vtkPVXMLElement *subproxy_element)
- Protected Member Functions inherited from vtkSIObject
 vtkSIObject ()
 ~vtkSIObject () override
- Protected Attributes inherited from vtkSIProxy
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLSubProxyName
char * PostPush
char * PostCreation
int NumberOfInputPorts
vtkSmartPointer< vtkObjectBase > VTKObject
bool ObjectsCreated
- Protected Attributes inherited from vtkSIObject
vtkWeakPointer< vtkClientServerInterpreter > Interpreter
vtkWeakPointer< vtkPVSessionCore > SessionCore
vtkSMMessage * LastPushedMessage
vtkTypeUInt32 GlobalID
vtkSIPVRepresentationProxy is the helper for vtkSMPVRepresentationProxy.
Definition at line 15 of file vtkSIPVRepresentationProxy.h.
Definition at line 19 of file vtkSIPVRepresentationProxy.h.
◆ vtkSIPVRepresentationProxy()
vtkSIPVRepresentationProxy::vtkSIPVRepresentationProxy ( )
◆ ~vtkSIPVRepresentationProxy()
vtkSIPVRepresentationProxy::~vtkSIPVRepresentationProxy ( )
static vtkSIPVRepresentationProxy* vtkSIPVRepresentationProxy::New ( )
virtual const char* vtkSIPVRepresentationProxy::GetClassName ( )
Reimplemented from vtkSIProxy.
static int vtkSIPVRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSIPVRepresentationProxy::IsA ( const char *  type)
static vtkSIPVRepresentationProxy* vtkSIPVRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSIPVRepresentationProxy::PrintSelf ( ostream &  os,
◆ AboutToDelete()
void vtkSIPVRepresentationProxy::AboutToDelete ( )
Basically this is used to remove all dependency with other SIObject so after a first pass on all SIObject with a AboutToDelete() we can simply delete the remaining SIObjects.
◆ ReadXMLAttributes()
bool vtkSIPVRepresentationProxy::ReadXMLAttributes ( vtkPVXMLElement *  element)
overrideprotectedvirtual
Overridden to parse all the "RepresentationType" elements.
