Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
vtkClientServerInterpreter Class Reference
Run-time VTK interpreter. More...
#include <vtkClientServerInterpreter.h>
Inheritance diagram for vtkClientServerInterpreter:
Collaboration diagram for vtkClientServerInterpreter:
struct  NewCallbackInfo
 The callback data structure passed to observers looking for VTK object creation and deletion events. More...
 vtkClientServerInterpreter (const vtkClientServerInterpreter &)=delete
vtkClientServerInterpreteroperator= (const vtkClientServerInterpreter &)=delete
int ProcessOneMessage (const vtkClientServerStream &css, int message)
 Process the message with the given index in the given stream. More...
const vtkClientServerStreamGetMessageFromID (vtkClientServerID id)
 Get the message for an ID. More...
const vtkClientServerStreamGetLastResult () const
 Get the last result message. More...
vtkObjectBaseGetObjectFromID (vtkClientServerID id)
 Return a pointer to a vtkObjectBase for an ID whose message contains only the one object. More...
vtkObjectBaseGetObjectFromID (vtkClientServerID id, int noerror)
vtkClientServerID GetIDFromObject (vtkObjectBase *key)
 Return an ID given a pointer to a vtkObjectBase (or 0 if object is not found) More...
int NewInstance (vtkObjectBase *obj, vtkClientServerID id)
 Called by generated code to register a new class instance. More...
VTK_NEWINSTANCE vtkObjectBaseNewInstance (const char *classname)
 Creates a new instance for the class specified using the interpreter. More...
int NewObserver (vtkObject *obj, const char *event, const vtkClientServerStream &css)
 Called by generated code to add an observer to a wrapped object. More...
void AddCommandFunction (const char *cname, vtkClientServerCommandFunction func, void *ctx=nullptr, vtkContextFreeFunction ctx_free=nullptr)
 Add a command function for a class. More...
bool HasCommandFunction (const char *cname)
 Return true if the classname has a command function, false otherwise. More...
int CallCommandFunction (const char *classname, vtkObjectBase *ptr, const char *method, const vtkClientServerStream &msg, vtkClientServerStream &result)
 Call a command function. More...
void AddNewInstanceFunction (const char *cname, vtkClientServerNewInstanceFunction f, void *ctx=nullptr, vtkContextFreeFunction ctx_free=nullptr)
 Add a function used to create new objects. More...
void ClearLastResult ()
 Resets the LastResult stream. More...
vtkClientServerID GetNextAvailableId ()
 Return the next available Id that can be used to create a new object. More...
int ProcessStream (const unsigned char *msg, size_t msgLength)
 Process all messages in a given vtkClientServerStream. More...
int ProcessStream (const vtkClientServerStream &css)
void SetLogFile (const char *name)
 Get/Set a stream to which an execution log is written. More...
virtual void SetLogStream (ostream *ostr)
virtual ostream * GetLogStream ()
int Load (const char *moduleName)
 Dynamically load a wrapper module into the interpreter. More...
int Load (const char *moduleName, const char *const *optionalPaths)
static vtkClientServerInterpreterNew ()
static vtkClientServerInterpreterSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkClientServerInterpreter ()
 ~vtkClientServerInterpreter () override
int ProcessCommandNew (const vtkClientServerStream &css, int midx)
int ProcessCommandInvoke (const vtkClientServerStream &css, int midx)
int ProcessCommandDelete (const vtkClientServerStream &css, int midx)
int ProcessCommandAssign (const vtkClientServerStream &css, int midx)
int ExpandMessage (const vtkClientServerStream &in, int inIndex, int startArgument, vtkClientServerStream &out)
int LoadInternal (const char *moduleName, const char *fullPath)
ostream * LogStream
ostream * LogFileStream
vtkClientServerInterpreter will process messages stored in a vtkClientServerStream. This allows run-time creation and execution of VTK programs.
Definition at line 51 of file vtkClientServerInterpreter.h.
Definition at line 55 of file vtkClientServerInterpreter.h.
◆ vtkClientServerInterpreter() [1/2]
vtkClientServerInterpreter::vtkClientServerInterpreter ( const vtkClientServerInterpreter )
delete
◆ vtkClientServerInterpreter() [2/2]
vtkClientServerInterpreter::vtkClientServerInterpreter ( )
◆ ~vtkClientServerInterpreter()
vtkClientServerInterpreter::~vtkClientServerInterpreter ( )
static vtkClientServerInterpreter* vtkClientServerInterpreter::New ( )
virtual const char* vtkClientServerInterpreter::GetClassName ( )
static int vtkClientServerInterpreter::IsTypeOf ( const char *  type)
virtual int vtkClientServerInterpreter::IsA ( const char *  type)
static vtkClientServerInterpreter* vtkClientServerInterpreter::SafeDownCast ( vtkObject o)
void vtkClientServerInterpreter::PrintSelf ( ostream &  os,
◆ operator=()
vtkClientServerInterpreter& vtkClientServerInterpreter::operator= ( const vtkClientServerInterpreter )
delete
◆ ProcessStream() [1/2]
int vtkClientServerInterpreter::ProcessStream ( const unsigned char *  msg,
size_t  msgLength
Return 1 if all messages succeeded, and 0 otherwise.
