| const char * | GetURI () override |
| | Return the url used to connect the current session to a server. More...
| virtual bool | Connect (const char *url, int timeout=60) |
| | Connects a remote server. More...
| bool | GetIsAlive () override |
| | Returns true is this session is active/alive/valid. More...
| ServerFlags | GetProcessRoles () override |
| | Returns a ServerFlags indicate the nature of the current processes. More...
| vtkMultiProcessController * | GetController (ServerFlags processType) override |
| | Returns the controller used to communicate with the process. More...
| vtkPVServerInformation * | GetServerInformation () override |
| | vtkPVServerInformation is an information-object that provides information about the server processes. More...
| void | Initialize () override |
| | Called to do any initializations after a successful session has been established. More...
| void | CloseSession () |
| | Gracefully exits the session. More...
| bool | GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) override |
| | Gather information about an object referred by the globalid. More...
| int | GetNumberOfProcesses (vtkTypeUInt32 servers) override |
| | Returns the number of processes on the given server/s. More...
| bool | IsMPIInitialized (vtkTypeUInt32 servers) override |
| | Returns whether or not MPI is initialized on the specified server/s. More...
| void | PreDisconnection () override |
| virtual bool | IsNotBusy () |
| | Flag used to know if it is a good time to handle server notification. More...
| virtual void | StartBusyWork () |
| | BusyWork should be declared inside method that will request several network call that we don't want to interrupt such as GatherInformation and Pull. More...
| virtual void | EndBusyWork () |
| vtkSMCollaborationManager * | GetCollaborationManager () override |
| | Return the instance of vtkSMCollaborationManager that will be lazy created at the first call. More...
| int | GetConnectID () |
| | Return the connect id of this client. More...
| vtkTypeUInt32 | GetNextGlobalUniqueIdentifier () override |
| | Provides the next available identifier. More...
| vtkTypeUInt32 | GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) override |
| | Return the first Id of the requested chunk. More...
| void | OnServerNotificationMessageRMI (void *message, int message_length) |
| void | PushState (vtkSMMessage *msg) override |
| | Push the state. More...
| void | PullState (vtkSMMessage *message) override |
| void | ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false) override |
| const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) override |
| virtual void | SetAbortConnect (bool) |
| | When Connect() is waiting for a server to connect back to the client (in reverse connect mode), then it periodically fires ProgressEvent. More...
| void | PrepareProgressInternal () override |
| | Should be called to begin/end receiving progresses on this session. More...
| void | CleanupPendingProgressInternal () override |
| virtual vtkSMProxyLocator * | GetProxyLocator () |
| virtual unsigned int | GetRenderClientMode () |
| | Convenient method to determine if the rendering is done in a pvrenderer or not. More...
| void | NotifyAllClients (const vtkSMMessage *msg) override |
| | Sends the message to all clients. More...
| void | NotifyOtherClients (const vtkSMMessage *) override |
| | Sends the message to all but the active client-session. More...
| | Returns the vtkSMSessionProxyManager associated with this session. More...
| virtual vtkSMStateLocator * | GetStateLocator () |
| | Provide an access to the session state locator that can provide the last state of a given remote object that have been pushed. More...
| virtual bool | GetIsAutoMPI () |
| | This flag if set indicates that the current session module has automatically started "pvservers" as MPI processes as default pipeline. More...
| vtkMPIMToNSocketConnection * | GetMPIMToNSocketConnection () override |
| | This is socket connection, if any to communicate between the data-server and render-server nodes. More...
| vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| | Get the ProxyDefinitionManager. More...
| | Returns a vtkSIObject or subclass given its global id, if any. More...
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| | Return a vtkSMRemoteObject given its global id if any otherwise return NULL;. More...
| virtual void | GetAllRemoteObjects (vtkCollection *collection) |
| | Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More...
| virtual bool | IsProcessingRemoteNotification () |
| | This property is used to discard ignore_synchronization proxy property when we load protobuf states. More...
| virtual void | UseSessionCoreOf (vtkPVSessionBase *other) |
| | Update internal session core in order to use the one used in another session. More...
| virtual vtkPVSessionCore * | GetSessionCore () |
| | Provides access to the session core. More...
| bool | HasProcessRole (vtkTypeUInt32 flag) |
| | Convenience method that returns true if the current session is serving the indicated role on this process. More...
| virtual bool | IsMultiClients () |
| | Allow anyone to know easily if the current session is involved in collaboration or not. More...
| bool | GetPendingProgress () |
| | Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More...
