Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
vtkPVTransferFunction2D Class Reference
Defines a 2D transfer function for mapping to RGBA values for volume rendering. More...
#include <vtkPVTransferFunction2D.h>
Inheritance diagram for vtkPVTransferFunction2D:
Collaboration diagram for vtkPVTransferFunction2D:
virtual void Build ()
 Generate the transfer function image data. More...
std::vector< vtkSmartPointer< vtkPVTransferFunction2DBox > > GetBoxes ()
 Get the control boxes defined on the function. More...
void RemoveAllBoxes ()
 Remove all control boxes from the transfer function. More...
vtkImageData * GetFunction ()
 Get the 2D transfer function. More...
virtual void SetOutputDimensions (int, int)
 Set/Get the output dimensions of the image data that is the transfer function. More...
void SetOutputDimensions (int[2])
virtual int * GetOutputDimensions ()
virtual void GetOutputDimensions (int &, int &)
virtual void GetOutputDimensions (int[2])
int AddControlBox (double x, double y, double width, double height, double r, double g, double b, double a)
 Add/Remove a control box to/from the 2D transfer function. More...
int AddControlBox (double x, double y, double width, double height, double *color)
int AddControlBox (vtkRectd &box, double *color)
int AddControlBox (vtkSmartPointer< vtkPVTransferFunction2DBox > box)
int SetControlBox (int id, vtkSmartPointer< vtkPVTransferFunction2DBox > box)
int RemoveControlBox (int id)
int RemoveControlBox (vtkSmartPointer< vtkPVTransferFunction2DBox > box)
virtual void SetRange (double, double, double, double)
 Set/Get the range of the function. More...
virtual void SetRange (double[4])
virtual double * GetRange ()
virtual void GetRange (double &, double &, double &, double &)
virtual void GetRange (double[4])
static vtkPVTransferFunction2D * New ()
 Instantiate the class. More...
 vtkPVTransferFunction2D ()
 ~vtkPVTransferFunction2D () override
bool UpdateRange ()
 Update the range of the function. More...
double Range [4] = { 0, 0, 0, 0 }
 The range for the X and Y axes of the function. More...
int OutputDimensions [2] = { 10, 10 }
 The output dimensions for the transfer function. More...
 Standard methods for the VTK class. More...
static vtkPVTransferFunction2D * SafeDownCast (vtkObject *o)
vtkPVTransferFunction2D is a color mapping in RGBA space that uses 2D functions to allow interpolation along both the X and Y axes of the function.
Definition at line 27 of file vtkPVTransferFunction2D.h.
Definition at line 39 of file vtkPVTransferFunction2D.h.
◆ vtkPVTransferFunction2D()
vtkPVTransferFunction2D::vtkPVTransferFunction2D ( )
◆ ~vtkPVTransferFunction2D()
vtkPVTransferFunction2D::~vtkPVTransferFunction2D ( )
static vtkPVTransferFunction2D* vtkPVTransferFunction2D::New ( )
virtual const char* vtkPVTransferFunction2D::GetClassName ( )
static int vtkPVTransferFunction2D::IsTypeOf ( const char *  type)
virtual int vtkPVTransferFunction2D::IsA ( const char *  type)
static vtkPVTransferFunction2D* vtkPVTransferFunction2D::SafeDownCast ( vtkObject *  o)
void vtkPVTransferFunction2D::PrintSelf ( ostream &  os,
◆ Build()
virtual void vtkPVTransferFunction2D::Build ( )
◆ SetOutputDimensions() [1/2]
virtual void vtkPVTransferFunction2D::SetOutputDimensions ( int  ,
int
By default, this is (10, 10).
◆ SetOutputDimensions() [2/2]
void vtkPVTransferFunction2D::SetOutputDimensions ( int  [2])
◆ GetOutputDimensions() [1/3]
virtual int* vtkPVTransferFunction2D::GetOutputDimensions ( )
◆ GetOutputDimensions() [2/3]
virtual void vtkPVTransferFunction2D::GetOutputDimensions ( int &  ,
int &
◆ GetOutputDimensions() [3/3]
virtual void vtkPVTransferFunction2D::GetOutputDimensions ( int  [2])
◆ AddControlBox() [1/4]
int vtkPVTransferFunction2D::AddControlBox ( double  x,
double  y,
double  width,
double  height,
double  r,
double  g,
double  b,
double  a
Returns the index of the added box or -1 on error.
Note
This function does not check to see if the box already exists in the function before adding it. Adding an existing box would add a duplicate control to the transfer function.
◆ AddControlBox() [2/4]
double  y,
double  width,
double  height,
double *  color
Note
◆ AddControlBox() [3/4]
int vtkPVTransferFunction2D::AddControlBox ( vtkRectd &  box,
double *  color
Note
◆ AddControlBox() [4/4]
int vtkPVTransferFunction2D::AddControlBox ( vtkSmartPointer< vtkPVTransferFunction2DBox >  box)
Note
◆ SetControlBox()
int vtkPVTransferFunction2D::SetControlBox ( int  id,
Note
◆ RemoveControlBox() [1/2]
int vtkPVTransferFunction2D::RemoveControlBox ( int  id)
Note
◆ RemoveControlBox() [2/2]
int vtkPVTransferFunction2D::RemoveControlBox ( vtkSmartPointer< vtkPVTransferFunction2DBox >  box)
Note
◆ GetBoxes()
std::vector<vtkSmartPointer<vtkPVTransferFunction2DBox> > vtkPVTransferFunction2D::GetBoxes ( )
◆ RemoveAllBoxes()
void vtkPVTransferFunction2D::RemoveAllBoxes ( )
◆ SetRange() [1/2]
virtual void vtkPVTransferFunction2D::SetRange ( double  ,
double  ,
double  ,
double
Set/Get the (minX, maxX, minY, maxY) for the 2D transfer function.
◆ SetRange() [2/2]
virtual void vtkPVTransferFunction2D::SetRange ( double  [4])
◆ GetRange() [1/3]
virtual double* vtkPVTransferFunction2D::GetRange ( )
◆ GetRange() [2/3]
virtual void vtkPVTransferFunction2D::GetRange ( double &  ,
double &  ,
double &  ,
double &
◆ GetRange() [3/3]
virtual void vtkPVTransferFunction2D::GetRange ( double  [4])
◆ GetFunction()
vtkImageData* vtkPVTransferFunction2D::GetFunction ( )
◆ UpdateRange()
bool vtkPVTransferFunction2D::UpdateRange ( )
Returns true if the range changes. If the range has changed, calls Modified(). If UseCustomRange is set, this is a no-op.
◆ Range
double vtkPVTransferFunction2D::Range[4] = { 0, 0, 0, 0 }
This will determine the bounds of the transfer function.
Definition at line 108 of file vtkPVTransferFunction2D.h.
◆ OutputDimensions
int vtkPVTransferFunction2D::OutputDimensions[2] = { 10, 10 }
Definition at line 113 of file vtkPVTransferFunction2D.h.
