pqCheckableProperty.h
4 #ifndef pqCheckableProperty_h
5 #define pqCheckableProperty_h
6
7 #include "pqApplicationComponentsModule.h"
8 #include "pqPropertyWidget.h"
9
10 #include <memory>
11
47 class PQAPPLICATIONCOMPONENTS_EXPORT pqCheckableProperty : public pqPropertyWidget
48 {
49  Q_OBJECT
51
52 public:
53  pqCheckableProperty(vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = nullptr);
54  ~pqCheckableProperty() override;
55
56  void apply() override;
57  void reset() override;
58  void select() override;
59  void deselect() override;
60  void updateWidget(bool showing_advanced_properties) override;
61  void setPanelVisibility(const char* vis) override;
62  void setView(pqView*) override;
63  bool isSingleRowItem() const override;
64
65  bool enableCheckbox() const;
66
67 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
68  void setEnableCheckbox(bool enableCheckbox);
69
70 private:
71  Q_PROPERTY(bool enableCheckbox READ enableCheckbox WRITE setEnableCheckbox)
72
73  struct Internal;
74  std::unique_ptr<Internal> internal;
75 };
76
77 #endif
pqView
This is a PQ abstraction of a generic view module.
Definition: pqView.h:26
pqPropertyWidget
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
Definition: pqPropertyWidget.h:25
pqPropertyWidget::isSingleRowItem
virtual bool isSingleRowItem() const
Determines if the PropertyWidget must be constructed using a single row.
pqPropertyWidget::setView
virtual void setView(pqView *)
called to set the active view.
vtkSMProxy
Definition: vtkSMProxy.h:140
pqPropertyWidget::setPanelVisibility
virtual void setPanelVisibility(const char *vis)
pqPropertyWidget::updateWidget
virtual void updateWidget(bool showing_advanced_properties)
Definition: pqPropertyWidget.h:59
vtkSMPropertyGroup
Definition: vtkSMPropertyGroup.h:16
pqPropertyWidget.h
pqPropertyWidget::deselect
virtual void deselect()
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive.
Definition: pqPropertyWidget.h:50
pqPropertyWidget::apply
virtual void apply()
pqPropertyWidget::select
virtual void select()
Definition: pqPropertyWidget.h:48
pqCheckableProperty
property widget for properties representing a checkable property.
Definition: pqCheckableProperty.h:47
pqPropertyWidget::reset
virtual void reset()
