| void | DeepCopy (vtkPVServerInformation *info) |
| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| virtual void | SetNVPipeSupport (bool) |
| | if the server supports compressing images via NVPipe More...
| virtual bool | GetNVPipeSupport () |
| virtual bool | IsMPIInitialized () const |
| | Return whether MPI is initialized or not. More...
| virtual void | SetRemoteRendering (int) |
| | This flag indicates whether the server can render remotely. More...
| virtual int | GetRemoteRendering () |
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | SetTileDimensions (int, int) |
| | Variables (command line argurments) set to render to a tiled display. More...
| void | SetTileDimensions (int [2]) |
| virtual int * | GetTileDimensions () |
| virtual void | GetTileDimensions (int &, int &) |
| virtual void | GetTileDimensions (int [2]) |
| virtual void | SetTileMullions (int, int) |
| void | SetTileMullions (int [2]) |
| virtual int * | GetTileMullions () |
| virtual void | GetTileMullions (int &, int &) |
| virtual void | GetTileMullions (int [2]) |
| virtual void | SetUseIceT (int) |
| | Returns 1 if IceT is available. More...
| virtual int | GetUseIceT () |
| virtual void | SetTimeout (int) |
| | Get/Set the time after which the server timesout. More...
| virtual int | GetTimeout () |
| void | SetEyeSeparation (double value) |
| | Set/Get the EyeSeparation on server. More...
| double | GetEyeSeparation () const |
| void | SetNumberOfMachines (unsigned int num) |
| | Number of machines to use in data or render server Setting the number of machines has the side effect of wiping out any machine parameters previously set. More...
| unsigned int | GetNumberOfMachines () const |
| void | SetEnvironment (unsigned int idx, const char *name) |
| | Value of DISPLAY environment variable for this cave node. More...
| const char * | GetEnvironment (unsigned int idx) const |
| void | SetGeometry (unsigned int idx, int geo[4]) |
| | Window geometry for server, specified as x, y, width, height. More...
| int * | GetGeometry (unsigned int idx) const |
| void | SetFullScreen (unsigned int idx, bool fullscreen) |
| | Whether to show the server window as fullscreen. More...
| bool | GetFullScreen (unsigned int idx) const |
| void | SetShowBorders (unsigned int idx, bool borders) |
| | Whether to show the server window with window decorations. More...
| bool | GetShowBorders (unsigned int idx) const |
| int | GetStereoType (unsigned int idx) const |
| | Get the stereo-type specified in the pvx. More...
| void | SetStereoType (unsigned int idx, int type) |
| void | SetLowerLeft (unsigned int idx, double coord[3]) |
| | Coordinates of lower left corner of this cave display. More...
| double * | GetLowerLeft (unsigned int idx) const |
| void | SetLowerRight (unsigned int idx, double coord[3]) |
| | Coordinates of lower right corner of this cave display. More...
| double * | GetLowerRight (unsigned int idx) const |
| void | SetUpperRight (unsigned int idx, double coord[3]) |
| double * | GetUpperRight (unsigned int idx) const |
| virtual int | GetNumberOfProcesses () |
| | Get the number of processes. More...
| virtual int | GetMultiClientsEnable () |
| | Return true if the server allow server client to connect to itself. More...
| virtual int | GetClientId () |
| | Get the id that correspond to the current client. More...
| virtual void | SetIdTypeSize (int) |
| | Set/Get vtkIdType size, which can be 32 or 64. More...
| virtual int | GetIdTypeSize () |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
Gets features of the server.
This objects is used by the client to get the features supported by the server. At the moment, server information is only on the root.
Definition at line 33 of file vtkPVServerInformation.h.