| virtual vtkPVProgressHandler * | GetProgressHandler () |
| | Provides access to the progress handler. More...
| void | PrepareProgress () |
| void | CleanupPendingProgress () |
| static vtkSMSessionClient * | New () |
| static vtkSMSessionClient * | SafeDownCast (vtkObject *o) |
| static vtkSMSession * | New () |
| static vtkSMSession * | New (vtkPVSessionBase *otherSession) |
| static vtkSMSession * | New (vtkPVSessionCore *otherSessionCore) |
| static vtkSMSession * | SafeDownCast (vtkObject *o) |
| static vtkIdType | ConnectToCatalyst () |
| | These are static helper methods that help create Catalyst ParaView sessions. More...
| static vtkIdType | ConnectToSelf (int timeout=60) |
| | These are static helper methods that help create standard ParaView sessions. More...
| static vtkIdType | ConnectToRemote (const char *hostname, int port, int timeout=60) |
| static vtkIdType | ReverseConnectToRemote (int port) |
| | Same as ConnectToRemote() except that it waits for a reverse connection. More...
| static vtkIdType | ReverseConnectToRemote (int port, bool(*callback)()) |
| static vtkIdType | ConnectToRemote (const char *dshost, int dsport, const char *rshost, int rsport, int timeout=60) |
| static vtkIdType | ReverseConnectToRemote (int dsport, int rsport) |
| static vtkIdType | ReverseConnectToRemote (int dsport, int rsport, bool(*callback)()) |
| static void | Disconnect (vtkIdType sessionid) |
| | Use this method to disconnect from a session. More...
| static void | Disconnect (vtkSMSession *session) |
| static vtkPVSessionBase * | SafeDownCast (vtkObject *o) |
| static vtkPVSession * | SafeDownCast (vtkObject *o) |
| static vtkSession * | SafeDownCast (vtkObject *o) |
| | vtkSMSessionClient () |
| | ~vtkSMSessionClient () override |
| void | SetRenderServerController (vtkMultiProcessController *) |
| void | SetDataServerController (vtkMultiProcessController *) |
| void | SetupDataServerRenderServerConnection () |
| void | UnRegisterSIObject (vtkSMMessage *msg) override |
| | Delete server side object. More...
| void | RegisterSIObject (vtkSMMessage *msg) override |
| | Notify server side object that it is used by one more client. More...
| vtkTypeUInt32 | GetRealLocation (vtkTypeUInt32) |
| | Translates the location to a real location based on whether a separate render-server exists. More...
| virtual void | SetURI (const char *) |
| bool | OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata) override |
| | Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More...
| virtual void | OnConnectionLost (vtkObject *caller, unsigned long eventid, void *calldata) |
| | Callback when any vtkMultiProcessController subclass fires a ErrorEvent. More...
| | vtkSMSession (bool initialize_during_constructor=true, vtkPVSessionCore *preExistingSessionCore=NULL) |
| | ~vtkSMSession () override |
| virtual void | ProcessNotification (const vtkSMMessage *) |
| | Process the Notifation message sent using API to communicate from server-to-client. More...
| void | UpdateStateHistory (vtkSMMessage *msg) |
| | This method has been externalized so classes that heritate from vtkSMSession and override PushState could easily keep track of the StateHistory and maintain the UndoRedo mecanisme. More...
| | vtkPVSessionBase () |
| | vtkPVSessionBase (vtkPVSessionCore *coreToUse) |
| | ~vtkPVSessionBase () override |
| void | RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj) |
| | Register a remote object. More...
| void | UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location) |
| | Unregister a remote object. More...
| vtkPVSessionCore * | GetSessionCore () const |
| | Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More...
| void | SetSessionCore (vtkPVSessionCore *) |
| virtual bool | StartProcessingRemoteNotification () |
| | Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More...
| virtual void | StopProcessingRemoteNotification (bool previousValue) |
| | vtkPVSession () |
| | ~vtkPVSession () override |
| | vtkSession () |
| | ~vtkSession () override |
| virtual void | Activate () |
| | Subclasses must call this to mark the session active. More...
| virtual void | DeActivate () |
| | Subclasses must call this to mark the session inactive. More...
| | vtkObject () |
| | vtkObjectBase () |
vtkSMSessionClient is a remote-session that connects to a remote server.
vtkSMSessionClient supports both connecting a pvserver as well as connecting a pvdataserver/pvrenderserver.
Definition at line 35 of file vtkSMSessionClient.h.
