Controller that encapsulates control logic for typical ParaView applications.
| virtual bool | InitializeSession (vtkSMSession *session) |
| | Call this method to setup a branch new session with state considered essential for ParaView session. More...
| virtual vtkSMProxy * | FindTimeKeeper (vtkSMSession *session) |
| | Returns the TimeKeeper proxy associated with the session. More...
| virtual vtkSMProxy * | FindMaterialLibrary (vtkSMSession *session) |
| | Returns the MaterialLibrary proxy associated with the session. More...
| virtual bool | PreInitializeProxy (vtkSMProxy *proxy) |
| | Pre-initializes a proxy i.e. More...
| virtual bool | PostInitializeProxy (vtkSMProxy *proxy) |
| | Final step in proxy initialization. More...
| bool | InitializeProxy (vtkSMProxy *proxy) |
| | Convenience method to call PreInitializeProxy and PostInitializeProxy. More...
| virtual bool | FinalizeProxy (vtkSMProxy *proxy) |
| | Cleans up any helper proxies registered for the proxy in PreInitializeProxy/PostInitializeProxy. More...
| virtual bool | RegisterPipelineProxy (vtkSMProxy *proxy, const char *proxyname) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a pipeline proxy with the proxy manager. More...
| virtual bool | RegisterPipelineProxy (vtkSMProxy *proxy) |
| virtual bool | UnRegisterPipelineProxy (vtkSMProxy *proxy) |
| | Unregisters a pipeline proxy. More...
| virtual bool | RegisterViewProxy (vtkSMProxy *proxy) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a view proxy with the proxy manager. More...
| virtual bool | RegisterViewProxy (vtkSMProxy *proxy, const char *proxyname) |
| virtual bool | UnRegisterViewProxy (vtkSMProxy *proxy, bool unregister_representations=true) |
| | Inverse of RegisterViewProxy. More...
| virtual bool | RegisterRepresentationProxy (vtkSMProxy *proxy) |
| | Registration method for representations to be used after PreInitializeProxy() and PostInitializeProxy(). More...
| virtual bool | UnRegisterRepresentationProxy (vtkSMProxy *proxy) |
| | Unregisters a representation proxy. More...
| virtual bool | RegisterColorTransferFunctionProxy (vtkSMProxy *proxy, const char *proxyname) |
| | Registration method for color transfer function proxies to be used after PreInitializeProxy() and PostInitializeProxy() calls. More...
| virtual bool | RegisterColorTransferFunctionProxy (vtkSMProxy *proxy) |
| virtual bool | RegisterOpacityTransferFunction (vtkSMProxy *proxy, const char *proxyname) |
| | Registration method for opacity transfer function proxies. More...
| virtual bool | RegisterOpacityTransferFunction (vtkSMProxy *proxy) |
| virtual bool | RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view, const char *proxyname) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a light proxy with the proxy manager. More...
| virtual bool | RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view) |
| virtual bool | RegisterTextureProxy (vtkSMProxy *proxy, const char *filename) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register a texture proxy with the proxy manager. More...
| virtual bool | RegisterExtractorProxy (vtkSMProxy *proxy, const char *proxyname) |
| | Registers an extractor. More...
| virtual bool | RegisterExtractorProxy (vtkSMProxy *proxy) |
| virtual vtkSMProxy * | FindAnimationScene (vtkSMSession *session) |
| | Returns the animation scene, if any. More...
| virtual vtkSMProxy * | GetAnimationScene (vtkSMSession *session) |
| | Returns the animation scene for the session. More...
| virtual vtkSMProxy * | FindTimeAnimationTrack (vtkSMProxy *scene) |
| | Return the animation track for time, if any. More...
| virtual vtkSMProxy * | GetTimeAnimationTrack (vtkSMProxy *scene) |
| | Return the animation track for time. More...
| virtual bool | RegisterAnimationProxy (vtkSMProxy *proxy) |
| | Use this method after PreInitializeProxy() and PostInitializeProxy() to register an animation proxy with the proxy manager. More...
| virtual bool | UnRegisterAnimationProxy (vtkSMProxy *proxy) |
| | Inverse of RegisterAnimationProxy. More...
| virtual void | UpdateSettingsProxies (vtkSMSession *session) |
| | Initializes and registers proxies in the "settings" group that haven't been already. More...
| virtual bool | UnRegisterProxy (vtkSMProxy *proxy) |
| | A catch-all method do cleanup and unregister any proxies that were registered using Register..Proxy() APIs on this class. More...
| | vtkSMParaViewPipelineController () |
| | ~vtkSMParaViewPipelineController () override |
| vtkSMProxy * | FindProxy (vtkSMSessionProxyManager *pxm, const char *reggroup, const char *xmlgroup, const char *xmltype) |
| | Find proxy of the group type (xmlgroup, xmltype) registered under a particular group (reggroup). More...
| virtual bool | SetupGlobalPropertiesLinks (vtkSMProxy *proxy) |
| | Setup global properties links based on hints for properties in the XML. More...
| virtual bool | CreateAnimationHelpers (vtkSMProxy *proxy) |
| | To help animation representation properties such as visibility, opacity, we create animation helpers. More...
| virtual bool | UnRegisterDependencies (vtkSMProxy *proxy) |
| | Unregisters know proxy dependencies that must be removed when the proxy is to be deleted e.g animation cues, representations, etc. More...
| vtkMTimeType | GetInitializationTime (vtkSMProxy *) |
| | Returns the initialization timestamp for the proxy, if available. More...
| void | ProcessInitializationHelperRegistration (vtkSMProxy *) |
| | If the proxy has initialization helpers, let those classes also handle registration tasks, if any. More...
| virtual void | DoMaterialSetup (vtkSMProxy *proxy) |
| | An entry point to load a catalog of OSPRay rendering materials. More...
| virtual bool | CreateProxiesForProxyListDomains (vtkSMProxy *proxy) |
| | Creates new proxies for proxies referred in vtkSMProxyListDomain for any of the properties for the given proxy. More...
| virtual void | RegisterProxiesForProxyListDomains (vtkSMProxy *proxy) |
| void | ProcessInitializationHelper (vtkSMProxy *, vtkMTimeType initializationTimeStamp) |
| | Proxies can specify custom initialization using XML hints. More...
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
ParaView's ServerManager, together with it's proxies and properties provides a mechanism to create visualization and data processing pipelines. However, for a complex application like ParaView, there is considerable control logic to manage these proxies, set them up, etc. for common operations supported by the application. vtkSMParaViewPipelineController provides us a mechanism to encapsulate just control logic with ability to customize and extend for custom applications, similar to ParaView.
vtkSMParaViewPipelineController has no state of itself. When needed, one should simply create an instance of vtkSMParaViewPipelineController and release it once done.
vtkSMParaViewPipelineController uses the vtkObjectFactory mechanism. Custom application developers can provide subclasses and override the behaviour (see vtkSMParaViewPipelineControllerWithRender).
For an example of using vtkSMParaViewPipelineController in your application, see Remoting/Views/Testing/Cxx/TestParaViewPipelineController.cxx.
Definition at line 52 of file vtkSMParaViewPipelineController.h.