◆ ProcessStream() [2/2]
int vtkClientServerInterpreter::ProcessStream ( const vtkClientServerStream css)
◆ ProcessOneMessage()
int vtkClientServerInterpreter::ProcessOneMessage ( const vtkClientServerStream css,
int  message
Returns 1 for success, 0 for failure.
◆ GetMessageFromID()
const vtkClientServerStream* vtkClientServerInterpreter::GetMessageFromID ( vtkClientServerID  id)
ID 0 always returns a nullptr message.
◆ GetLastResult()
const vtkClientServerStream& vtkClientServerInterpreter::GetLastResult ( ) const
◆ GetObjectFromID() [1/2]
vtkObjectBase* vtkClientServerInterpreter::GetObjectFromID ( vtkClientServerID  id)
inline
Definition at line 90 of file vtkClientServerInterpreter.h.
◆ GetObjectFromID() [2/2]
vtkObjectBase* vtkClientServerInterpreter::GetObjectFromID ( vtkClientServerID  id,
int  noerror
◆ GetIDFromObject()
vtkClientServerID vtkClientServerInterpreter::GetIDFromObject ( vtkObjectBase key)
◆ SetLogFile()
void vtkClientServerInterpreter::SetLogFile ( const char *  name)
◆ SetLogStream()
virtual void vtkClientServerInterpreter::SetLogStream ( ostream *  ostr)
◆ GetLogStream()
virtual ostream* vtkClientServerInterpreter::GetLogStream ( )
◆ NewInstance() [1/2]
int vtkClientServerInterpreter::NewInstance ( vtkObjectBase obj,
Do not call directly.
◆ NewInstance() [2/2]
VTK_NEWINSTANCE vtkObjectBase* vtkClientServerInterpreter::NewInstance ( const char *  classname)
◆ NewObserver()
int vtkClientServerInterpreter::NewObserver ( vtkObject obj,
const char *  event,
◆ AddCommandFunction()
void vtkClientServerInterpreter::AddCommandFunction ( const char *  cname,
void *  ctx = nullptr,
vtkContextFreeFunction  ctx_free = nullptr
◆ HasCommandFunction()
bool vtkClientServerInterpreter::HasCommandFunction ( const char *  cname)
◆ CallCommandFunction()
int vtkClientServerInterpreter::CallCommandFunction ( const char *  classname,
vtkObjectBase ptr,
const char *  method,
const vtkClientServerStream msg,
vtkClientServerStream result
◆ AddNewInstanceFunction()
void vtkClientServerInterpreter::AddNewInstanceFunction ( const char *  cname,
◆ ClearLastResult()
void vtkClientServerInterpreter::ClearLastResult ( )
◆ Load() [1/2]
int vtkClientServerInterpreter::Load ( const char *  moduleName)
Returns 1 for success and 0 for failure.
◆ Load() [2/2]
int vtkClientServerInterpreter::Load ( const char *  moduleName,
const char *const *  optionalPaths
◆ GetNextAvailableId()
vtkClientServerID vtkClientServerInterpreter::GetNextAvailableId ( )
This only work if all class that created object into the interpretor have used this method. Basically it is just a counter available with the interpreter instance.
◆ ProcessCommandNew()
int vtkClientServerInterpreter::ProcessCommandNew ( const vtkClientServerStream css,
int  midx
◆ ProcessCommandInvoke()
int vtkClientServerInterpreter::ProcessCommandInvoke ( const vtkClientServerStream css,
int  midx
◆ ProcessCommandDelete()
int vtkClientServerInterpreter::ProcessCommandDelete ( const vtkClientServerStream css,
int  midx
◆ ProcessCommandAssign()
int vtkClientServerInterpreter::ProcessCommandAssign ( const vtkClientServerStream css,
int  midx
◆ ExpandMessage()
int vtkClientServerInterpreter::ExpandMessage ( const vtkClientServerStream in,
int  inIndex,
int  startArgument,
vtkClientServerStream out
◆ LoadInternal()
int vtkClientServerInterpreter::LoadInternal ( const char *  moduleName,
const char *  fullPath
◆ LogStream
ostream* vtkClientServerInterpreter::LogStream
Definition at line 189 of file vtkClientServerInterpreter.h.
◆ LogFileStream
ostream* vtkClientServerInterpreter::LogFileStream
Definition at line 190 of file vtkClientServerInterpreter.h.
