Public Member Functions | Friends | List of all members
pqReaderSelectionPropertyWidget Class Reference
Used to select readers to show or hide. More...
#include <pqReaderSelectionPropertyWidget.h>
Inheritance diagram for pqReaderSelectionPropertyWidget:
Collaboration diagram for pqReaderSelectionPropertyWidget:
 pqReaderSelectionPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqReaderSelectionPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Friends
class pqInternals
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
This widget is used in the settings to show a checklist of available readers, letting the user exclude some of them from the list shown in the File .. Open dialog.
See also
pqArraySelectorPropertyWidget
Definition at line 23 of file pqReaderSelectionPropertyWidget.h.
◆ pqReaderSelectionPropertyWidget()
pqReaderSelectionPropertyWidget::pqReaderSelectionPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqReaderSelectionPropertyWidget()
pqReaderSelectionPropertyWidget::~pqReaderSelectionPropertyWidget ( )
override
◆ pqInternals
friend class pqInternals
friend
Definition at line 38 of file pqReaderSelectionPropertyWidget.h.
